summaryrefslogtreecommitdiff
AgeCommit message (Collapse)Author
2021-12-22Doxygen: Adding Doxygen groups to filesqual-53Frank Kühndel
2021-12-22libc: Avoid dead code in memset()Sebastian Huber
2021-12-22build: FIXME introduce pre-qualified partsSebastian Huber
2021-12-22bsps/leon3: Fix group membershipsSebastian Huber
Update #3706.
2021-12-22spec/build/testsuites/validation/objgrlib.ymlSebastian Huber
2021-12-22bsps/include/grlib/irqamp.hSebastian Huber
2021-12-22bsps/sparc/include/grlib/io.hSebastian Huber
2021-12-22testsuites/validation/tc-dev-grlib-irqamp-get-timestamp.cSebastian Huber
2021-12-22validation: grlibSebastian Huber
2021-12-22bsps/sparc: Remove BSP_POWER_DOWN_AT_FATAL_HALTSebastian Huber
Remove the BSP_POWER_DOWN_AT_FATAL_HALT BSP option. Applications should do the customization of the system termination with an initial fatal extension.
2021-12-22bsp/leon3: Enable up-counter conditionallySebastian Huber
2021-12-22bsp/leon3: Use LEON3_GPTIMER_BASESebastian Huber
2021-12-22bsp/leon3: Add LEON3_IRQAMP_EXTENDED_INTERRUPTSebastian Huber
2021-12-22bsp/leon3: Add LEON3_PROBE_ASR_22_23_UP_COUNTERSebastian Huber
2021-12-22bsp/leon3: Simplify fatal error handlingSebastian Huber
2021-12-22bsp/leon3: Move leon3_power_down_loop()Sebastian Huber
2021-12-22bsp/leon3: Add LEON3_L2CACHE_BASESebastian Huber
2021-12-22bsp/leon3: Add LEON3_HAS_ASR_22_23_UP_COUNTERSebastian Huber
2021-12-22bsp/leon3: Add LEON3_IRQAMP_PROBE_TIMESTAMPSebastian Huber
2021-12-22bsp/leon3: LEON3_PLB_FREQUENCY_DEFINED_BY_GPTIMERSebastian Huber
2021-12-22bsp/leon3: Add LEON3_IRQAMP_BASESebastian Huber
2021-12-22bsp/leon3: Add LEON3_GPTIMER_BASESebastian Huber
2021-12-22bsp/leon3: Add LEON3_APBUART_BASESebastian Huber
2021-12-22bsp/leon3: Use new L2CACHE register block APISebastian Huber
2021-12-22bsp/leon3: Use new GPTIMER register block APISebastian Huber
2021-12-22bsp/leon3: Move up-counter supportSebastian Huber
Move, document, and reformat support functions from <leon.h> to <bsp/leon3.h>.
2021-12-22bsp/leon3: Move system control register supportSebastian Huber
2021-12-22bsp/leon3: Use new IRQ(A)MP register block APISebastian Huber
2021-12-22bsps: Use new APBUART register block APISebastian Huber
2021-12-22bsp/leon3: Move and simplify bsp_irq_fixup()Sebastian Huber
2021-12-22bsp/leon3: Untangle interrupt controller supportSebastian Huber
Separate the probing of the interrupt controller from the initialization.
2021-12-22bsps/sparc/include/dev/grlib/io.hSebastian Huber
2021-12-22grlib: Add generated headersSebastian Huber
2021-12-22validation: Add tests derived from modelsAndrew Butterfield
2021-12-22membench: Add memory benchmark programsSebastian Huber
2021-12-22unit: Test red-black treesSebastian Huber
2021-12-22unit: Test unlimited objects configurationFrank Kühndel
2021-12-22unit: Test POSIX-specific message queue implFrank Kühndel
2021-12-22unit: Add test for misaligned builtin memcpy()Sebastian Huber
2021-12-22unit: Add two unit test suitesSebastian Huber
2021-12-22validation: Test sparc/leon3 BSP familySebastian Huber
2021-12-22validation: Test memory allocationSebastian Huber
2021-12-22validation: Add MemorySave() and MemoryRestore()Sebastian Huber
2021-12-22Add not pre-qualified constraintsSebastian Huber
2021-12-22cpukit/doxygen/appl-config.hSebastian Huber
2021-12-22Replace Doxygen main pageSebastian Huber
2021-12-22build: Add RTEMS_CLANG_STATIC_ANALYZER optionSebastian Huber
2021-12-22build: Install test executablesSebastian Huber
2021-12-22build: Add cflags to BuildItemContextSebastian Huber
2021-12-22build: Substitute all includesSebastian Huber
