2021-07-28 | cpukit/libtest/testbeginend.cqual-29 | Sebastian Huber | |
2021-07-28 | build fixme qual only | Sebastian Huber | |
2021-07-28 | cpukit/libtest/testbeginend.c | Sebastian Huber | |
2021-07-28 | apbuart | Sebastian Huber | |
2021-07-28 | validation: grlib | Sebastian Huber | |
2021-07-28 | use new APBUART | Sebastian Huber | |
2021-07-28 | validation: Test support directives | Sebastian Huber | |
2021-07-28 | testsuites/validation/tc-status | Sebastian Huber | |
2021-07-28 | testsuites/validation/tc-object.c | Sebastian Huber | |
2021-07-28 | testsuites/validation/tc-clock.c | Sebastian Huber | |
2021-07-28 | validation: object services | Sebastian Huber | |
2021-07-28 | validation: Test status directives | Sebastian Huber | |
2021-07-28 | Fix _IO_Dump_gcov_info() | Sebastian Huber | |
2021-07-28 | build: fixme qual | Sebastian Huber | |
2021-07-28 | cpukit/include/rtems/score/basedefs.h | Sebastian Huber | |
2021-07-28 | bsp/leon3: Move leon3_power_down_loop() | Sebastian Huber | |
2021-07-28 | bsp/leon3: Add LEON3_L2CACHE_BASE | Sebastian Huber | |
2021-07-28 | bsp/leon3: Add LEON3_HAS_ASR_22_23_UP_COUNTER | Sebastian Huber | |
2021-07-28 | bsp/leon3: Add LEON3_IRQAMP_PROBE_TIMESTAMP | Sebastian Huber | |
2021-07-28 | bsp/leon3: LEON3_PLB_FREQUENCY_DEFINED_BY_GPTIMER | Sebastian Huber | |
2021-07-28 | bsp/leon3: Add LEON3_IRQAMP_BASE | Sebastian Huber | |
2021-07-28 | bsp/leon3: Add LEON3_GPTIMER_BASE | Sebastian Huber | |
2021-07-28 | bsp/leon3: Add LEON3_APBUART_BASE | Sebastian Huber | |
2021-07-28 | bsp/leon3: Use new L2CACHE register block API | Sebastian Huber | |
2021-07-28 | bsp/leon3: Use new GPTIMER register block API | Sebastian Huber | |
2021-07-28 | bsp/leon3: Move up-counter support | Sebastian Huber | |
Move, document, and reformat support functions from <leon.h> to <bsp/leon3.h>. | |||
2021-07-28 | bsp/leon3: Move system control register support | Sebastian Huber | |
2021-07-28 | bsp/leon3: Use new IRQ(A)MP register block API | Sebastian Huber | |
2021-07-28 | bsps: Use new APBUART register block API | Sebastian Huber | |
2021-07-28 | bsp/leon3: Move and simplify bsp_irq_fixup() | Sebastian Huber | |
2021-07-28 | bsp/leon3: Untangle interrupt controller support | Sebastian Huber | |
Separate the probing of the interrupt controller from the initialization. | |||
2021-07-28 | bsps/sparc/include/dev/grlib/io.h | Sebastian Huber | |
2021-07-28 | validation: Add SetIOReleaxHandler() | Sebastian Huber | |
2021-07-28 | score: Add _IO_Relax() | Sebastian Huber | |
2021-07-28 | validation: Test bsp_interrupt_spurious() | Sebastian Huber | |
Update #3269 | |||
2021-07-28 | bsp/leon3: Do not invalidate cache in SMP start | Sebastian Huber | |
Since the trap table is now statically initialized, there is no need to invalidate the instruction cache. | |||
2021-07-28 | tm27.h | Sebastian Huber | |
2021-07-28 | bsp/leon3: Use interrupt entry directives | Sebastian Huber | |
2021-07-28 | FIXME libtest: Increase line length | Sebastian Huber | |
2021-07-28 | grlib: Add generated headers | Sebastian Huber | |
2021-07-28 | validation: Use unprotected chain directives | Sebastian Huber | |
2021-07-28 | validation: Use self suspend instead of exit | Sebastian Huber | |
This fixes errors in RtemsModelEventsMgr_Teardown(). | |||
2021-07-28 | build: Add tr-model-events-mgr-4.c | Sebastian Huber | |
2021-07-28 | Adds revised Event Mgr test files | abutterfield-ext | |
2021-07-28 | Adds working Chain API Tests | abutterfield-ext | |
2021-07-28 | Factors out common boilerplate and passes all tests | abutterfield-ext | |
2021-07-28 | validation: Increase stack size for -O0 | Sebastian Huber | |
2021-07-28 | validation: Test rtems_task_restart() | Sebastian Huber | |
