path: root/wscript (follow)
* build: Bring Item.link() in line with waf linkSebastian Huber2021-07-261-1/+1
| | | | | The LDFLAGS are placed after the static libraries in the standard waf link command, see "waflib/Tools/c.py" in the waf sources.
* build: Add "bsps/" prefix to BSP family enableSebastian Huber2021-07-221-1/+1
| | | | | BSP family and BSP variant names may be equal. This prefix avoids ambiguity in the enabled-by expressions.
* build: Use objects of build context for programsSebastian Huber2021-07-151-1/+1
* build: Add the BSP family to the enable setSebastian Huber2021-07-151-1/+6
| | | | | This makes it possible to use the BSP family in expressions of the enabled-by attribute.
* build: Fix formatSebastian Huber2021-07-151-1/+1
* build: Prefer variant default value over familySebastian Huber2021-07-151-4/+4
| | | | Update #4468.
* build: Fix bsp_defaults commandSebastian Huber2021-07-151-6/+8
| | | | Update #4468.
* build: Use BSP family for optionsChris Johns2021-07-151-13/+21
| | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468
* build: Fix format in wscriptSebastian Huber2021-02-231-1/+3
* build: Add CPPFLAGS to assembler command lineSebastian Huber2021-01-261-0/+1
| | | | | We use GCC to call the assembler. This means the assembler files are processed by the C preprocessor.
* build: Add ABI flags to gnatmake compiler flagsSebastian Huber2020-12-161-0/+2
* wscript: Apply test state expectations correctlyKinsey Moore2020-11-241-1/+1
| | | | | | | | The variety of expected test states are not currently applied to tests with names containing '-' correctly due to a failure to replace '-' with '_' before adding the CPPFLAGS to the environment for that test. This ensures that all additions of CPPFLAGS have that replacement performed so that the CPPFLAGS are applied properly during compilation.
* build: Fix cache file placementSebastian Huber2020-11-121-3/+5
| | | | | | The "bsp_list" and "bsp_defaults" commands get a waflib.Context object which has no build node. Use a hard coded build path for these commands.
* build: Place cache file in output directorySebastian Huber2020-11-051-2/+2
| | | | | | | | This improves support for the --out option. Previously, the cache file was placed in the source directory under "build/...". Now, it is placed in the output directory, which is "build" by default. So, if you don't use the --out option nothing changes. However, if you use the --out option, then the cache file is placed under the specified directory.
* build: Improve cache handlingSebastian Huber2020-10-281-1/+4
| | | | Check the directory modification time to notice file removals.
* build: Report caching errorsSebastian Huber2020-10-281-1/+1
| | | | | The ctx.fatal() method uses an exception to stop the build. Do not catch it.
* build: Use exact match by default for BSP namesSebastian Huber2020-10-021-2/+2
| | | | Update #3818.
* build: Add commentSebastian Huber2020-09-281-0/+4
| | | | Update #3818.
* build: Fix option default valuesSebastian Huber2020-09-271-3/+4
| | | | | | | For the option default values we have to use the BSP name defined by the build specification and not the user. Update #3818.
* build: Fix enabled-by evaluationSebastian Huber2020-09-271-1/+2
| | | | | | | For the enabled-by evaluation we have to use the BSP name defined by the build specification and not the user. Update #3818.
* build: Simplify get_compiler()Sebastian Huber2020-09-271-2/+2
| | | | Update #3818.
* build: Allow test program item UIDs with a "-"Sebastian Huber2020-09-171-2/+4
| | | | Update #3818.
* build: Fix dependencies for start and asm filesSebastian Huber2020-09-171-7/+38
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Add a feature to enforce an explicit target file for assembler sources. Add a build start file node list and use it as a test program dependency. The fix for #3846 and #4080 needs to be combined, because the fix for #3846 requires the removal of 'before=["cstlib"]'. This patch fixes two issues: 1. The tracking of start file dependencies. 2. Reflect that executables depend on the start files. We need a start.o file in the right path so that the linker can find is as specified by the linker script, and not for example a start.S.17.o file in some path. This part is addressed by the "explicit_asm_target" feature. This build process extension @after("apply_link") @feature("cprogram", "cxxprogram") def process_start_files(self): if getattr(self, "start_files", False): self.link_task.dep_nodes.extend(self.bld.start_files) addresses 2. Close #3846. Close #4080.
* build: Use Python tarfile instead of paxSebastian Huber2020-09-141-13/+14
| | | | This patch is for the new build system.
* build: Alternative build system based on wafSebastian Huber2020-09-141-0/+1531
Update #3818.
