Closes #2867.
Change the testsuite configuration files to hold state information about
a test. The states are:
exclude - Do not build the test
expected-fail - The test is expected to fail
indeterminate - The test may pass or may fail
A message is printed just after the test's BEGIN message to indicate
there is a special state for the test. No state message means the test
is expected to pass.
This support requires tests are correctly written to the use standard
support to begin and end a test.
This was a no-install binary apparently unused.
Update #2730.
Updates #2405.
Updates #2405.
Update #2238.
Close #2240.
This code is built without warnings and ignored by Coverity Scan.
CodeSonar found a wide range of issues including buffer overruns,
buffer underruns, questionable type conversions, leaks, etc. This
set of patches addresses all reported issues.
The waf converter in examples-v2 uses an absolute path and this
creates defines with invalid characters.
BSPs for simulators which do not include a clock tick interrupt source
are incapable of running some tests successfully. This is a common
characteristic of some BSPs and a fixed set of tests. There is no point
in duplicating this list of tests in those BSPs test configuration.
Read testsuites/testdata/require-tick-isr.tcfg for details.
Provide a file per BSP to list tests that do not build for a BSP. This change
removes the BSP_SMALL_MEMORY hack from the code. That hack was a
mistake.
Provide configuration files for each BSP with tests that cannot build.
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
for details.
* config.h.in: Regenerated.
tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c,
tools/build/cklength.c, tools/build/config.h.in,
tools/build/configure.ac, tools/build/cvsignore-add.sh,
tools/build/doxy-filter, tools/build/eolstrip.c,
tools/build/install-if-change.in, tools/build/multigen,
tools/build/packhex.c, tools/build/rtems-bin2c.c,
tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore,
tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac,
tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog,
tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac,
tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore,
tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am,
tools/cpu/nios2/README, tools/cpu/nios2/bridges.c,
tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c,
tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac,
tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h,
tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h,
tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h,
tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c,
tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c,
tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf,
tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING,
tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO,
tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h,
tools/cpu/sh/shgen.c: New files.
* tools/build/.cvsignore, tools/build/ChangeLog,
tools/build/cklength.c, tools/build/configure.ac,
tools/build/cvsignore-add.sh, tools/build/doxy-filter,
tools/build/eolstrip.c, tools/build/install-if-change.in,
tools/build/multigen, tools/build/packhex.c,
tools/build/rtems-bin2c.c, tools/build/search-id.sh,
tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog,
tools/cpu/sh/shgen.c, tools/schedsim/.cvsignore,
tools/schedsim/ChangeLog, tools/schedsim/Makefile.am,
tools/schedsim/README, tools/schedsim/configure.ac,
tools/schedsim/rtems/.cvsignore, tools/schedsim/rtems/ChangeLog,
tools/schedsim/rtems/Makefile.am, tools/schedsim/rtems/interr.c,
tools/schedsim/rtems/rtems_init.c,
tools/schedsim/rtems/rtems_sched.h, tools/schedsim/rtems/wkspace.c,
tools/schedsim/rtems/sched_cpu/cpu.c,
tools/schedsim/rtems/sched_cpu/cpu_asm.c,
tools/schedsim/rtems/sched_cpu/rtems/asm.h,
tools/schedsim/rtems/sched_cpu/rtems/stringto.h,
tools/schedsim/rtems/sched_cpu/rtems/score/cpu.h,
tools/schedsim/rtems/sched_cpu/rtems/score/cpu_asm.h,
tools/schedsim/rtems/sched_cpu/rtems/score/cpuopts.h,
tools/schedsim/rtems/sched_cpu/rtems/score/no_cpu.h,
tools/schedsim/rtems/sched_cpu/rtems/score/types.h,
tools/schedsim/shell/.cvsignore, tools/schedsim/shell/ChangeLog,
tools/schedsim/shell/Makefile.am,
tools/schedsim/shell/schedsim_priority/.cvsignore,
tools/schedsim/shell/schedsim_priority/Makefile.am,
tools/schedsim/shell/schedsim_priority/config.c,
tools/schedsim/shell/schedsim_priority/printheir_executing.c,
tools/schedsim/shell/schedsim_priority/schedsim.cc,
tools/schedsim/shell/schedsim_priority/wrap_thread_dispatch.c,
tools/schedsim/shell/scripts/script01,
tools/schedsim/shell/scripts/script02,
tools/schedsim/shell/scripts/script03,
tools/schedsim/shell/scripts/script04,
tools/schedsim/shell/scripts/script05,
tools/schedsim/shell/scripts/script06,
tools/schedsim/shell/shared/.cvsignore,
tools/schedsim/shell/shared/Makefile.am,
tools/schedsim/shell/shared/commands.c,
tools/schedsim/shell/shared/getopt.c,
tools/schedsim/shell/shared/lookup_semaphore.c,
tools/schedsim/shell/shared/lookup_task.c,
tools/schedsim/shell/shared/main_clocktick.c,
tools/schedsim/shell/shared/main_echo.c,
tools/schedsim/shell/shared/main_executing.c,
tools/schedsim/shell/shared/main_heir.c,
tools/schedsim/shell/shared/main_help.c,
tools/schedsim/shell/shared/main_rtemsinit.c,
tools/schedsim/shell/shared/main_semcreate.c,
tools/schedsim/shell/shared/main_semdelete.c,
tools/schedsim/shell/shared/main_semflush.c,
tools/schedsim/shell/shared/main_semobtain.c,
tools/schedsim/shell/shared/main_semrelease.c,
tools/schedsim/shell/shared/main_taskcreate.c,
tools/schedsim/shell/shared/main_taskdelete.c,
tools/schedsim/shell/shared/main_taskmode.c,
tools/schedsim/shell/shared/main_taskpriority.c,
tools/schedsim/shell/shared/main_taskresume.c,
tools/schedsim/shell/shared/main_tasksuspend.c,
tools/schedsim/shell/shared/main_taskwakeafter.c,
tools/schedsim/shell/shared/schedsim_shell.h,
tools/schedsim/shell/shared/shell_cmdset.c,
tools/schedsim/shell/shared/shell_makeargs.c,
tools/schedsim/shell/shared/include/shell.h,
tools/schedsim/shell/shared/include/newlib/_ansi.h,
tools/schedsim/shell/shared/include/newlib/getopt.h: Removed.
* configure.ac: RTEMS Scheduler Simulator is now in its own CVS module
named rtems-schedsim.
* rtems/interr.c: Minimize diffs to cpukit/score/src/interr.c.
* rtems/sched_cpu/rtems/score/cpu.h:
Incorporate parts of former posix BSP.
PR 1777/cpukit
* tools/schedsim/rtems/rtems_init.c: Consolidated access to
_Thread_Dispatch_disable_level.
* Makefile.am: Add schedulersimple.h
* README: New file.
* shared/main_clocktick.c, shared/main_semcreate.c,
shared/main_semdelete.c, shared/main_semflush.c,
shared/main_semobtain.c, shared/main_semrelease.c,
shared/main_taskcreate.c, shared/main_taskdelete.c,
shared/main_taskmode.c, shared/main_taskpriority.c,
shared/main_taskresume.c, shared/main_tasksuspend.c,
shared/main_taskwakeafter.c, shared/schedsim_shell.h: Compiles now
and do not core dump when RTEMS is not initialized.
* Makefile.am, wkspace.c: Compiles now and do not core dump when RTEMS
is not initialized.
* sched_cpu/rtems/score/cpuopts.h: Bump to 4.10.99.0
* configure.ac: Remove RTEMS_PATH_KSH (Unused).
Require autoconf >= 2.68, automake >= 1.11.1.
Add AC_PROG_CC_C99 to enforce c99 hoping this will suffice to make
this stuff compilable with older GCCs (works on some hosts).
Jennifer Averett <jennifer.averett@oarcorp.com>
Add RTEMS Scheduler Simulator. This is the top level of the tree.
* .cvsignore, ChangeLog, Makefile.am, configure.ac: New files.
* .cvsignore: New file.
Add RTEMS Scheduler Simulator. This is the RTEMS "port" to and
adapter code to run on GNU/Linux with a fake context switch.
* ChangeLog, Makefile.am, interr.c, rtems_init.c, rtems_sched.h,
wkspace.c, sched_cpu/cpu.c, sched_cpu/cpu_asm.c,
sched_cpu/rtems/asm.h, sched_cpu/rtems/stringto.h,
sched_cpu/rtems/score/cpu.h, sched_cpu/rtems/score/cpu_asm.h,
sched_cpu/rtems/score/cpuopts.h, sched_cpu/rtems/score/no_cpu.h,
sched_cpu/rtems/score/types.h: New files.
Add RTEMS Scheduler Simulator. This is the shell scripting portion.
* .cvsignore, ChangeLog, Makefile.am, schedsim_priority/.cvsignore,
schedsim_priority/Makefile.am, schedsim_priority/config.c,
schedsim_priority/wrap_thread_dispatch.c, scripts/script01,
scripts/script02, scripts/script03, scripts/script04,
scripts/script05, scripts/script06, shared/.cvsignore,
shared/Makefile.am, shared/commands.c, shared/getopt.c,
shared/lookup_semaphore.c, shared/lookup_task.c,
shared/main_clocktick.c, shared/main_echo.c, shared/main_executing.c,
shared/main_heir.c, shared/main_help.c, shared/main_rtemsinit.c,
shared/main_semcreate.c, shared/main_semdelete.c,
shared/main_semflush.c, shared/main_semobtain.c,
shared/main_semrelease.c, shared/main_taskcreate.c,
shared/main_taskdelete.c, shared/main_taskmode.c,
shared/main_taskpriority.c, shared/main_taskresume.c,
shared/main_tasksuspend.c, shared/main_taskwakeafter.c,
shared/schedsim_shell.h, shared/shell_cmdset.c,
shared/shell_makeargs.c, shared/include/shell.h,
shared/include/newlib/_ansi.h, shared/include/newlib/getopt.h: New
files.
