tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c,
tools/build/cklength.c, tools/build/config.h.in,
tools/build/configure.ac, tools/build/cvsignore-add.sh,
tools/build/doxy-filter, tools/build/eolstrip.c,
tools/build/install-if-change.in, tools/build/multigen,
tools/build/packhex.c, tools/build/rtems-bin2c.c,
tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore,
tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac,
tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog,
tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac,
tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore,
tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am,
tools/cpu/nios2/README, tools/cpu/nios2/bridges.c,
tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c,
tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac,
tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h,
tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h,
tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h,
tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c,
tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c,
tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf,
tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING,
tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO,
tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h,
tools/cpu/sh/shgen.c: New files.
* tools/build/.cvsignore, tools/build/ChangeLog,
tools/build/cklength.c, tools/build/configure.ac,
tools/build/cvsignore-add.sh, tools/build/doxy-filter,
tools/build/eolstrip.c, tools/build/install-if-change.in,
tools/build/multigen, tools/build/packhex.c,
tools/build/rtems-bin2c.c, tools/build/search-id.sh,
tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog,
tools/cpu/sh/shgen.c, tools/schedsim/.cvsignore,
tools/schedsim/ChangeLog, tools/schedsim/Makefile.am,
tools/schedsim/README, tools/schedsim/configure.ac,
tools/schedsim/rtems/.cvsignore, tools/schedsim/rtems/ChangeLog,
tools/schedsim/rtems/Makefile.am, tools/schedsim/rtems/interr.c,
tools/schedsim/rtems/rtems_init.c,
tools/schedsim/rtems/rtems_sched.h, tools/schedsim/rtems/wkspace.c,
tools/schedsim/rtems/sched_cpu/cpu.c,
tools/schedsim/rtems/sched_cpu/cpu_asm.c,
tools/schedsim/rtems/sched_cpu/rtems/asm.h,
tools/schedsim/rtems/sched_cpu/rtems/stringto.h,
tools/schedsim/rtems/sched_cpu/rtems/score/cpu.h,
tools/schedsim/rtems/sched_cpu/rtems/score/cpu_asm.h,
tools/schedsim/rtems/sched_cpu/rtems/score/cpuopts.h,
tools/schedsim/rtems/sched_cpu/rtems/score/no_cpu.h,
tools/schedsim/rtems/sched_cpu/rtems/score/types.h,
tools/schedsim/shell/.cvsignore, tools/schedsim/shell/ChangeLog,
tools/schedsim/shell/Makefile.am,
tools/schedsim/shell/schedsim_priority/.cvsignore,
tools/schedsim/shell/schedsim_priority/Makefile.am,
tools/schedsim/shell/schedsim_priority/config.c,
tools/schedsim/shell/schedsim_priority/printheir_executing.c,
tools/schedsim/shell/schedsim_priority/schedsim.cc,
tools/schedsim/shell/schedsim_priority/wrap_thread_dispatch.c,
tools/schedsim/shell/scripts/script01,
tools/schedsim/shell/scripts/script02,
tools/schedsim/shell/scripts/script03,
tools/schedsim/shell/scripts/script04,
tools/schedsim/shell/scripts/script05,
tools/schedsim/shell/scripts/script06,
tools/schedsim/shell/shared/.cvsignore,
tools/schedsim/shell/shared/Makefile.am,
tools/schedsim/shell/shared/commands.c,
tools/schedsim/shell/shared/getopt.c,
tools/schedsim/shell/shared/lookup_semaphore.c,
tools/schedsim/shell/shared/lookup_task.c,
tools/schedsim/shell/shared/main_clocktick.c,
tools/schedsim/shell/shared/main_echo.c,
tools/schedsim/shell/shared/main_executing.c,
tools/schedsim/shell/shared/main_heir.c,
tools/schedsim/shell/shared/main_help.c,
tools/schedsim/shell/shared/main_rtemsinit.c,
tools/schedsim/shell/shared/main_semcreate.c,
tools/schedsim/shell/shared/main_semdelete.c,
tools/schedsim/shell/shared/main_semflush.c,
tools/schedsim/shell/shared/main_semobtain.c,
tools/schedsim/shell/shared/main_semrelease.c,
tools/schedsim/shell/shared/main_taskcreate.c,
tools/schedsim/shell/shared/main_taskdelete.c,
tools/schedsim/shell/shared/main_taskmode.c,
tools/schedsim/shell/shared/main_taskpriority.c,
tools/schedsim/shell/shared/main_taskresume.c,
tools/schedsim/shell/shared/main_tasksuspend.c,
tools/schedsim/shell/shared/main_taskwakeafter.c,
tools/schedsim/shell/shared/schedsim_shell.h,
tools/schedsim/shell/shared/shell_cmdset.c,
tools/schedsim/shell/shared/shell_makeargs.c,
tools/schedsim/shell/shared/include/shell.h,
tools/schedsim/shell/shared/include/newlib/_ansi.h,
tools/schedsim/shell/shared/include/newlib/getopt.h: Removed.
* configure.ac: RTEMS Scheduler Simulator is now in its own CVS module
named rtems-schedsim.
* rtems/interr.c: Minimize diffs to cpukit/score/src/interr.c.
* rtems/sched_cpu/rtems/score/cpu.h:
Incorporate parts of former posix BSP.
PR 1777/cpukit
* tools/schedsim/rtems/rtems_init.c: Consolidated access to
_Thread_Dispatch_disable_level.
* Makefile.am: Add schedulersimple.h
* README: New file.
* shared/main_clocktick.c, shared/main_semcreate.c,
shared/main_semdelete.c, shared/main_semflush.c,
shared/main_semobtain.c, shared/main_semrelease.c,
shared/main_taskcreate.c, shared/main_taskdelete.c,
shared/main_taskmode.c, shared/main_taskpriority.c,
shared/main_taskresume.c, shared/main_tasksuspend.c,
shared/main_taskwakeafter.c, shared/schedsim_shell.h: Compiles now
and do not core dump when RTEMS is not initialized.
* Makefile.am, wkspace.c: Compiles now and do not core dump when RTEMS
is not initialized.
* sched_cpu/rtems/score/cpuopts.h: Bump to 4.10.99.0
* configure.ac: Remove RTEMS_PATH_KSH (Unused).
Require autoconf >= 2.68, automake >= 1.11.1.
Add AC_PROG_CC_C99 to enforce c99 hoping this will suffice to make
this stuff compilable with older GCCs (works on some hosts).
Jennifer Averett <jennifer.averett@oarcorp.com>
Add RTEMS Scheduler Simulator. This is the top level of the tree.
* .cvsignore, ChangeLog, Makefile.am, configure.ac: New files.
* .cvsignore: New file.
Add RTEMS Scheduler Simulator. This is the RTEMS "port" to and
adapter code to run on GNU/Linux with a fake context switch.
* ChangeLog, Makefile.am, interr.c, rtems_init.c, rtems_sched.h,
wkspace.c, sched_cpu/cpu.c, sched_cpu/cpu_asm.c,
sched_cpu/rtems/asm.h, sched_cpu/rtems/stringto.h,
sched_cpu/rtems/score/cpu.h, sched_cpu/rtems/score/cpu_asm.h,
sched_cpu/rtems/score/cpuopts.h, sched_cpu/rtems/score/no_cpu.h,
sched_cpu/rtems/score/types.h: New files.
Add RTEMS Scheduler Simulator. This is the shell scripting portion.
* .cvsignore, ChangeLog, Makefile.am, schedsim_priority/.cvsignore,
schedsim_priority/Makefile.am, schedsim_priority/config.c,
schedsim_priority/wrap_thread_dispatch.c, scripts/script01,
scripts/script02, scripts/script03, scripts/script04,
scripts/script05, scripts/script06, shared/.cvsignore,
shared/Makefile.am, shared/commands.c, shared/getopt.c,
shared/lookup_semaphore.c, shared/lookup_task.c,
shared/main_clocktick.c, shared/main_echo.c, shared/main_executing.c,
shared/main_heir.c, shared/main_help.c, shared/main_rtemsinit.c,
shared/main_semcreate.c, shared/main_semdelete.c,
shared/main_semflush.c, shared/main_semobtain.c,
shared/main_semrelease.c, shared/main_taskcreate.c,
shared/main_taskdelete.c, shared/main_taskmode.c,
shared/main_taskpriority.c, shared/main_taskresume.c,
shared/main_tasksuspend.c, shared/main_taskwakeafter.c,
shared/schedsim_shell.h, shared/shell_cmdset.c,
shared/shell_makeargs.c, shared/include/shell.h,
shared/include/newlib/_ansi.h, shared/include/newlib/getopt.h: New
files.
* rtems-bin2c.c: Fix memory leak in '.c' suffix strip.
Also strip '.h' suffix.
* rtems-bin2c.c: Make -v (verbose) working.
* configure.ac: Check for libgen.h, basename.
* rtems-bin2c.c: Use basename(3) instead of strrchr cascade.
Introduce ifbasename. Use ifbasename in generated files.
* rtems-bin2c.c: Add -C and -H options.
* eolstrip.c: Readdress use of ctype methods per recommendation from
D.J. Delorie on the newlib mailing list. We should pass an unsigned
char into these methods.
* Makefile.am: Rename bin2c to rtems-bin2c.
* bin2c.c: Updated license after author changed it.
* bin2c.c: Update comments.
* bin2c.c: Significant improvements -- add multiple options, generate
both C and H files, do not always generate static. fix indentation,
add comments.
* bin2c.c: New file.
http://www.wxwidgets.org/wiki/index.php/Embedding_PNG_Images-Bin2c_In_C
* Makefile.am: Add bin2c so we can have a more reliable way to convert
binary files to objects. If they are in C, we can use the correct CPU
CFLAGS and they will link easier.
* linkcmds.c, linkcmds.h, memory.c, memory.h, sample.ptf: New files.
* bridges.c: corrected detection of bridged connections
* clocks.c: removed a printf
* linkcmds.[ch] new files, added output of linker script
* Makefile.am: added new files
* memory.[ch]: new files, detection of memory in SOPC configuration
* nios2gen.c: updated command line parsing and output control
* output.[ch]: improved output of BSP header file
* ptf.[ch]: added ptf_dump_ptf_item and small fixes
* sample.ptf: new file, sample configuration for nios2gen
* README: updated
* nios2gen.c: Added some very basic support for --help and --version
options along with output that is roughly in GNU format. This is
required by help2man. help2man expects this all to be written to
stdout instead of stderr so this was changed as well.
* ChangeLog: New file.
* configure.ac: New port to Altera NIOS II.
* nios2/.cvsignore, nios2/Makefile.am, nios2/README, nios2/bridges.c,
nios2/bridges.h, nios2/clocks.c, nios2/clocks.h, nios2/configure.ac,
nios2/devices.c, nios2/devices.h, nios2/nios2gen.c, nios2/output.c,
nios2/output.h, nios2/ptf.c, nios2/ptf.h: New files.
* doxy-filter: New.
* Makefile.am: Add doxy-filter.
* ampolish3.in: Remove.
* Makefile.am: Remove ampolish3.
* configure.ac: Remove ampolish3, perl.
* shgen.c: include <stdlib.h>.
* ampolish3.in: Check Makefile.am for SUBDIRS.
Add all-am: for PREINSTALL_FILES.
* ampolish3.in: Add all: for PREINSTALL_FILES.
Add all-local for TMPINSTALL_FILES.
Misc bug fixes.
* ampolish3.in: Check if Makefile.am already contains CLEANFILES or
DISTCLEANFILES.
* ampolish3.im: Update.
* ampolish3.in: Sync with private bleeding-edge .
* ampolish3.in: Use @PERL@, partial update from local sources.
* configure.ac: Add ampolish3.
* Makefile.am: Add ampolish3.
* ampolish3.in: New.
