2020-09-16 | spec: Group items by component | Sebastian Huber | |
2020-08-06 | spec: Improve references in appl config options | Sebastian Huber | |
2020-07-07 | spec: Move application configuration items | Sebastian Huber | |
2020-07-03 | spec: Allow dual licensing | Sebastian Huber | |
The items have the following copyright statements: * Copyright (C) 2019, 2020 embedded brains GmbH (http://www.embedded-brains.de) * Copyright (C) 2010 Gedare Bloom * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR) The copyright holders agreed to the relicensing according to this ticket: https://devel.rtems.org/ticket/3899 | |||
2020-05-28 | spec: Add dedicated constraint items | Sebastian Huber | |
2020-05-28 | spec: Add rationale attribute to requirements | Sebastian Huber | |
2020-05-28 | spec: Make constraints non-functional requirements | Sebastian Huber | |
2020-05-28 | Change format of enabled-by attribute | Sebastian Huber | |
2020-04-21 | Remove Doorstop specifics | Sebastian Huber | |
2020-03-30 | spec: Use constraint links | Sebastian Huber | |
