The variety of expected test states are not currently applied to tests
with names containing '-' correctly due to a failure to replace '-' with
'_' before adding the CPPFLAGS to the environment for that test. This
ensures that all additions of CPPFLAGS have that replacement performed
so that the CPPFLAGS are applied properly during compilation.
The "bsp_list" and "bsp_defaults" commands get a waflib.Context object
which has no build node. Use a hard coded build path for these
commands.
This improves support for the --out option. Previously, the cache file
was placed in the source directory under "build/...". Now, it is placed
in the output directory, which is "build" by default. So, if you don't
use the --out option nothing changes. However, if you use the --out
option, then the cache file is placed under the specified directory.
Check the directory modification time to notice file removals.
The ctx.fatal() method uses an exception to stop the build. Do not
catch it.
Update #3818.
Update #3818.
For the option default values we have to use the BSP name defined by the build
specification and not the user.
Update #3818.
For the enabled-by evaluation we have to use the BSP name defined by the
build specification and not the user.
Update #3818.
Update #3818.
Update #3818.
Add a feature to enforce an explicit target file for assembler sources.
Add a build start file node list and use it as a test program
dependency.
The fix for #3846 and #4080 needs to be combined, because the fix
for #3846 requires the removal of 'before=["cstlib"]'. This patch fixes
two issues:
1. The tracking of start file dependencies.
2. Reflect that executables depend on the start files.
We need a start.o file in the right path so that the linker can find is
as specified by the linker script, and not for example a start.S.17.o
file in some path. This part is addressed by the "explicit_asm_target"
feature.
This build process extension
@after("apply_link")
@feature("cprogram", "cxxprogram")
def process_start_files(self):
if getattr(self, "start_files", False):
self.link_task.dep_nodes.extend(self.bld.start_files)
addresses 2.
Close #3846.
Close #4080.
This patch is for the new build system.
Update #3818.
