2021-03-10 | membench: Add memory benchmark programsqual-15 | Sebastian Huber | |
2021-03-09 | validation/ts-performance-0: Print samples | Sebastian Huber | |
2021-03-09 | Adds four test runner files, all work | Andrew Butterfield | |
2021-03-09 | Adds model-events-mgr test to model-0 testsuite | Andrew Butterfield | |
2021-03-09 | validation/ts-model-0: Add test suite | Sebastian Huber | |
2021-03-09 | FIXME ISR_LOCK_MEMBER() confuses Doxygen | Sebastian Huber | |
2021-03-09 | cpukit/include/rtems.h | Sebastian Huber | |
2021-03-09 | validation: Add tests for basedefs.h | Frank Kühndel | |
These are validation tests for cpukit/include/rtems/score/basedefs.h. tc-basedefs.c is automatically generated from the new verification item in rtems-central repository file spec/rtems/basedefs/val/basedefs.yml. These tests shall verify the requirements in spec/rtems/basedefs/req/*. The other two files are manually created. They are needed as some of the tests require items being defined in another compilation unit. Note: There are already unit test for basedefs.h in testsuites/sptests/spmisc01/init.c. | |||
2021-03-09 | validation: Add tests for Partition Manager | Sebastian Huber | |
2021-03-09 | validation: Add tests for task modes | Sebastian Huber | |
2021-03-09 | validation: Add tests for options | Sebastian Huber | |
2021-03-09 | validation: Add tests for attributes | Sebastian Huber | |
2021-03-09 | validation: Add tests for Event Manager | Sebastian Huber | |
2021-03-09 | validation: Add tests for object identification | Sebastian Huber | |
2021-03-09 | FIXME add runtime measurement test | Sebastian Huber | |
2021-03-09 | build: Add RTEMS_CLANG_STATIC_ANALYZER option | Sebastian Huber | |
2021-03-09 | build FIXME install test executables | Sebastian Huber | |
2021-03-09 | build FIXME No libc.a for pre-qualified only | Sebastian Huber | |
2021-03-09 | build: FIXME introduce pre-qualified parts | Sebastian Huber | |
2021-03-09 | validation: Add space profile testsuite | Sebastian Huber | |
2021-03-09 | build FIXME realview_pbx_a9 | Sebastian Huber | |
2021-03-09 | build mallocinitone leon3 | Sebastian Huber | |
2021-03-09 | libc: Optimize malloc() initialization | Sebastian Huber | |
Change licence to BSD-2-Clause according to file history. | |||
2021-03-09 | build wkspaceinitone leon3 | Sebastian Huber | |
2021-03-09 | score: Optimize Workspace Handler initialization | Sebastian Huber | |
2021-03-09 | build wkspace split | Sebastian Huber | |
2021-03-09 | score: Split wkspace.c | Sebastian Huber | |
2021-03-09 | wkspace.c: Change license to BSD-2-Clause | Sebastian Huber | |
Change licence according to file history. Update #3053. | |||
2021-03-09 | unit: Add test for misaligned builtin memcpy() | Sebastian Huber | |
2021-03-09 | testsuites: Add testsuite for unit tests | Sebastian Huber | |
2021-03-09 | rtems: Generate <rtems/rtems/tasks.h> | Sebastian Huber | |
Change license to BSD-2-Clause according to file histories and documentation re-licensing agreement. Update #3899. Update #3993. | |||
2021-03-09 | rtems: Generate <rtems/rtems/support.h> | Sebastian Huber | |
2021-03-09 | rtems: Generate <rtems/rtems/region.h> | Sebastian Huber | |
2021-03-09 | rtems: Generate <rtems/rtems/ratemon.h> | Sebastian Huber | |
2021-03-09 | rtems: Generate <rtems/rtems/mp.h> | Sebastian Huber | |
2021-03-09 | rtems: Generate <rtems/rtems/message.h> | Sebastian Huber | |
2021-03-09 | rtems: Generate <rtems/rtems/intr.h> | Sebastian Huber | |
2021-03-09 | rtems: Generate <rtems/rtems/dpmem.h> | Sebastian Huber | |
2021-03-09 | rtems: Generate <rtems/rtems/cache.h> | Sebastian Huber | |
2021-03-09 | rtems: Generate <rtems/init.h> | Sebastian Huber | |
2021-03-09 | rtems: Generate <rtems/fatal.h> | Sebastian Huber | |
2021-03-09 | rtems: Generate <rtems/extension.h> | Sebastian Huber | |
2021-03-09 | basedefs: Clarify RTEMS_STRING(), RTEMS_XSTRING() | Frank Kühndel | |
2021-03-09 | build: Fix broken link | Sebastian Huber | |
2021-03-08 | spec/aarch64: Enable previously disabled tests | Alex White | |
This enables several testsuites that were initially disabled during development. | |||
2021-03-08 | main_help.c: Unchecked return value from library (CID #1437650) | Ryan Long | |
CID 1437650: Unchecked return value from library in rtems_shell_help(). Closes #4291 | |||
2021-03-08 | pwdgrp.c: Fix Unchecked return value from library (CID #1255518) | Ryan Long | |
CID 1255518: Unchecked return value from library in pwdgrp_init(). Closes #4282 | |||
2021-03-08 | main_chmod.c: Fix Unchecked return value from library (CID #1063856) | Ryan Long | |
CID 1063856: Unchecked return value from library in rtems_shell_main_chmod(). Closes #4281 | |||
2021-03-08 | gen_uuid.c: Fix two Unchecked return value from library errors | Ryan Long | |
CID 1049146: Unchecked return value from library in get_clock(). CID 1049147: Unchecked return value from library in get_random_fd(). Closes #4280 | |||
2021-03-08 | main_edit.c: Fix Unchecked return value (CID #1255318) | Ryan Long | |
CID 1255318: Unchecked return value in display_line(). Updates #4257 |
