2021-08-19 | build: Support conditional build dependenciesqual-31 | Sebastian Huber | |
2021-08-17 | tx-support | Sebastian Huber | |
2021-08-17 | build FIXME | Sebastian Huber | |
2021-08-17 | validation: Test per-processor jobs order | Sebastian Huber | |
2021-08-17 | validation: Test rtems_status_text() | Sebastian Huber | |
2021-08-17 | validation: Test acfg option default values | Sebastian Huber | |
2021-08-17 | validation: Test thread-local storage | Sebastian Huber | |
2021-08-17 | testsuites/validation/tc-task-construct-errors.c | Sebastian Huber | |
2021-08-17 | validation: Test thread termination error | Sebastian Huber | |
2021-08-17 | validation: rtems_interrupt_entry_install() | Sebastian Huber | |
Check that the handler of the entries installed by rtems_interrupt_entry_install() are invoked in the right order. | |||
2021-08-17 | validation: Test user extensions | Sebastian Huber | |
2021-08-17 | validation: Test rate monotonic manager | Frank Kühndel | |
2021-08-17 | validation: Improve GetTestableInterruptVector() | Sebastian Huber | |
Add optional required attributes. | |||
2021-08-17 | validation: More SMP system initialization tests | Sebastian Huber | |
2021-08-17 | validation: Add second SMP-only test suite | Sebastian Huber | |
2021-08-17 | validation: Test system termination | Sebastian Huber | |
2021-08-17 | validation: Test SMP fatal errors | Sebastian Huber | |
2021-08-17 | validation: Test some fatal errors | Sebastian Huber | |
2021-08-17 | validation: Test kernel character I/O | Sebastian Huber | |
2021-08-17 | validation: Test cache manager directives | Sebastian Huber | |
2021-08-17 | validation: grlib | Sebastian Huber | |
2021-08-17 | validation: Test support directives | Sebastian Huber | |
2021-08-17 | validation: object services | Sebastian Huber | |
2021-08-17 | validation: Test status directives | Sebastian Huber | |
2021-08-17 | validation: Test bsp_interrupt_spurious() | Sebastian Huber | |
Update #3269 | |||
2021-08-17 | validation: Use unprotected chain directives | Sebastian Huber | |
2021-08-17 | validation: Use self suspend instead of exit | Sebastian Huber | |
This fixes errors in RtemsModelEventsMgr_Teardown(). | |||
2021-08-17 | build: Add tr-model-events-mgr-4.c | Sebastian Huber | |
2021-08-17 | Adds revised Event Mgr test files | abutterfield-ext | |
2021-08-17 | Adds working Chain API Tests | abutterfield-ext | |
2021-08-17 | Factors out common boilerplate and passes all tests | abutterfield-ext | |
2021-08-17 | validation: Increase stack size for -O0 | Sebastian Huber | |
2021-08-17 | validation: Test rtems_task_delete() | Sebastian Huber | |
2021-08-17 | validation: Test rtems_task_restart() | Sebastian Huber | |
2021-08-17 | validation: Test rtems_task_exit() | Sebastian Huber | |
2021-08-17 | validation: Test rtems_task_wake_when() | Sebastian Huber | |
2021-08-17 | validation: Test rtems_task_wake_after() | Sebastian Huber | |
2021-08-17 | validation: Test clock_nanosleep() | Sebastian Huber | |
2021-08-17 | validation: Code for timer server-fire-when test | Frank Kühndel | |
Adding tc-timer-server-fire-when.c to validation-2.yml | |||
2021-08-17 | validation: Code for timer server-fire-after test | Frank Kühndel | |
Adding tc-timer-server-fire-after.c to validation-2.yml | |||
2021-08-17 | validation: Code for timer fire_when tests | Frank Kühndel | |
This additional manual crafted code is needed to compile the timer manager tests for rtems_timer_fire_when(). validation-2.yml: Add the new test file. | |||
2021-08-17 | validation: Code for timer fire-after tests | Frank Kühndel | |
Adding tc-timer-fire-after.c to validation-2.yml. | |||
2021-08-17 | validation: Code for timer cancel & rests tests | Frank Kühndel | |
This additional manual crafted code is needed to compile the timer manager tests for rtems_timer_cancel() and rtems_timer_reset(). validation-2.yml: Add the new test files. testsuites/validation/tx-timer-server.c: New functions to permit tests to read RTEMS timer internal states. | |||
2021-08-17 | validation: Add task manager tests | Sebastian Huber | |
2021-08-17 | validation: Test scheduler manager directives | Sebastian Huber | |
2021-08-17 | validation: Add SMP-only and non-SMP test suites | Sebastian Huber | |
2021-08-17 | validation: Test memory allocation directives | Sebastian Huber | |
2021-08-17 | validation: Test rtems_timer_initiate_server() | Frank Kühndel | |
2021-08-17 | validation: Add tests for clock manager | Frank Kühndel | |
2021-08-17 | validation: Add a suite without a clock driver | Sebastian Huber | |
