Add a feature to enforce an explicit target file for assembler sources.
Add a build start file node list and use it as a test program
dependency.
The fix for #3846 and #4080 needs to be combined, because the fix
for #3846 requires the removal of 'before=["cstlib"]'. This patch fixes
two issues:
1. The tracking of start file dependencies.
2. Reflect that executables depend on the start files.
We need a start.o file in the right path so that the linker can find is
as specified by the linker script, and not for example a start.S.17.o
file in some path. This part is addressed by the "explicit_asm_target"
feature.
This build process extension
@after("apply_link")
@feature("cprogram", "cxxprogram")
def process_start_files(self):
if getattr(self, "start_files", False):
self.link_task.dep_nodes.extend(self.bld.start_files)
addresses 2.
Close #3846.
Close #4080.
