* | 2010-07-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-07-30 | 2 | -2/+11 |
| | | | | | * rtems-bin2c.c: Fix memory leak in '.c' suffix strip. Also strip '.h' suffix. | ||||
* | 2010-07-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-07-30 | 2 | -1/+5 |
| | | | | * rtems-bin2c.c: Make -v (verbose) working. | ||||
* | 2010-07-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-07-30 | 3 | -13/+15 |
| | | | | | | * configure.ac: Check for libgen.h, basename. * rtems-bin2c.c: Use basename(3) instead of strrchr cascade. Introduce ifbasename. Use ifbasename in generated files. | ||||
* | 2010-07-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-07-29 | 2 | -7/+34 |
| | | | | * rtems-bin2c.c: Add -C and -H options. | ||||
* | 2010-03-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-03-12 | 2 | -1/+7 |
| | | | | | | * eolstrip.c: Readdress use of ctype methods per recommendation from D.J. Delorie on the newlib mailing list. We should pass an unsigned char into these methods. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-12-10 | 1 | -2/+2 |
* | Whitespace removal. | Ralf Corsepius | 2009-12-10 | 11 | -44/+44 |
* | 2007-09-18 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-09-18 | 2 | -2/+6 |
| | | | | * Makefile.am: Rename bin2c to rtems-bin2c. | ||||
* | 2007-09-10 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-09-10 | 2 | -3/+9 |
| | | | | * bin2c.c: Updated license after author changed it. | ||||
* | 2007-09-07 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-09-07 | 2 | -4/+12 |
| | | | | * bin2c.c: Update comments. | ||||
* | 2007-09-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-09-04 | 2 | -81/+241 |
| | | | | | | * bin2c.c: Significant improvements -- add multiple options, generate both C and H files, do not always generate static. fix indentation, add comments. | ||||
* | 2007-09-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-09-04 | 2 | -0/+113 |
| | | | | | * bin2c.c: New file. http://www.wxwidgets.org/wiki/index.php/Embedding_PNG_Images-Bin2c_In_C | ||||
* | 2007-09-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-09-04 | 2 | -1/+8 |
| | | | | | | * Makefile.am: Add bin2c so we can have a more reliable way to convert binary files to objects. If they are in C, we can use the correct CPU CFLAGS and they will link easier. | ||||
* | Fix indentation. | Ralf Corsepius | 2007-01-27 | 1 | -7/+7 |
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 10 | -5/+25 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 10 | -10/+30 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2006-08-15 Kolja Waschk <kawk@telos.de> | Joel Sherrill | 2006-08-15 | 15 | -115/+1283 |
| | | | | | | | | | | | | | | * linkcmds.c, linkcmds.h, memory.c, memory.h, sample.ptf: New files. * bridges.c: corrected detection of bridged connections * clocks.c: removed a printf * linkcmds.[ch] new files, added output of linker script * Makefile.am: added new files * memory.[ch]: new files, detection of memory in SOPC configuration * nios2gen.c: updated command line parsing and output control * output.[ch]: improved output of BSP header file * ptf.[ch]: added ptf_dump_ptf_item and small fixes * sample.ptf: new file, sample configuration for nios2gen * README: updated | ||||
* | 2006-08-10 Joel Sherrill <joel@oarcorp.com> | Joel Sherrill | 2006-08-10 | 2 | -3/+37 |
| | | | | | | | | * nios2gen.c: Added some very basic support for --help and --version options along with output that is roughly in GNU format. This is required by help2man. help2man expects this all to be written to stdout instead of stderr so this was changed as well. * ChangeLog: New file. | ||||
* | 2006-08-09 Kolja Waschk <waschk@telos.de> | Joel Sherrill | 2006-08-09 | 17 | -0/+1837 |
| | | | | | | | | * configure.ac: New port to Altera NIOS II. * nios2/.cvsignore, nios2/Makefile.am, nios2/README, nios2/bridges.c, nios2/bridges.h, nios2/clocks.c, nios2/clocks.h, nios2/configure.ac, nios2/devices.c, nios2/devices.h, nios2/nios2gen.c, nios2/output.c, nios2/output.h, nios2/ptf.c, nios2/ptf.h: New files. | ||||
* | 2006-07-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-07-13 | 3 | -0/+29 |
| | | | | | * doxy-filter: New. * Makefile.am: Add doxy-filter. | ||||
* | Remove. | Ralf Corsepius | 2006-07-11 | 1 | -275/+0 |
* | 2006-07-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-07-11 | 3 | -7/+10 |
| | | | | | | * ampolish3.in: Remove. * Makefile.am: Remove ampolish3. * configure.ac: Remove ampolish3, perl. | ||||
* | 2006-01-31 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-31 | 2 | -1/+6 |
| | | | | * shgen.c: include <stdlib.h>. | ||||
* | 2006-10-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-14 | 2 | -2/+7 |
| | | | | | * ampolish3.in: Check Makefile.am for SUBDIRS. Add all-am: for PREINSTALL_FILES. | ||||
* | 2006-10-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 2 | -10/+24 |
| | | | | | | * ampolish3.in: Add all: for PREINSTALL_FILES. Add all-local for TMPINSTALL_FILES. Misc bug fixes. | ||||
* | 2006-10-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 2 | -3/+26 |
| | | | | | * ampolish3.in: Check if Makefile.am already contains CLEANFILES or DISTCLEANFILES. | ||||
* | 2006-10-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 2 | -100/+110 |
| | | | | * ampolish3.im: Update. | ||||
* | 2005-10-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-25 | 2 | -2/+6 |
| | | | | * ampolish3.in: Sync with private bleeding-edge . | ||||
* | 2005-10-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-24 | 2 | -2/+6 |
| | | | | * ampolish3.in: Use @PERL@, partial update from local sources. | ||||
* | Fix typo | Ralf Corsepius | 2005-10-24 | 1 | -1/+1 |
* | 2005-10-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-24 | 3 | -4/+12 |
| | | | | | | * configure.ac: Add ampolish3. * Makefile.am: Add ampolish3. * ampolish3.in: New. | ||||
* | New. | Ralf Corsepius | 2005-10-24 | 1 | -0/+243 |
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 4 | -4/+4 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 8 | -4/+20 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | 2004-09-24 Ralf Corsepius <ralf_corsepiu@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+7 |
| | | | | * configure.ac: Remove RTEMS_CPU_SUBDIRS. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-20 | 5 | -35/+35 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 |
* | Unused. | Ralf Corsepius | 2004-03-09 | 1 | -2/+0 |
* | 2004-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-20 | 2 | -0/+6 |
| | | | | | * Makefile.am: Add EXTRA_DIST = search-id.sh multigen cvsignore-add.sh. | ||||
* | 2004-02-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-04 | 2 | -1/+5 |
| | | | | * Makefile.am: DIST_SUBDIRS = @subdirs@. | ||||
* | 2004-01-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-06 | 2 | -1/+5 |
| | | | | * Makefile.am: Let shgen.1 depend on shgen$(EXEEXT). | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 8 | -8/+24 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -0/+5 |
| | | | | * Makefile.am: Cosmetics. | ||||
* | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-26 | 2 | -1/+5 |
| | | | | * Makefile.am: Obsoleting HP PA-RISC port. | ||||
* | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-26 | 6 | -463/+5 |
| | | | | | * hppa1.1/.cvsignore, hppa1.1/ChangeLog, hppa1.1/Makefile.am, hppa1.1/configure.ac, hppa1.1/genoffsets.c: Removed. | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 2 | -2/+6 |
| | | | | * genoffsets.c: URL for license changed. | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 2 | -1/+5 |
| | | | | * size_rtems.in: URL for license changed. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 10 | -5/+25 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-25 | 13 | -2581/+0 |
