path: root/tools (follow)
* unhex.c: Remove unnecessary extern of errnoJoel Sherrill2018-02-191-2/+0
| | | | Closes #2610.
* Remove make preinstallChris Johns2018-01-255-0/+10
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254.
* testsuite: Fix rtems-test-check-py when a BSP has no tcfg file.Chris Johns2017-04-191-1/+7
| | | | Updates #2981.
* testsuite: Fix rtems-test-check not excluding tests.Chris Johns2017-04-181-11/+49
| | | | | | | | The include file handling was broken. Add a test configuration data README. Closes #2981.
* rtems-test-check-py: Fix typoSebastian Huber2017-04-051-1/+1
* testsuite: Add a common test configuration. Fix configure.ac and Makefile.am ↵Chris Johns2017-04-043-16/+230
| | | | | | | | | | | | | | | | | | | | | | | | | | errors. - Add a top level test configuration file for test states that are common to all BSPs. This saves adding a test configuration (tcfg) file for every BSP. - Add the test states 'user-input' and 'benchmark'. This lets 'rtems-test' stop the test rather than waiting for a timeout or letting a benchmark run without the user asking for it to run. - Implement rtems-test-check in Python to make it faster. The shell script had grown to a point it was noticably slowing the build down. - Fix the configure.ac and Makefile.am files for a number of the test directories. The files are difficiult to keep in sync with the number of tests and mistakes can happen such as tests being left out of the build. The test fsrofs01 is an example. Also a there was a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be used. - Fix the test fsrofs01 so it compiles. Closes #2963.
* termios: Synchronize with latest FreeBSD headersKevin Kirspel2017-03-221-9/+20
| | | | | | | | | | | Adding modified FreeBSD headers to synchronize RTEMS termios with FreeBSD. Modify termios to support dedicated input and output baud for termios structure. Updated BSPs to use dedicated input and output baud in termios structure. Updated tools to use dedicated input and output baud in termios structure. Updated termios testsuites to use dedicated input and output baud in termios structure. Close #2897.
* tools/build/eolstrip.c: Use snprintf() to avoid potential buffer overflowJoel Sherrill2017-03-141-1/+3
| | | | This was spotted by Coverity Scan.
* Fix rtems-test-check with a BSD sed.Chris Johns2017-03-141-5/+5
| | | | | BSD sed does not support '\t' and treated '[ \t]' as 3 characters. This patch uses a standard method of supporting blank spaces.
* rtems-test-check: Fix to properly process excludesStavros Passas2017-01-171-1/+5
| | | | Closes #2867.
* testsuite: Add test states to the testsuit configuration files.Chris Johns2016-12-071-27/+101
| | | | | | | | | | | | | | | | Change the testsuite configuration files to hold state information about a test. The states are: exclude - Do not build the test expected-fail - The test is expected to fail indeterminate - The test may pass or may fail A message is printed just after the test's BEGIN message to indicate there is a special state for the test. No state message means the test is expected to pass. This support requires tests are correctly written to the use standard support to begin and end a test.
* tools: Delete unused binpatchSebastian Huber2016-06-062-148/+0
| | | | | | This was a no-install binary apparently unused. Update #2730.
* tools/cpu/nios2/ptf.c: Fix leak of memory pointed to by new_prefixMartin Galvan2015-09-031-10/+14
| | | | Updates #2405.
* tools/cpu/nios2/memory.c: Fix uninitialized use of variable memoryMartin Galvan2015-09-031-3/+2
| | | | Updates #2405.
* tools/cpu/nios2/ptf.c: Add include of <ctype.h>Joel Sherrill2015-03-241-0/+1
* tools/build/binpatch.c: Include <unistd.h> for getopt()Joel Sherrill2015-03-241-0/+1
* tools/build/rtems-test-check: Support multiple include filesJoel Sherrill2015-03-221-1/+1
* tools/cpu/sh/sci.c: Add include of bsp.h to generated fileJoel Sherrill2015-03-091-0/+1
* rtems-bin2c: Fix Windows buildSebastian Huber2015-02-231-1/+1
| | | | Update #2238.
* Use counted strnlen in bin2c. Closes #2238.Gedare Bloom2015-02-231-1/+1
* tools: Fix fprintf() statementSebastian Huber2015-01-231-1/+1
| | | | Close #2240.
* tools/cpu/nios2/ptf.c: Add include to fix warningsJoel Sherrill2015-01-131-0/+1
* Update bug report URLSebastian Huber2014-12-055-5/+5
* tools: Provide strnlen() if missingSebastian Huber2014-12-024-3/+50
* rtems-bin2c.c: Fix free() of altered pointerJoel Sherrill2014-11-271-4/+5
* tools/build/*.c: Clean up issues reported by CodeSonarJosh Oguin2014-11-265-306/+309
| | | | | | | This code is built without warnings and ignored by Coverity Scan. CodeSonar found a wide range of issues including buffer overruns, buffer underruns, questionable type conversions, leaks, etc. This set of patches addresses all reported issues.
* tools: Remove invalid cpp characters from the header guards.Chris Johns2014-09-051-8/+21
| | | | | The waf converter in examples-v2 uses an absolute path and this creates defines with invalid characters.
* rtems-test-check: Ignore tests which require real ISR based clock tickChris Johns2014-05-281-3/+27
| | | | | | | | | BSPs for simulators which do not include a clock tick interrupt source are incapable of running some tests successfully. This is a common characteristic of some BSPs and a fixed set of tests. There is no point in duplicating this list of tests in those BSPs test configuration. Read testsuites/testdata/require-tick-isr.tcfg for details.
* testsuite: Add a per BSP test check for tests not to build.Chris Johns2014-05-051-0/+52
| | | | | | | | Provide a file per BSP to list tests that do not build for a BSP. This change removes the BSP_SMALL_MEMORY hack from the code. That hack was a mistake. Provide configuration files for each BSP with tests that cannot build.
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-2116-17/+17
* Initialize the string before replacing charactersCynthia Rempel2013-08-261-1/+1
* RTEMS: Delete ChangeLog files.Gedare Bloom2013-03-085-534/+0
| | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain.
* Require automake-1.12.2.Ralf Corsépius2012-07-195-5/+5
* Require autoconf-2.69.Ralf Corsépius2012-07-195-5/+5
* Remove CVS Id Strings (manual edits after script)Joel Sherrill2012-05-116-25/+2
| | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns.
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-1134-88/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-0710-0/+32
* Remove CVS-Ids.Ralf Corsépius2012-05-042-6/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-042-8/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-015-75/+0
* 2011-06-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-082-0/+13
| | | | * config.h.in: Regenerated.
* * tools/build/.cvsignore, tools/build/ChangeLog,Joel Sherrill2011-05-1757-0/+7632
| | | | | | | | | | | | | | | | | | | | | | | | | | | | tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c, tools/build/cklength.c, tools/build/config.h.in, tools/build/configure.ac, tools/build/cvsignore-add.sh, tools/build/doxy-filter, tools/build/eolstrip.c, tools/build/install-if-change.in, tools/build/multigen, tools/build/packhex.c, tools/build/rtems-bin2c.c, tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac, tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog, tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac, tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore, tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am, tools/cpu/nios2/README, tools/cpu/nios2/bridges.c, tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c, tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac, tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h, tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h, tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h, tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c, tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c, tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf, tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING, tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO, tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h, tools/cpu/sh/shgen.c: New files.
* 2011-05-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-05-17122-13807/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tools/build/.cvsignore, tools/build/ChangeLog, tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c, tools/build/cklength.c, tools/build/configure.ac, tools/build/cvsignore-add.sh, tools/build/doxy-filter, tools/build/eolstrip.c, tools/build/install-if-change.in, tools/build/multigen, tools/build/packhex.c, tools/build/rtems-bin2c.c, tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac, tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog, tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac, tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore, tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am, tools/cpu/nios2/README, tools/cpu/nios2/bridges.c, tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c, tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac, tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h, tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h, tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h, tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c, tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c, tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf, tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING, tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO, tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h, tools/cpu/sh/shgen.c, tools/schedsim/.cvsignore, tools/schedsim/ChangeLog, tools/schedsim/Makefile.am, tools/schedsim/README, tools/schedsim/configure.ac, tools/schedsim/rtems/.cvsignore, tools/schedsim/rtems/ChangeLog, tools/schedsim/rtems/Makefile.am, tools/schedsim/rtems/interr.c, tools/schedsim/rtems/rtems_init.c, tools/schedsim/rtems/rtems_sched.h, tools/schedsim/rtems/wkspace.c, tools/schedsim/rtems/sched_cpu/cpu.c, tools/schedsim/rtems/sched_cpu/cpu_asm.c, tools/schedsim/rtems/sched_cpu/rtems/asm.h, tools/schedsim/rtems/sched_cpu/rtems/stringto.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpu.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpu_asm.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpuopts.h, tools/schedsim/rtems/sched_cpu/rtems/score/no_cpu.h, tools/schedsim/rtems/sched_cpu/rtems/score/types.h, tools/schedsim/shell/.cvsignore, tools/schedsim/shell/ChangeLog, tools/schedsim/shell/Makefile.am, tools/schedsim/shell/schedsim_priority/.cvsignore, tools/schedsim/shell/schedsim_priority/Makefile.am, tools/schedsim/shell/schedsim_priority/config.c, tools/schedsim/shell/schedsim_priority/printheir_executing.c, tools/schedsim/shell/schedsim_priority/schedsim.cc, tools/schedsim/shell/schedsim_priority/wrap_thread_dispatch.c, tools/schedsim/shell/scripts/script01, tools/schedsim/shell/scripts/script02, tools/schedsim/shell/scripts/script03, tools/schedsim/shell/scripts/script04, tools/schedsim/shell/scripts/script05, tools/schedsim/shell/scripts/script06, tools/schedsim/shell/shared/.cvsignore, tools/schedsim/shell/shared/Makefile.am, tools/schedsim/shell/shared/commands.c, tools/schedsim/shell/shared/getopt.c, tools/schedsim/shell/shared/lookup_semaphore.c, tools/schedsim/shell/shared/lookup_task.c, tools/schedsim/shell/shared/main_clocktick.c, tools/schedsim/shell/shared/main_echo.c, tools/schedsim/shell/shared/main_executing.c, tools/schedsim/shell/shared/main_heir.c, tools/schedsim/shell/shared/main_help.c, tools/schedsim/shell/shared/main_rtemsinit.c, tools/schedsim/shell/shared/main_semcreate.c, tools/schedsim/shell/shared/main_semdelete.c, tools/schedsim/shell/shared/main_semflush.c, tools/schedsim/shell/shared/main_semobtain.c, tools/schedsim/shell/shared/main_semrelease.c, tools/schedsim/shell/shared/main_taskcreate.c, tools/schedsim/shell/shared/main_taskdelete.c, tools/schedsim/shell/shared/main_taskmode.c, tools/schedsim/shell/shared/main_taskpriority.c, tools/schedsim/shell/shared/main_taskresume.c, tools/schedsim/shell/shared/main_tasksuspend.c, tools/schedsim/shell/shared/main_taskwakeafter.c, tools/schedsim/shell/shared/schedsim_shell.h, tools/schedsim/shell/shared/shell_cmdset.c, tools/schedsim/shell/shared/shell_makeargs.c, tools/schedsim/shell/shared/include/shell.h, tools/schedsim/shell/shared/include/newlib/_ansi.h, tools/schedsim/shell/shared/include/newlib/getopt.h: Removed. * configure.ac: RTEMS Scheduler Simulator is now in its own CVS module named rtems-schedsim.
* 2011-05-13 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-05-133-5/+12
| | | | | | * rtems/interr.c: Minimize diffs to cpukit/score/src/interr.c. * rtems/sched_cpu/rtems/score/cpu.h: Incorporate parts of former posix BSP.
* 2011-04-21 Jennifer Averett <Jennifer.Averett@OARcorp.comJennifer Averett2011-04-211-1/+1
| | | | | | PR 1777/cpukit * tools/schedsim/rtems/rtems_init.c: Consolidated access to _Thread_Dispatch_disable_level.
* 2011-04-11 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-04-112-0/+5
| | | | * Makefile.am: Add schedulersimple.h
* 2011-04-07 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-04-072-0/+104
| | | | * README: New file.
