* sh/COPYING: Readded. Deleting this violated GPL on shgen.
* sh/COPYING: Deleted.
* sh/Makefile.am: Use "./shgen" not "shgen" so current directory
does not have to be in the PATH.
* Makefile.am: Remove unix from DIST_SUBDIRS.
* Per PR150, unix directory and contents removed.
* unix/, unix/ChangeLog, unix/Makefile.am, unix/configure.ac,
unix/gensize.c: Deleted.
* tools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
* configure.in: AC_PREREQ(2.52), apply RTEMS_CPU_SUBDIRS.
* configure.in: Reworked for Canadian Cross support.
* config.guess, config.sub: Update from subversions.gnu.org.
* README.cdn-X: New file.
* tools/Makefile.am: Remove build, tools from SUBDIRS.
* config.h.in: Automatically generated. Remove from CVS.
* shgen.c: Set default Phi to 20MHz (BUG-FIX).
* ampolish: Generate ACLOCAL_AMFLAGS = -I .../aclocal.
* Makefile.am: Switch to GNU-canonicalized autoconf macros.
* multigen: Fix BARE_CPU_CFLAGS.
* multigen: Fix usage.
* ampolish: Add rules to add compile.am
that is a cosmetic patch to ampolish.
that adds multigen to the list of noinst_SCRIPTS.
CVS:
CVS: Committing in .
CVS:
CVS: Modified Files:
<corsepiu@faw.uni-ulm.de> to update multigen.
that contains:
* Removes MKLIB
handling)
that should not have been.
which is described below:
break something.
SUBDIRS in a Makefile.am)
* An update to gensh2.cfg.
cd <srcdir>
in the previous commits.
His comments follow:
This is a minor enhancement to shgen, which should not have any
side-effects.
for RTEMS.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
This patch addresses a few configuration issues and removes some
duplicate configuration files.
Background:
* some files used in AC_INIT were not unique enough and can lead to
problems if a user plays with configure scripts.
* the Makefile templates are independent of the target/cpu and bsp, so
the bsp dependent versions (c/src/make/Templates) are removed.
patch -p1 < rtems-rc-19990820-3.diff
rm -f c/src/make/Templates
ATTENTION: This patch removes several files and one directory :)
1. Addition of maintainer-mode dependencies on config.status and
aclocal.m4 for autoconf toplevel Makefile.ins. These rules are taken
over from automake generated Makefile.ins, i.e. they are contained in
any automake generated toplevel Makefile.in. Having this patch in is at
least a great releaf for me when working on RTEMS configuration :)
2. Automated support for #1 in acpolish
3. Some minor "beautifications" on Makefile.ins resulting from running
acpolish.
FYI: This patch has been generated by running
tools/update/rtems-polish.sh -ac on the source tree and manually editing
the resulting patch afterwards to work around a problem with acpolish,
which still corrupts one Makefile.in - WARNING: Be careful with running
acpolish!
cd <srcdir>
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
<corsepiu@faw.uni-ulm.de>.
