* | Solaris port updates from Chris Johns | Joel Sherrill | 1998-01-23 | 4 | -4/+4 | |
* | Cleaned up a bit. | Joel Sherrill | 1998-01-23 | 1 | -9/+31 | |
* | Added autoconf support for strerror/sys_errlist per Ralf Corsepius' | Joel Sherrill | 1998-01-21 | 9 | -53/+161 | |
| | | | | | direction. This fixes a problem reported by Steve Evans of Radstone since he is using glibc2. | |||||
* | Corrected prototypes for main per Ralf Corsepius' report of warnings | Joel Sherrill | 1998-01-21 | 6 | -10/+24 | |
| | | | | generated when egcs is used with "-Wall -pedantic". | |||||
* | Removed CONFIG_DIR and PROJECT_HOME directories. | Joel Sherrill | 1998-01-20 | 4 | -4/+4 | |
* | Ralf Corsepius reported a number of missing CVS Id's: | Joel Sherrill | 1998-01-16 | 4 | -1/+34 | |
| | | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose. | |||||
* | Now generating this file with autoconf to avoid having to embed so | Joel Sherrill | 1997-12-22 | 1 | -0/+221 | |
| | | | | much target specific information in the script. | |||||
* | Modified a lot of files to take a first cut at supporting building from | Joel Sherrill | 1997-12-10 | 9 | -12/+36 | |
| | | | | | any directory in the build tree. The only variable which must be set before the command "gmake" is invoked is RTEMS_BSP (e.g. RTEMS_BSP=erc32). | |||||
* | Corrected comment. | Joel Sherrill | 1997-11-30 | 1 | -4/+0 | |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 2 | -8/+8 | |
* | Removed include directory at "build" point and the link of this directory | Joel Sherrill | 1997-10-08 | 1 | -1/+1 | |
| | | | | | | to lib/include. Went to using a PROJECT_INCLUDE variable. | |||||
* | Removed hackspecs.awk in move from -mrtems to -qrtems. | Joel Sherrill | 1997-08-28 | 1 | -2/+1 | |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 2 | -18/+18 | |
| | | | | of switching to the modified GNU GPL. | |||||
* | added ifdef around variables to eliminate warnings when cross | Joel Sherrill | 1997-04-07 | 1 | -0/+2 | |
* | This set of changes is the build of what was required to convert to | Joel Sherrill | 1997-04-01 | 11 | -6/+310 | |
| | | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved. | |||||
* | added ifdef for sunos 4.x since it does not have strtoul. | Joel Sherrill | 1996-06-03 | 2 | -4/+12 | |
* | *** empty log message *** | Joel Sherrill | 1996-05-23 | 1 | -2/+2 | |
* | updates from Tony Bennett | Joel Sherrill | 1996-04-22 | 1 | -6/+35 | |
* | updates from Tony Bennett for PA and UNIX ports | Joel Sherrill | 1996-01-15 | 6 | -64/+12 | |
* | changes remerged after disk crash -- history lost | Joel Sherrill | 1995-12-19 | 4 | -0/+12 | |
* | minor changes so it would compile in a cross environment | Joel Sherrill | 1995-12-05 | 1 | -0/+2 | |
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 5 | -0/+13 | |
* | SPARC merged and successfully tested w/o interrupt support | Joel Sherrill | 1995-10-06 | 4 | -0/+16 | |
* | moved to new development machine and went to gcc 2.7.0 | Joel Sherrill | 1995-10-06 | 4 | -0/+12 | |
* | all targets compile .. tony's patches in place | Joel Sherrill | 1995-09-29 | 3 | -4/+4 | |
* | new programs added | Joel Sherrill | 1995-09-27 | 3 | -1/+276 | |
* | Modified UNIX simulator port so all references to native unix | Joel Sherrill | 1995-09-27 | 1 | -0/+116 | |
| | | | | | stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files. | |||||
* | Initial attempt at building HP PA-RISC using Solaris hosted tools. | Joel Sherrill | 1995-09-12 | 1 | -5/+129 | |
| | | | | Changed back to Newlib for Solaris UNIX simulator. | |||||
* | Added | Joel Sherrill | 1995-09-11 | 1 | -0/+283 | |
* | Fixed missing RCS Ids | Joel Sherrill | 1995-08-22 | 1 | -1/+1 | |
* | updates for msdos/go32 from Bryce Cogswell | Joel Sherrill | 1995-07-26 | 3 | -0/+498 | |
* | fixing revision | Joel Sherrill | 1995-05-31 | 4 | -0/+12 | |
* | Fully tested on all in-house targets | Joel Sherrill | 1995-05-24 | 1 | -4/+4 | |
* | Initial revision | Joel Sherrill | 1995-05-11 | 13 | -0/+4699 | |
