2022-09-09 | Add pre-qualified constraintsqual-64 | Sebastian Huber | |
2022-09-09 | appl-config.h: Regenerate | Sebastian Huber | |
2022-09-09 | build: Exclude performance test if RTEMS_GCOV_COVERAGE | Sebastian Huber | |
2022-09-09 | build: Do not use coverage for librtemstest | Sebastian Huber | |
2022-09-09 | Doxygen: Adding Doxygen groups to files | Frank Kühndel | |
2022-09-09 | libc: Avoid dead code in memset() | Sebastian Huber | |
2022-09-09 | build fixme | Sebastian Huber | |
2022-09-09 | build: FIXME introduce pre-qualified parts | Sebastian Huber | |
2022-09-09 | bsp/leon3: Add specialized target hash | Sebastian Huber | |
2022-09-09 | bsp/leon3: Fix group memberships | Sebastian Huber | |
Update #3706. | |||
2022-09-09 | bsps/sparc: Remove BSP_POWER_DOWN_AT_FATAL_HALT | Sebastian Huber | |
Remove the BSP_POWER_DOWN_AT_FATAL_HALT BSP option. Applications should do the customization of the system termination with an initial fatal extension. | |||
2022-09-09 | bsp/leon3: Enable up-counter conditionally | Sebastian Huber | |
2022-09-09 | bsp/leon3: Use LEON3_GPTIMER_BASE | Sebastian Huber | |
2022-09-09 | bsp/leon3: Add LEON3_IRQAMP_EXTENDED_INTERRUPT | Sebastian Huber | |
2022-09-09 | bsp/leon3: Add LEON3_PROBE_ASR_22_23_UP_COUNTER | Sebastian Huber | |
2022-09-09 | bsp/leon3: Simplify fatal error handling | Sebastian Huber | |
2022-09-09 | bsp/leon3: Move leon3_power_down_loop() | Sebastian Huber | |
2022-09-09 | bsp/leon3: Add LEON3_L2CACHE_BASE | Sebastian Huber | |
2022-09-09 | bsp/leon3: Add LEON3_HAS_ASR_22_23_UP_COUNTER | Sebastian Huber | |
2022-09-09 | bsp/leon3: Add LEON3_IRQAMP_PROBE_TIMESTAMP | Sebastian Huber | |
2022-09-09 | bsp/leon3: LEON3_PLB_FREQUENCY_DEFINED_BY_GPTIMER | Sebastian Huber | |
2022-09-09 | bsp/leon3: Add LEON3_IRQAMP_BASE | Sebastian Huber | |
2022-09-09 | bsp/leon3: Add LEON3_GPTIMER_BASE | Sebastian Huber | |
2022-09-09 | bsp/leon3: Add LEON3_APBUART_BASE | Sebastian Huber | |
2022-09-09 | bsp/leon3: Use new L2CACHE register block API | Sebastian Huber | |
2022-09-09 | bsp/leon3: Use new GPTIMER register block API | Sebastian Huber | |
2022-09-09 | bsp/leon3: Move up-counter support | Sebastian Huber | |
Move, document, and reformat support functions from <leon.h> to <bsp/leon3.h>. | |||
2022-09-09 | bsp/leon3: Move system control register support | Sebastian Huber | |
2022-09-09 | bsp/leon3: Use new IRQ(A)MP register block API | Sebastian Huber | |
2022-09-09 | bsps: Use new APBUART register block API | Sebastian Huber | |
2022-09-09 | bsp/leon3: Move and simplify bsp_irq_fixup() | Sebastian Huber | |
2022-09-09 | bsp/leon3: Untangle interrupt controller support | Sebastian Huber | |
Separate the probing of the interrupt controller from the initialization. | |||
2022-09-09 | validation: grlib | Sebastian Huber | |
2022-09-09 | grlib: Add generated headers | Sebastian Huber | |
2022-09-09 | validation: Add tests derived from models | Andrew Butterfield | |
2022-09-09 | membench: Add memory benchmark programs | Sebastian Huber | |
2022-09-09 | unit: Test unlimited objects configuration | Frank Kühndel | |
2022-09-09 | unit: Test POSIX-specific message queue impl | Frank Kühndel | |
2022-09-09 | validation: Test sparc/leon3 BSP family | Sebastian Huber | |
2022-09-09 | validation: Test memory allocation | Sebastian Huber | |
2022-09-09 | validation: Add MemorySave() and MemoryRestore() | Sebastian Huber | |
2022-09-09 | cpukit/doxygen/appl-config.h | Sebastian Huber | |
2022-09-09 | Replace Doxygen main page | Sebastian Huber | |
2022-09-09 | build: Add RTEMS_CLANG_STATIC_ANALYZER option | Sebastian Huber | |
2022-09-09 | build: Install test executables | Sebastian Huber | |
2022-09-09 | build: Support conditional build dependencies | Sebastian Huber | |
2022-09-09 | Do not use RTEMS_INLINE_ROUTINE | Sebastian Huber | |
Directly use "static inline" which is available in C99 and later. This brings the RTEMS implementation closer to standard C. Close #3935. | |||
2022-09-09 | validation: Fix integer type warning | Sebastian Huber | |
Update #4662. |
