2022-08-01 | build: Exclude performance test if RTEMS_COVERAGEqual-59 | Sebastian Huber | |
2022-05-18 | build: Fix typo | Sebastian Huber | |
2022-05-18 | Doxygen: Adding Doxygen groups to files | Frank Kühndel | |
2022-05-18 | libc: Avoid dead code in memset() | Sebastian Huber | |
2022-05-18 | build: FIXME introduce pre-qualified parts | Sebastian Huber | |
2022-05-18 | bsp/leon3: Add specialized target hash | Sebastian Huber | |
2022-05-18 | bsp/leon3: Fix group memberships | Sebastian Huber | |
Update #3706. | |||
2022-05-18 | bsps/sparc: Remove BSP_POWER_DOWN_AT_FATAL_HALT | Sebastian Huber | |
Remove the BSP_POWER_DOWN_AT_FATAL_HALT BSP option. Applications should do the customization of the system termination with an initial fatal extension. | |||
2022-05-18 | bsp/leon3: Enable up-counter conditionally | Sebastian Huber | |
2022-05-18 | bsp/leon3: Use LEON3_GPTIMER_BASE | Sebastian Huber | |
2022-05-18 | bsp/leon3: Add LEON3_IRQAMP_EXTENDED_INTERRUPT | Sebastian Huber | |
2022-05-18 | bsp/leon3: Add LEON3_PROBE_ASR_22_23_UP_COUNTER | Sebastian Huber | |
2022-05-18 | bsp/leon3: Simplify fatal error handling | Sebastian Huber | |
2022-05-18 | bsp/leon3: Move leon3_power_down_loop() | Sebastian Huber | |
2022-05-18 | bsp/leon3: Add LEON3_L2CACHE_BASE | Sebastian Huber | |
2022-05-18 | bsp/leon3: Add LEON3_HAS_ASR_22_23_UP_COUNTER | Sebastian Huber | |
2022-05-18 | bsp/leon3: Add LEON3_IRQAMP_PROBE_TIMESTAMP | Sebastian Huber | |
2022-05-18 | bsp/leon3: LEON3_PLB_FREQUENCY_DEFINED_BY_GPTIMER | Sebastian Huber | |
2022-05-18 | bsp/leon3: Add LEON3_IRQAMP_BASE | Sebastian Huber | |
2022-05-18 | bsp/leon3: Add LEON3_GPTIMER_BASE | Sebastian Huber | |
2022-05-18 | bsp/leon3: Add LEON3_APBUART_BASE | Sebastian Huber | |
2022-05-18 | bsp/leon3: Use new L2CACHE register block API | Sebastian Huber | |
2022-05-18 | bsp/leon3: Use new GPTIMER register block API | Sebastian Huber | |
2022-05-18 | bsp/leon3: Move up-counter support | Sebastian Huber | |
Move, document, and reformat support functions from <leon.h> to <bsp/leon3.h>. | |||
2022-05-18 | bsp/leon3: Move system control register support | Sebastian Huber | |
2022-05-18 | bsp/leon3: Use new IRQ(A)MP register block API | Sebastian Huber | |
2022-05-18 | bsps: Use new APBUART register block API | Sebastian Huber | |
2022-05-18 | bsp/leon3: Move and simplify bsp_irq_fixup() | Sebastian Huber | |
2022-05-18 | bsp/leon3: Untangle interrupt controller support | Sebastian Huber | |
Separate the probing of the interrupt controller from the initialization. | |||
2022-05-18 | validation: grlib | Sebastian Huber | |
2022-05-18 | grlib: Add generated headers | Sebastian Huber | |
2022-05-18 | validation: Add tests derived from models | Andrew Butterfield | |
2022-05-18 | membench: Add memory benchmark programs | Sebastian Huber | |
2022-05-18 | unit: Test unlimited objects configuration | Frank Kühndel | |
2022-05-18 | unit: Test POSIX-specific message queue impl | Frank Kühndel | |
2022-05-18 | validation: Test sparc/leon3 BSP family | Sebastian Huber | |
2022-05-18 | validation: Test memory allocation | Sebastian Huber | |
2022-05-18 | validation: Add MemorySave() and MemoryRestore() | Sebastian Huber | |
2022-05-18 | Add not pre-qualified constraints | Sebastian Huber | |
2022-05-18 | cpukit/doxygen/appl-config.h | Sebastian Huber | |
2022-05-18 | Replace Doxygen main page | Sebastian Huber | |
2022-05-18 | build: Add RTEMS_CLANG_STATIC_ANALYZER option | Sebastian Huber | |
2022-05-18 | build: Install test executables | Sebastian Huber | |
2022-05-18 | build: Add RTEMS_COVERAGE support | Sebastian Huber | |
2022-05-18 | build: Add cflags to BuildItemContext | Sebastian Huber | |
2022-05-18 | build: Support conditional build dependencies | Sebastian Huber | |
2022-05-18 | build: Split includes | Sebastian Huber | |
2022-05-18 | score: Add SPDX License Identifier | Sebastian Huber | |
Remove URL in copyright notice. Update #3053. | |||
2022-05-18 | rtems: Relicense rtemsmaxprio.c | Sebastian Huber | |
Change license to BSD-2-Clause according to file history. Update #3053. | |||
2022-05-18 | bsps: Relicense <bsp/fatal.h> | Sebastian Huber | |
Add Doxygen documentation. Change license to BSD-2-Clause according to file history. Update #3053. |
