2020-09-16 | spec: Group items by component | Sebastian Huber | |
2020-08-06 | spec: Improve references in appl config options | Sebastian Huber | |
2020-07-07 | spec: Use ${...} references in /if/acfg/* | Sebastian Huber | |
This allows generation of Sphinx and Doxygen output. | |||
2020-07-07 | spec: Move application configuration items | Sebastian Huber | |
2020-07-03 | spec: Allow dual licensing | Sebastian Huber | |
The items have the following copyright statements: * Copyright (C) 2019, 2020 embedded brains GmbH (http://www.embedded-brains.de) * Copyright (C) 2010 Gedare Bloom * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR) The copyright holders agreed to the relicensing according to this ticket: https://devel.rtems.org/ticket/3899 | |||
2020-05-28 | Rename custom constraints attribute | Sebastian Huber | |
Uses "texts" to be in line with the "text" attribute of constraint items. | |||
2020-05-28 | Rename application configuration attributes | Sebastian Huber | |
2020-05-28 | spec: Add appl-config-group-member link role | Sebastian Huber | |
2020-05-28 | Change format of enabled-by attribute | Sebastian Huber | |
2020-04-21 | Remove Doorstop specifics | Sebastian Huber | |
2020-04-01 | spec: Clarify config options use | Sebastian Huber | |
2020-04-01 | spec: Use null if no notes are present | Sebastian Huber | |
2020-03-31 | spec: Add undocumented configuration options | Sebastian Huber | |
