2023-03-16 | Add pre-qualified constraintsqual-80 | Sebastian Huber | |
2023-03-16 | build: Exclude performance test if RTEMS_GCOV_COVERAGE | Sebastian Huber | |
2023-03-16 | build: Do not use coverage for librtemstest | Sebastian Huber | |
2023-03-16 | Doxygen: Adding Doxygen groups to files | Frank Kühndel | |
2023-03-16 | libc: Avoid dead code in memset() | Sebastian Huber | |
2023-03-16 | build fixme | Sebastian Huber | |
2023-03-16 | build: FIXME introduce pre-qualified parts | Sebastian Huber | |
2023-03-16 | bsp/leon3: Simplify shutdown | Sebastian Huber | |
Do not wait for other processors to halt. | |||
2023-03-16 | bsp/leon3: Add specialized target hash | Sebastian Huber | |
2023-03-16 | bsp/leon3: Fix group memberships | Sebastian Huber | |
Update #3706. | |||
2023-03-16 | bsps/sparc: Remove BSP_POWER_DOWN_AT_FATAL_HALT | Sebastian Huber | |
Remove the BSP_POWER_DOWN_AT_FATAL_HALT BSP option. Applications should do the customization of the system termination with an initial fatal extension. | |||
2023-03-16 | bsp/leon3: Enable up-counter conditionally | Sebastian Huber | |
2023-03-16 | bsp/leon3: Use LEON3_GPTIMER_BASE | Sebastian Huber | |
2023-03-16 | bsp/leon3: Add LEON3_IRQAMP_EXTENDED_INTERRUPT | Sebastian Huber | |
2023-03-16 | bsp/leon3: Add LEON3_PROBE_ASR_22_23_UP_COUNTER | Sebastian Huber | |
2023-03-16 | bsp/leon3: Simplify fatal error handling | Sebastian Huber | |
2023-03-16 | bsp/leon3: Move leon3_power_down_loop() | Sebastian Huber | |
2023-03-16 | bsp/leon3: Add LEON3_L2CACHE_BASE | Sebastian Huber | |
2023-03-16 | bsp/leon3: Add LEON3_HAS_ASR_22_23_UP_COUNTER | Sebastian Huber | |
2023-03-16 | bsp/leon3: Add LEON3_IRQAMP_PROBE_TIMESTAMP | Sebastian Huber | |
2023-03-16 | bsp/leon3: LEON3_PLB_FREQUENCY_DEFINED_BY_GPTIMER | Sebastian Huber | |
2023-03-16 | bsp/leon3: Add LEON3_IRQAMP_BASE | Sebastian Huber | |
2023-03-16 | bsp/leon3: Add LEON3_APBUART_BASE | Sebastian Huber | |
2023-03-16 | bsp/leon3: Add LEON3_GPTIMER_BASE | Sebastian Huber | |
2023-03-16 | bsp/leon3: Use new L2CACHE register block API | Sebastian Huber | |
2023-03-16 | bsp/leon3: Use new GPTIMER register block API | Sebastian Huber | |
2023-03-16 | bsp/leon3: Move up-counter support | Sebastian Huber | |
Move, document, and reformat support functions from <leon.h> to <bsp/leon3.h>. | |||
2023-03-16 | bsp/leon3: Move system control register support | Sebastian Huber | |
2023-03-16 | bsp/leon3: Use new IRQ(A)MP register block API | Sebastian Huber | |
2023-03-16 | bsps: Use new APBUART register block API | Sebastian Huber | |
2023-03-16 | bsp/leon3: Move and simplify bsp_irq_fixup() | Sebastian Huber | |
2023-03-16 | bsp/leon3: Untangle interrupt controller support | Sebastian Huber | |
Separate the probing of the interrupt controller from the initialization. | |||
2023-03-16 | validation: grlib | Sebastian Huber | |
2023-03-16 | bsps/grlib: Improve register bit field macros | Sebastian Huber | |
Close #4828. | |||
2023-03-16 | bsps/grlib: Expand SpaceWire port bit fields | Sebastian Huber | |
Use the maximum width supported by the SpaceWire standard even if this exceeds the configuration limits of a particular IP instance. Update #4842. | |||
2023-03-16 | bsps/grlib: Fix SpaceWire RMAP - Product ID | Sebastian Huber | |
Update #4842. | |||
2023-03-16 | bsps/grlib: Fix GRGPIO - IRQMAP bit fields | Sebastian Huber | |
Update #4842. | |||
2023-03-16 | bsps/grlib: Fix FTMCTRL - MCFG1 bit fields | Sebastian Huber | |
There was an off by one error in all bit fields. Add the R flag. Update #4842. | |||
2023-03-16 | bsps/grlib: Add generated headers | Sebastian Huber | |
2023-03-16 | validation: Add tests derived from models | Andrew Butterfield | |
2023-03-16 | membench: Add memory benchmark programs | Sebastian Huber | |
2023-03-16 | unit: Test unlimited objects configuration | Frank Kühndel | |
2023-03-16 | unit: Test POSIX-specific message queue impl | Frank Kühndel | |
2023-03-16 | validation: Test sparc/leon3 BSP family | Sebastian Huber | |
2023-03-16 | validation: Test memory allocation | Sebastian Huber | |
2023-03-16 | validation: Add MemorySave() and MemoryRestore() | Sebastian Huber | |
2023-03-16 | Replace Doxygen main page | Sebastian Huber | |
