2011-03-31 | yaffs: More mainlining cleanup | Charles Manning | |
Signed-off-by: Charles Manning <cdhmanning@gmail.com> | |||
2011-02-01 | yaffs: Update year to 2011 in copyrights etc. | Charles Manning | |
2011-02-01 | yaffs: Clean up as per Ryan's comments | Charles Manning | |
Clean up a whole lot of code issues raised by Ryan. Some further reformatting etc to be mor kernel friendly. Signed-off-by: Charles Manning <cdhmanning@gmail.com> | |||
2011-01-13 | yaffs: Reformatting to be kernel friendly. | Charles Manning | |
Passes checkpatch.pl Signed-off-by: Charles Manning <cdhmanning@gmail.com> | |||
2010-11-30 | yaffs: Refactor bit counting code | Charles Manning | |
For Linux kernel we use hweight8() and hweight32(). This allows use of special bit-counting code instructions in processors that do this. The yaffs direct we now only use one set of code. There were two. NB On x86 the yaffs hweight8 code is actually a lot faster than the sofwtare implementation in Linux kernel. Signed-off-by: Charles Manning <cdhmanning@gmail.com> | |||
2010-11-03 | yaffs: Redo Lindent | Charles Manning | |
Only applies to Linux files. Signed-off-by: Charles Manning <cdhmanning@gmail.com> | |||
2010-11-02 | yaffs: More clean up | Charles Manning | |
2010-10-27 | yaffs Further name changes and file reorganisation | Charles Manning | |
2010-10-07 | yaffs Make more symbol changes | Charles Manning | |
2010-10-07 | yaffs First round of name changes | Charles Manning | |
2010-04-27 | yaffs Some cleanups. | Charles Manning | |
Update copyright messages. Clean up tracing to use TSTR and KERN_DEBUG. Remove cvs $Id. Change /proc/yaffs_debug to /proc/yaffs_stats. ... and a few other clean ups. Signed-off-by: Charles Manning <cdhmanning@gmail.com> | |||
2009-03-06 | Major whitespace/style changes to match Linux checkpatch.pl code style | wookey | |
2007-12-13 | Cleanup patch - Remove all trailing whitespace and fix a few typos. | wookey | |
2007-02-14 | Updated headers so they really are the same | wookey | |
2007-02-12 | normalise licence headers and attributions | wookey | |
2006-09-14 | Bounds check on ecc correction | charles | |
2005-08-11 | *** empty log message *** | charles | |
2005-08-11 | Lindent | charles | |
2005-07-31 | Replace linux/config.h with yportenv.h and remove some dead code | charles | |
2005-07-29 | Add missing #include <linux/config.h> | luc | |
Needed to compile the code with a Makefile from the Linux tree. | |||
2005-03-16 | Add patches from Nick Banes for compatability | charles | |
2004-11-03 | *** empty log message *** | charles | |
