2023-07-20 | build: Load items on demand during a buildqual-87 | Sebastian Huber | |
If the CSafeLoader is available, load only the necessary build items. This considerably speeds up the build setup time if the CSafeLoader is used. | |||
2023-07-20 | build: Rename TOPGROUP in TOPGROUP_UID | Sebastian Huber | |
This makes it more obvious that this is an item UID. | |||
2023-07-20 | build: Avoid cache if CSafeLoader is available | Sebastian Huber | |
Move the item cache handling to a ItemCache class. Implement this class depending on the availability of CSafeLoader. | |||
2023-07-20 | build: Use CSafeLoader if available | Sebastian Huber | |
The CSafeLoader uses the C libyaml libary to considerably speed up the loading of YAML files. | |||
2023-07-20 | Add pre-qualified constraints | Sebastian Huber | |
2023-07-20 | build: Exclude performance test if RTEMS_GCOV_COVERAGE | Sebastian Huber | |
2023-07-20 | build: Do not use coverage for librtemstest | Sebastian Huber | |
2023-07-20 | build: Use -frandom-seed=0 | Sebastian Huber | |
2023-07-20 | Doxygen: Adding Doxygen groups to files | Frank Kühndel | |
2023-07-20 | libc: Avoid dead code in memset() | Sebastian Huber | |
2023-07-20 | build: FIXME introduce pre-qualified parts | Sebastian Huber | |
2023-07-20 | validation: Test memory allocation | Sebastian Huber | |
2023-07-20 | validation: Add MemorySave() and MemoryRestore() | Sebastian Huber | |
2023-07-20 | Replace Doxygen main page | Sebastian Huber | |
2023-07-20 | build: Add RTEMS_CLANG_STATIC_ANALYZER option | Sebastian Huber | |
2023-07-20 | build: Install test executables | Sebastian Huber | |
2023-07-20 | build: Support conditional build dependencies | Sebastian Huber | |
2023-07-20 | validation: Add tests derived from models | Andrew Butterfield | |
2023-07-20 | membench: Add memory benchmark programs | Sebastian Huber | |
2023-07-20 | unit: Test unlimited objects configuration | Frank Kühndel | |
2023-07-20 | unit: Test POSIX-specific message queue impl | Frank Kühndel | |
2023-07-20 | score: Add workaround for GCC bug | Sebastian Huber | |
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=108658 | |||
2023-07-20 | rtems: Update references to rtems_task_wake_after | Kinsey Moore | |
rtems_task_wake_after takes a parameter in terms of a count of clock ticks and not a measure in a subunit of seconds. This updates documentation to reflect that. This also makes obvious the caveat about the first tick wait not being a whole tick and points the user at a replacement for better accuracy. Updates #4772 | |||
2023-07-19 | powerpc/beatnik: Remove RTEMS_NETWORKING check from bsp.h | Vijay Kumar Banerjee | |
2023-07-17 | bsps/grlib: Fix use of uninitialized variable | Sebastian Huber | |
Fixes Coverity CID 1538314. | |||
2023-07-14 | score/arm: improve printed exception information for Cortex-Mx CPUs | Karel Gardas | |
Sponsored-By: Precidata | |||
2023-07-14 | bsp/leon3: Simplify shutdown | Sebastian Huber | |
Do not wait for other processors to halt. | |||
2023-07-14 | validation: Test sparc/leon3 BSP family | Sebastian Huber | |
Update #3716. | |||
2023-07-14 | validation: grlib | Sebastian Huber | |
Update #3716. | |||
2023-07-14 | bsp/leon3: Add specialized target hash | Sebastian Huber | |
2023-07-14 | bsp/leon3: Fix group memberships | Sebastian Huber | |
Update #3706. | |||
2023-07-14 | bsps/sparc: Remove BSP_POWER_DOWN_AT_FATAL_HALT | Sebastian Huber | |
Remove the BSP_POWER_DOWN_AT_FATAL_HALT BSP option. Applications should do the customization of the system termination with an initial fatal extension. | |||
2023-07-14 | bsp/leon3: Enable up-counter conditionally | Sebastian Huber | |
2023-07-14 | bsp/leon3: Use LEON3_GPTIMER_BASE | Sebastian Huber | |
2023-07-14 | bsp/leon3: Add LEON3_IRQAMP_EXTENDED_INTERRUPT | Sebastian Huber | |
2023-07-14 | bsp/leon3: Add LEON3_PROBE_ASR_22_23_UP_COUNTER | Sebastian Huber | |
2023-07-14 | bsp/leon3: Simplify fatal error handling | Sebastian Huber | |
2023-07-14 | bsp/leon3: Move leon3_power_down_loop() | Sebastian Huber | |
2023-07-14 | bsp/leon3: Add LEON3_L2CACHE_BASE | Sebastian Huber | |
2023-07-14 | bsp/leon3: Add LEON3_HAS_ASR_22_23_UP_COUNTER | Sebastian Huber | |
2023-07-14 | bsp/leon3: Add LEON3_IRQAMP_PROBE_TIMESTAMP | Sebastian Huber | |
2023-07-14 | bsp/leon3: Add LEON3_IRQAMP_BASE | Sebastian Huber | |
2023-07-14 | bsp/leon3: Add LEON3_GPTIMER_BASE | Sebastian Huber | |
2023-07-14 | bsp/leon3: LEON3_PLB_FREQUENCY_DEFINED_BY_GPTIMER | Sebastian Huber | |
2023-07-14 | bsp/leon3: Add LEON3_APBUART_BASE | Sebastian Huber | |
2023-07-14 | bsp/leon3: Use new L2CACHE register block API | Sebastian Huber | |
2023-07-14 | bsp/leon3: Use new GPTIMER register block API | Sebastian Huber | |
2023-07-14 | bsp/leon3: Move system control register support | Sebastian Huber | |
Move, document, and reformat support functions from <leon.h> to <bsp/leon3.h>. | |||
2023-07-14 | bsp/leon3: Use new IRQ(A)MP register block API | Sebastian Huber | |
2023-07-14 | bsp/leon3: Move and simplify bsp_irq_fixup() | Sebastian Huber | |
