* | Remove stray white spaces. | Ralf Corsepius | 2004-04-20 | 5 | -35/+35 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 |
* | Unused. | Ralf Corsepius | 2004-03-09 | 1 | -2/+0 |
* | 2004-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-20 | 2 | -0/+6 |
| | | | | | * Makefile.am: Add EXTRA_DIST = search-id.sh multigen cvsignore-add.sh. | ||||
* | 2004-02-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-04 | 2 | -1/+5 |
| | | | | * Makefile.am: DIST_SUBDIRS = @subdirs@. | ||||
* | 2004-01-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-06 | 2 | -1/+5 |
| | | | | * Makefile.am: Let shgen.1 depend on shgen$(EXEEXT). | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 8 | -8/+24 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -0/+5 |
| | | | | * Makefile.am: Cosmetics. | ||||
* | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-26 | 2 | -1/+5 |
| | | | | * Makefile.am: Obsoleting HP PA-RISC port. | ||||
* | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-26 | 6 | -463/+5 |
| | | | | | * hppa1.1/.cvsignore, hppa1.1/ChangeLog, hppa1.1/Makefile.am, hppa1.1/configure.ac, hppa1.1/genoffsets.c: Removed. | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 2 | -2/+6 |
| | | | | * genoffsets.c: URL for license changed. | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 2 | -1/+5 |
| | | | | * size_rtems.in: URL for license changed. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 10 | -5/+25 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-25 | 13 | -2581/+0 |
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 12 | -7/+35 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 12 | -6/+30 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 12 | -18/+54 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-10-02 Chris Johns <cjohns@cybertec.com.au> | Joel Sherrill | 2002-10-04 | 3 | -1/+31 |
| | | | | | * cvsignore-add.sh: Script to append a specific file to all .cvsignore files if the files exists is a specific directory. | ||||
* | 2002-06-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-06-27 | 2 | -0/+6 |
| | | | | * Makefile.am: genoffsets must be built before the executive. | ||||
* | 2002-06-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-06-27 | 1 | -1/+1 |
| | | | | * tools/Makefile.am: Build the cpu dependent tools as well. | ||||
* | 2002-05-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-05-01 | 7 | -103/+6 |
| | | | | | * lock-directory.in, unlock-directory.in: Removed. * Makefile.am, README, .cvsignore: Updated to reflect above. | ||||
* | 2002-04-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-04-03 | 6 | -3/+12 |
| | | | | * configure.ac: Remove AC_EXEEXT (obsolete). | ||||
* | 2001-04-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-04-03 | 2 | -0/+348 |
| | | | | * sh/COPYING: Readded. Deleting this violated GPL on shgen. | ||||
* | 2001-04-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-04-02 | 2 | -19/+4 |
| | | | | * sh/COPYING: Deleted. | ||||
* | 2001-04-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-04-02 | 2 | -1/+6 |
| | | | | | * sh/Makefile.am: Use "./shgen" not "shgen" so current directory does not have to be in the PATH. | ||||
* | 2001-04-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-04-02 | 2 | -1/+5 |
| | | | | * Makefile.am: Remove unix from DIST_SUBDIRS. | ||||
* | 2001-03-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-03-29 | 6 | -192/+6 |
| | | | | | | * Per PR150, unix directory and contents removed. * unix/, unix/ChangeLog, unix/Makefile.am, unix/configure.ac, unix/gensize.c: Deleted. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -1/+0 |
| | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. * tools/Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 21 | -21/+63 |
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-12 | 7 | -0/+178 |
| | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. | ||||
* | 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-12 | 7 | -162/+0 |
| | | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-11 | 14 | -0/+49 |
* | 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-11 | 2 | -3/+6 |
| | | | | * configure.in: AC_PREREQ(2.52), apply RTEMS_CPU_SUBDIRS. | ||||
* | 2001-02-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-03-01 | 1 | -1/+1 |
| | | | | | | | | * configure.in: Reworked for Canadian Cross support. * Makefile.am: Reflect changes to configure.in. * config.guess, config.sub: Update from subversions.gnu.org. * README.cdn-X: New file. * tools/Makefile.am: Remove build, tools from SUBDIRS. | ||||
* | 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-01-24 | 2 | -7/+4 |
| | | | | * config.h.in: Automatically generated. Remove from CVS. | ||||
* | 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-15 | 2 | -2/+6 |
| | | | | * shgen.c: Set default Phi to 20MHz (BUG-FIX). | ||||
* | 2000-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-10 | 2 | -5/+5 |
| | | | | * ampolish: Generate ACLOCAL_AMFLAGS = -I .../aclocal. | ||||
* | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-09 | 14 | -7/+35 |
| | | | | * Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. | ||||
* | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-02 | 14 | -7/+35 |
| | | | | * Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. | ||||
* | 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-10-31 | 14 | -7/+35 |
| | | | | * Makefile.am: Switch to GNU-canonicalized autoconf macros. | ||||
* | 2000-08-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-12 | 2 | -1/+5 |
| | | | | * multigen: Fix BARE_CPU_CFLAGS. | ||||
* | 2000-09-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-06 | 2 | -2/+8 |
| | | | | * multigen: Fix usage. | ||||
* | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-05 | 2 | -0/+21 |
| | | | | * ampolish: Add rules to add compile.am | ||||
* | Adding ChangeLogs. | Joel Sherrill | 2000-08-10 | 7 | -0/+21 |
* | Patch rtems-rc-20000731-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-08-01 | 1 | -1/+1 |
| | | | | that is a cosmetic patch to ampolish. | ||||
* | Patch rtems-rc-20000705-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-07-06 | 1 | -1/+1 |
| | | | | that adds multigen to the list of noinst_SCRIPTS. | ||||
* | Patch rtems-rc-20000705-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-07-06 | 1 | -11/+19 |
| | | | | | | | | | | | CVS: ---------------------------------------------------------------------- CVS: Enter Log. Lines beginning with `CVS:' are removed automatically CVS: CVS: Committing in . CVS: CVS: Modified Files: CVS: c/src/tests/libtests/termios/init.c CVS: ---------------------------------------------------------------------- | ||||
* | Patch rtems-rc-20000615-2-cvs.diff from Ralf Corsepius | Joel Sherrill | 2000-06-15 | 1 | -0/+6 |
| | | | | <corsepiu@faw.uni-ulm.de> to update multigen. | ||||
* | New file from Ralf. | Joel Sherrill | 2000-06-14 | 1 | -0/+165 |
