In the current version of libbsd, if the --show-commands option is used,
the cwd is passed as a Nod3. Popen does not work with that. Therefore
create a string from cwd if it isn't already.
If the --show-commands is set, the cmd-string is joined for printing.
This breaks a later Popen call that expects an array instead of an fully
assembled string. This patch fixes the problem.
To use add to your wscript file:
rtems.root_filesystem(bld, 'rootfs',
['etc/rc.conf'],
'rootfs.tar', 'rootfs-tar.o')
to create a rootfs-tar.o which you add to your executable's list of
sources.
In your main or Init function add:
#include <rtems/untar.h>
extern int _binary_rootfs_tar_start;
extern int _binary_rootfs_tar_size;
static void expand_rootfs_tarfile(void)
rtems_status_code sc;
rtems_printer printer;
rtems_print_printer_printf(&printer);
sc = Untar_FromMemory_Print((void *)(&_binary_rootfs_tar_start),
(size_t)&_binary_rootfs_tar_size,
&printer);
if (sc != RTEMS_SUCCESSFUL)
fprintf(stderr, "error: untar failed: %s\n", rtems_status_text(sc));
Note, some arch's may not need the '_' at the start of the tar symbols.
message.
Allow an application the ability to set a version number for RTEMS. This avoids
issues with the automatic detection code. It means an application becomes keyed
to a specific version of RTEMS.
Check the environment for variables being set that could effect a build. We
allow the environment to do this but it can have a side effect such as CC being
set for one architecture and the rtems_waf being asked to use another.
Print the version of CC being used. This is a diagnostic.
Now the configuration is quite simple for standard installations, e.g.
waf configure --prefix=/opt/rtems-4.12 --rtems-bsps=sparc/sis
Close #2440.
Set mandatory C++ standard option in case SMP is enabled.
Close #2418.
The handler is called with the BSP environment set up so the
user can perform various checks.
