path: root/tools (follow)
* New file from Ralf.Joel Sherrill2000-06-141-0/+165
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-1216-167/+609
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-138-0/+102
| | | | adds .cvsignore.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-088-80/+196
* Ralf Corsepius <corsepiu@faw.uni-ulm.de> caught some files in CVSJoel Sherrill2000-01-311-1/+0
| | | | that should not have been.
* Patch rtems-rc-20000104-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-071-9/+19
| | | | | | | | | | | | | | | | | | | | | which is described below: This one is a (minor) patch in preparation of the upcoming patches. It actually is an excerpt of the upcoming patches and therefore is completely untested in this standalone form, but I don't expect it to break something. The essential changes in this patch are: * An update to rtems-polish.sh (Now can also be run in subdirectories) * A bug-fix for the libcpu/powerpc (A directory was missing from SUBDIRS in a Makefile.am) * An update to gensh2.cfg. * Cleanups/Enhancements to configuration files To apply: cd <srcdir> patch -p0 < rtems-rc-20000104-0.diff cvs rm -f c/src/lib/libbsp/Makefile.am.new
* Miscellaneous patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-232-1/+12
| | | | | that are part of the Makefile.am conversion effort but were missed in the previous commits.
* Updated copyright notice.Joel Sherrill1999-11-173-8/+5
* Patch rtems-rc-19991105-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill1999-11-173-7/+25
| | | | | | | His comments follow: This is a minor enhancement to shgen, which should not have any side-effects.
* This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill1999-11-091-0/+4
| | | | for RTEMS.
* Removed aclocal.m4 generated from aclocal macrosJoel Sherrill1999-10-067-1827/+0
* Removed configure generated from configure.inJoel Sherrill1999-10-067-10564/+0
* Regenerated.Joel Sherrill1999-10-0514-511/+539
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-047-23/+23
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-10-047-7/+7
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | The patch below actuallly consists of two patches: 1) moving librpc to c/src/librpc similar to what has been done to librtems++ 2) reworked configure scripts, many safety and dependency checks added to aclocal/*.m4 macros + configuration fixes. To apply: mkdir c/src/librpc mkdir c/src/librpc/src cp c/src/lib/librpc/*.c c/src/librpc/src cp c/src/lib/librpc/Makefile.in c/src/librpc/src mkdir c/src/librpc/include mkdir c/src/librpc/include/rpc cp c/src/lib/include/rpc/* c/src/librpc/include/rpc patch -p1 < ../rtems-rc-19990820-7.diff rm -rf c/src/lib/librpc rm -rf c/src/lib/include/rpc ./autogen The additional checks in aclocal/*m4 macros add rather restrictive, sometimes unnecessarily restrictive constraints on the sequence of how macros can be used in a configure.in script. Adding them has let my problems with some more complicated configuration options vanish. Apparently some macros had not been in the required order . ---- Now I still get some linking errors for some cpus and bsps, esp when linking cdtest, but also at other locations: e.g. this happens for mips64orion/p4600: # make[5]: Entering directory `/lfs/poseidon/users/rtems/src/multi/build/mips64orion-rtems/c/p4600/tests/samples/hello' /opt/rtems/bin/mips64orion-rtems-gcc --pipe -B../../../../../../p4600/lib/ -specs bsp_specs -qrtems -DP4000 -DCPU_R4000 -DP3_DIAG -D_R4000 -D__mips=3 -mcpu=4600 -G0 -I../../../../../../p4600/lib/include/networking -g -Wall -ansi -fasm -O4 -fomit-frame-pointer -o o-p4600/hello.exe o-p4600/init.o ../../../../../../p4600/lib/no-dpmem.rel ../../../../../../p4600/lib/no-event.rel ../../../../../../p4600/lib/no-msg.rel ../../../../../../p4600/lib/no-mp.rel ../../../../../../p4600/lib/no-part.rel ../../../../../../p4600/lib/no-signal.rel ../../../../../../p4600/lib/no-timer.rel ../../../../../../p4600/lib/no-rtmon.rel /opt/rtems/mips64orion-rtems/lib/libc.a(dtoa.o): In function `_dtoa_r': /opt/hermes/embedded/build/build-mips64orion-tools/mips64orion-rtems/newlib/libc/stdlib/../../../../../src/newlib/libc/stdlib/dtoa.c:348: relocation truncated to fit: R_MIPS_LITERAL no symbol /opt/hermes/embedded/build/build-mips64orion-tools/mips64orion-rtems/newlib/libc/stdlib/../../../../../src/newlib/libc/stdlib/dtoa.c:348: relocation truncated to fit: R_MIPS_LITERAL no symbol /opt/hermes/embedded/build/build-mips64orion-tools/mips64orion-rtems/newlib/libc/stdlib/../../../../../src/newlib/libc/stdlib/dtoa.c:348: relocation truncated to fit: R_MIPS_LITERAL no symbol collect2: ld returned 1 exit status # mips64orion-rtems-gcc -v Reading specs from /opt/rtems/lib/gcc-lib/mips64orion-rtems/2.95.1/specs gcc version 2.95.1 19990816 (release) # mips64orion-rtems-ld -v GNU ld version 2.9.5 (with BFD 2.9.5)
* Removed Makefile.in generated from Makefile.amJoel Sherrill1999-10-047-2563/+0
* Regenerated.Joel Sherrill1999-10-0421-169/+197
* Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1999-09-0714-14/+18
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-08-302-2/+2
| | | | | | | | | | | | | | | | | | This patch addresses a few configuration issues and removes some duplicate configuration files. Background: * some files used in AC_INIT were not unique enough and can lead to problems if a user plays with configure scripts. * the Makefile templates are independent of the target/cpu and bsp, so the bsp dependent versions (c/src/make/Templates) are removed. To apply: patch -p1 < rtems-rc-19990820-3.diff rm -f c/src/make/Templates ./autogen ATTENTION: This patch removes several files and one directory :)
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-08-301-11/+40
| | | | | | | | | | | | | | | | | | | 1. Addition of maintainer-mode dependencies on config.status and aclocal.m4 for autoconf toplevel Makefile.ins. These rules are taken over from automake generated Makefile.ins, i.e. they are contained in any automake generated toplevel Makefile.in. Having this patch in is at least a great releaf for me when working on RTEMS configuration :) 2. Automated support for #1 in acpolish 3. Some minor "beautifications" on Makefile.ins resulting from running acpolish. FYI: This patch has been generated by running tools/update/rtems-polish.sh -ac on the source tree and manually editing the resulting patch afterwards to work around a problem with acpolish, which still corrupts one Makefile.in - WARNING: Be careful with running acpolish!
* Patch rtems-rc-19990709-6-diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-08-061-0/+5
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-08-021-0/+25
| | | | | | | | | | | | | | The patch below fixes a nasty bug in acpolish, which has broken many Makefile.ins below c/src/tests/ APPLYING THE PATCH: patch -p1 < rtems-rc-19990709-5.diff The essential part of this patch is the diff-fragment for acpolish contained in this patch. Ie. if any of the other diffs do not apply, make sure that the acpolish diff was applied correctly and then run cd <srcdir> tools/update/rtems-polish.sh -ac
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-07-302-6/+11
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | The main topic is replacing the hard-coded values for HAS_MP and HAS_RDBG in custom/*.cfg with per-bsp configuration-time autoconf checks (This is the patch I had mentioned before earlier this week). CHANGES * HAS_MP removed from custom/*.cfg, replaced with configuration time autoconf check * HAS_RDBG removed from custom/*.cfg, replaced with configuration-time autoconf check * NEW: c/src/make/bsp.cfg.in, takes configuration-time checked per-bsp values (i.e. HAS_MP, HAS_RDBG), gets installed as $(prefix)/<bsp>/make/bsp.cfg * NEW: default.cfg includes bsp.cfg - this change is backward compatible. * IMPORT_SRC: apply VPATH instead for ts_386ex/i386ex subdirectory Makefile.ins * HACK: a bug in acpolish mis-handles addtions to makefile variables which are enclosed in gmake conditionals: c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in * Apply inline_dir, HAS_MP and HAS_RDBG for avoiding configuration of unneeded subdirectories in various configure.in files. * Several minor changes in Makefile.ins and configure.ins, wrt. to the order of including *.cfg and defining Makefile variables APPLYING THE PATCH: patch -p1 < rtems-rc-19990709-4.diff ./autogen
* Patch to remove rcs-clean.in as it is unused from Ralf CorsepiusJoel Sherrill1999-07-284-82/+4
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-07-2618-173/+380
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | This patch is an addition to "The big-patch" CHANGES: * FIX: c/Makefile.am: bogus comment which changed the behavior of c/Makefile.am removed * FIX: make/custom/ts_i386ex.cfg did not set HAS_NETWORKING correctly (Me thinks it might have been me who added this bogus setting :-). * NEW: removing make targets get, protos, debug_install, profile_install * NEW: replacing clobber with distclean * NEW: Reimplement distclean and clean as reverse depth first make targets (adaptation to automake's behavior) * NEW: removing RCS_CLEAN from make distclean (tools/build/rcs_clean is still in - remove it?) * NEW: "$(RM) Makefile" added to make distclean (adaptation to automake's behavior) * NEW: "$(RM) config.cache config.log" to CLOBBER_ADDITIONS in [lib|exec|tests]/Makefile.in (adaptation to automake's behavior) * NEW: "$(CLEAN_PROTOS)" removed (Not used anywhere) * NEW: binpatch.c moved from i386 bsp tools to tools/build (AFAIS, binpatch is not specific to the pc386 BSP at all) * NEW: AC_EXEEXT added to all configure scripts which contain AC_PROG_CC (Cygwin support) * NEW/Experimental: An experimental implementation of temporary installation tree support in libbsp/i386/pc386/tools/Makefile.am, based on dependency tracking with make, instead of applying INSTALL_CHANGE. REMARK: * This patch is small in size, but changes the behavior of "make clean|distclean|clobber" basically. * This patch does not alter building/compiling RTEMS, ie. there should be no need to rerun all "make all" building tests. KNOWN BUGS: * make RTEMS_BSP="..." distclean in c/ runs "make distclean" in BSPs subdirectories passed through RTEMS_BSP and in "c/." only, but does not descend into other BSP subdirectories previously configured with different settings of make RTEMS_BSP="...". => Workaround: always use the same setting of RTEMS_BSP when working inside the build-tree. * "make [distclean|clean]" do not clean subdirectories, which have been configured at configuration time, but which are not used due to make-time configuration (e.g. macros/networking/rdgb subdirectories). This will problem will vanish by itself when migrating from make-time to configuration-time configuration APPLYING THE PATCH mv c/src/lib/libbsp/i386/pc386/tools/binpatch.c tools/build patch -p1 < rtems-rc-19990709-2.diff autogen
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-07-261-1/+1
| | | | | | | | | | | | | | | | | | | | | A bug in acpolish made it into rtems-rc-19990709-0.diff, which unfortunately affects all Makefile.ins: * The maintainer mode conditional was erroniously applied to the dependencies of "Makefile". In case you already checked in rtems-rc-19990709-0.diff to CVS you have to check in all Makefile.ins again after applying the patch below :). Please apply the patch below as follows: patch -p1 < rtems-rc-19990709-1.diff tools/update/rtems-polish.sh -ac Note: There is no need to rerun your tests if you have used --enable-maintainer-mode to configure RTEMS, because this patch converts all Makefile.ins to the same settings as used for --enable-maintainer-mode.
* This is part of a major patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-07-266-0/+2124
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | to move RTEMS more to automake/autoconf and GNU compliance. Finally, here they are: the "big-patch" patches - merged into one big patch (~1.5MB). Sorry for the delay, but testing took much more time than I had expected - esp. reworking the acpolish script triggered many more tiny issues than I had expected (cf. below). At least, now you've got something to spend your weekend with :-. WARNINGS: * I've gone a little (??) further than I had announced before. * Several directories have been moved. * Several files have been added and removed * I have tested it with many BSPs/CPUs and a variety of permutiations of configuration flags, but not with all. * Most parts of the patch are automatically generated, however there are many tiny manual modifications. APPLYING THE PATCH: ./autogen -c mkdir tools mv c/src/exec/score/tools tools/cpu mv c/build-tools tools/build mv c/update-tools tools/update patch -p1 -E < rtems-rc-19990709-0.diff ./autogen If the patch doesn't apply to rtems-cvs, I would suggest that you should try to apply it brute-force and then to run tools/update/rtems-polish.sh -ac -am afterwards. A recursive diff between rtems-19990709 + patch and rtems-cvs + patch then should report only a few dozen significant changes to configuration files which need to be merged manually (IIRC, I did not change any source files). *** Attention: There are files to be removed, moved, copied and added in/to CVS! NEWS/CHANGES: 1. Configuration takes place in 3 stages: 1. per host (toplevel configure script), 2. per target (c/configure), 3. per bsp c/src/configure automatically triggered from ./configure and c/Makefile.am. 2. Building of subdirectory c/ takes place in c/$(target_alias) for cross-targets in c/ for native targets 3. Building of subdirectory c/src takes place in c/${target_alias}/<bsp> for cross-targets, c/<bsp> for native targets 4. c/build-tools moved to tools/build 5. c/src/exec/score/cpu/tools moved to tools/cpu (=cpu-tools split out) 6. c/update-tools moved to tools/update 7. New subdirectory c/src/make, handles files from make/ on a per BSP basis 8. Maintainer mode support: Ie. if configuring with --enable-maintainer-mode disabled (the default), then tracking of many dependencies will be disabled in Makefiles. Esp. many dependencies for auto* generated files will be switched off in Makefiles. Ie. if not using "--enable-maintainer-mode" many auto* generated files will not be updated automatically, i.e. normal users should not be required to have auto* tools anymore (untested). 9. Independent configuration scripts for / (toplevel), tools/build, tools/cpu, tools/update, c/, c/src/, c/src/exec, c/src/lib, c/src/tests, c/src/make 10. Automake support for all directories above and besides c/src 11. "preinstall" now is implemented as depth-first recursive make target 12. host compiled tools (exception bsp-tools) are accessed in location in the build tree instead of inside the build-tree when building RTEMS. 13. RTEMS_ROOT and PROJECT_ROOT now point to directories inside the build-tree - many tiny changes as consequence from this. 14. --with-cross-host support removed (offically announced obsolete by cygnus) 15. Changing the order of building libraries below c/src/lib/ 16. Former toplevel configure script broken into aclocal/*.m4 macros 17. Newlib now detected by configure macros, RTEMS_HAS_NEWLIB removed from *cfg. 18. sptables.h now generated by autoconf 19. Rules for "mkinstalldirs temporary installation tree" moved from c/Makefile to subdirectories. 20. Cpu-tools do not get installed. 21. FIX: Use ACLOCAL_AMFLAGS instead of ACLOCAL = -I ... in Makefile.ams which are in directories with own configure scripts. 22. Hardcoding BSP names into libbsp/.../tools to avoid RTEMS_BSP get overridden from the environment. 22. FIX: Handling of MP_PIECES in various Makefiles 23. FIX: Removing "::" rules from some Makefile.ins 24. FIX: File permission chaos: (-m 444 and -m 555 vs. -m 644 and -m 755) - Now all include files use -m 644. 25. Removed many gnumake-conditionals in Makefile.ins - Partially replaced with automake-conditional, partially replaced with conditionalized Makefile variables (... _yes_V) 26. Massively reworked acpolish: acpolish now parses Makefile.ins and interprets parts of the Makefile.ins. 27. FIX: Some $(wildcard $(srcdir)/*.h) macros removed / replaced with explicit lists of files in Makefile.ins. 28. FIX: Replacing MKLIB with RANLIB in Makefile.ins 29. HACK: Add preinstallation for pc386 specific $(PROJECT_RELEASE)/BootImgs directory ... many more details, I can't recall KNOWN BUGS: 1. make [debug|profile]_install do not do what they are promissing. "make [debug|profile] install" does what "make [debug|profile]_install" has been doing. Proposal: remove [debug|profile]_install 2. Dependencies between temporary installation tree and source tree are not yet handled correctly. 3. Dependencies between temporary installation tree and source tree are handled ineffencently (Using INSTALL_CHANGE instead of make dependencies) 4. RTEMS_ROOT, PROJECT_ROOT, top_builddir, RTEMS_TOPdir now are redundant. 5. The new configure scripts still are in their infancy. They contain redundant checks and might still contain bugs, too. 6. RTEMS autoconf Makefile.ins use a mixture of configuration information gathered in c/$(target_alias)/<bsp>/make and of information collected from their configure scripts. 7. make dist is not fully functional 8. Subdirectory host-/build-/target- configure options (--target, --host, --build) do not conform to Cygnus/GNU conventions. 9. Some RTEMS autoconf Makefile.in's makefile targets are not supported in automake Makefile.ams/ins (e.g. get, clobber). 10. Some automake standard targets are not propagated from toplevel and c/Makefile.am to autoconf subdirectories (eg. make dist). 11. rpcgen generated files are not part of the source-tree (Automake conventions favor supplying generated files inside the source-tree, however there is no support for rpcgen generated files in automake, cf. yacc/lex support in automake). 12. RTEMS_HAS_RDBG handling is flaky. make/*.cfg use RTEMS_HAS_RDBG per CPU, while librdb's sources can only be built per BSP. Raises the more general question whether librdbg located correctly in the source-tree. 13. All make/*cfg files are configured per cpu, currently there is no location to store per-bsp configuration information --> bsp.cfg, per aconfig.h? 14. "make install" without having run "make all" beforehand does not work. 15. handling of --enable-multiprocessing seems to be broken in make/custom/* 16. Makefile.ins still exploit many gmake features. 17. File permisson chaos on libraries (no explict -m for libraries/rels/etc). 18. mcp750 Makefiles are broken (Note: I *do* mean buggy - I am not talking about "not-conforming to conventions", here :-). 19. Dependencies between configure scripts are not handled, eg. aborting "make RTEMS_BSP=<bsp>" can leave the build-tree in an unusable state. 20. "make clean" does not delete <build-tree>/<bsp>. This is intentional for now, because rerunning "make" after "make clean" requires an explicit "make preinstall" afterwards now. This should be done automatically, but doesn't work in this case for now. To work around this problem <build-tree>/<bsp> is kept during "make clean" for now (HACK). TODO: 1. split out host-compiled bsp-tools 2. Use Cygnus/GNU standards for cross-compiling target-subdir (CC=CC_FOR_TARGET .. configure --host=${target_alias} --build=`config.guess'}), to be added to toplevel configure script after splitting out bsp-tools. 3. Exploit per cpu support directory (c/src/<cpu>)- Splitting out per-cpu libraries - Are there any? 4. Further automake support 5. Converting subdirectories into standalone / self-contained subdirectories (Esp. moving their headers to the same common root as their sources, eg. mv lib/include/rtems++ lib/librtems++/include/rtems++) - This is the main obstacle which prevents moving further towards automake. 6. Propagating values from *.cfg into Makefiles instead of propagating them at make time via Makefile-fragments (i.e. try to avoid using *.cfg). 7. Testing on cygwin host (I *do* expect cygwin specific problems). 8. The ARCH in o-$(ARCH)-$(VARIANT) build-subdirectories is not needed anymore. GENERAL ISSUES: 1. Temporary installation tree -- Ian and I seem to disagree basically. Though I think that I understand his argumentation, I do not share it. IMO, his way of using the buildtree is mis-using the build-tree, relying on an inofficial feature of RTEMS's current implementation, which doesn't even work correctly in the current build-tree, though it attempts hard to do so. From my very POV, it unnecessarily complicates the structures of the source- and build-trees. It is not supported by automake (No automatic generation for the necessary rules) and complicates the transition to automake significantly (Generating the rules with an enhanced version of acpolish could be possible). As Ian correctly pointed out, here a management decision is needed - though I don't see the need to draw this decision in short terms. 2. preinstallation generally is a sure means to spoil the structure of the source tree, IMHO (No ranting intended, I am completly serious about this one). eg. through tree dependencies. The worst problem related to this I have found in the meantime is bsp_specs. bsp_specs is part of libbsp, ie. there is *no* way to build *any* part of the source tree *without* having a BSP *preinstalled*. Note: This issue is related to issue 1., but is not identical - The difference is the change of the order make rules have to be triggered. While preinstallation triggers rules spread all over the source tree before a "make all" can be run, a temporary installation tree could also be installed by post "make all" hooks (all-local:, to be run after make all in a directory is completed) if the directories' dependencies would be a tree, 3. Stuctural dependencies between subdirectories. 4. Depth of the source tree (Prevents multilibbing and introduces many unnecessary configure scripts). 5. per cpu vs. per bsp configuration (There are no real per-cpu parts yets :-). 6. automake does not support $makefiles in AC_OUTPUT. Unlike before, we now should try to avoid RTEMS_CHECK_MAKEFILE and to hard-code as much paths to Makefiles as possible. 7. General redesign of the source tree 8. Main installation point - Changing it to ${prefix}/${target_alias}. ? Besides item 8. (which is a must, IMHO), as far as I see most of them can not be solved soon and will remain issues in the mid- to long-term :-. REMARKS: * You (as the maintainer) should always use --enable-maintainer-mode when building RTEMS to ensure that maintainer mode generated files (esp. those in c/src/make) will be updated when make/* files have changed. * Use @RTEMS_BSP@ in Makefile.ins and Makefile.ams below c/src/, $(RTEMS_BSP) or ${RTEMS_BSP} will be overridden from environment variables when using make RTEMS_BSP="....". * c/src/make is a temporary cludge until configuration issues are solved. At the moment it is configured per bsp, but contains per-target/cpu info only. Its main purpose now is to circumvent modifying make/*.cfg files, because I consider make/* to be frozen for backward compatibilty. * This patch should only affect configuration files. At least I do not remember having touched any source files. * To build the bare bsp you now need to mention it in --enable-rtemsbsp. Example: building gensh1 and sh1/bare simultaneously: ../rtems-rc-19990709-1/configure --target=sh-rtems \ --enable-rtemsbsp="bare gensh1" \ --prefix=/tmp/rtems \ --enable-bare-cpu-cflags='-DMHZ=20 -m1 -DCPU_CONSOLE_DEVNAME=\"/dev/null\"' \ --enable-bare-cpu-model=sh7032 \ --enable-maintainer-mode \ --enable-cxx make make install * The next steps in development would be to split out bsp-tools and then to change to Cygnus/GNU canonicalization conventions for building the c/ subdirectory afterwards (i.e. many standard AC_*.m4 macros could be used instead of customized versions) FINAL REMARK: The issues mentioned in the lists above sound much worser than the situation actually is. Most of them are not specific to this patch, but are also valid for the snapshot. I just wrote down what I came across when working on the patch over the last few weeks. I wouldn't be too surprised if you don't like the patch at the current point in development. I am willing to discuss details and problems, I also have no problem if you would post-pone applying this patch to times after 4.1, but rejecting it as a whole for all times would be a false management decision, IMHO. Therefore I would suggest that you, if your time constaints allow it, should at least play a little while with this patch to understand what is going on and before drawing a decision on how to handle this proposal. I know this patch is neither perfect nor complete, but I consider it to be a major breakthrough. Don't be anxious because of the size of the patch, the core of the patch is rather small, the size is mainly the side effect of some systematic cleanups inside the Makefiles (result of acpolish). Feel free to ask if you encounter problems, if you don't understand something or if you meet bugs - I am far from being perfect and am prepared to answer them. Ralf. -- Ralf Corsepius Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung (FAW) Helmholtzstr. 16, 89081 Ulm, Germany Tel: +49/731/501-8690 mailto:corsepiu@faw.uni-ulm.de FAX: +49/731/501-999 http://www.faw.uni-ulm.de
* This is part of a major patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-07-2634-629/+2096
* Regenerated.Joel Sherrill1999-07-011-232/+147
* Patcg from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-06-168-138/+98
| | | | | | | -- configure now fails to detect the toolchain for linux-posix. As work-around, I have reverted to the old behavior of RTEMS_TARGET_CPU_NAME, thus no_cpu/no_bsp will fail badly in configure again.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-06-1511-66/+81
| | | | | | | | | | | | | | | | | | | | | | | | | | | | > When I run my script that just repeatedly builds different targets, some > of them die with an error like this: > > Making all RTEMS_BSP=gen68360 in cpugmake[5]: Entering directory > `/usr1/rtems/build/build-m68k-rtems/c/src/exec/score/cpu' > Making all RTEMS_BSP=gen68360 in @RTEMS_CPU@ > /bin/sh: @RTEMS_CPU@: No such file or directory > gmake[5]: *** [all] Error 1 > gmake[5]: Leaving directory > `/usr1/rtems/build/build-m68k-rtems/c/src/exec/score/cpu' > > It is not always the same variable substitution that fails. Sometimes it > is @INSTALL@. But reliably, it is a variable substitution that is > failing. > > Do you have any idea why this happens? Yep, I think I know what's going on. AC_SUBST(RTEMS_CPU) is missing in configure.ins, thus @RTEMS_CPU@ in target.cfg.in doesn't get substituted correctly, causing the bug above. Due to the redundancy of RTEMS_CPU, other most BSPs don't seem to be affected. Other similar problems probably exist for the unix/posix bsp and the hppa.1 cpu, because their */tools/*Makefile.ams require RTEMS_CPU, too.
* Patch ("FIX: no_cpu/no_bsp") from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-06-148-182/+194
| | | | | | | | | | | | | | | | | | | | | | | | | | | | This patch should fix the nastiest configuration bugs for no_cpu/no_bsp. With this patch applied, configure --target=no_cpu-rtems now correctly acknowledges its configuration, but later fails building when trying to build libcsupport (I leave this problem for you :-). Fixes/Changes: * aclocal/canonicalize-target-name.m4: use RTEMS_CPU instead of target_cpu, switch to a native compiler setup if target = no_cpu*rtems, ie. implicitly use host=target (native) and RTEMS_CPU=no_cpu for --target=no_cpu*rtems. * add no_bsp/bsp_specs (Support -qrtems, -qrtems_debug; please check before adding :-) * Use RTEMS_CANONICALIZE_TARGET_CPU instead of AC_CANONICAL_SYSTEM in toplevel/configure.in * All references to $target_cpu in aclocal/*.m4, Makefile.ins and *.cfg files changed to RTEMS_CPU * bug fixes to exec/score/cpu/no_cpu/wrap (This part of the patch may result into patch rejections, because your recently posted patch may also have addressed this problem). After applying this patch, please do: cvs add c/src/lib/libbsp/no_cpu/no_bsp/bsp_specs ./autogen
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-06-022-4/+12
| | | | | | | This patch fixes a nasty problem with build-tools/Makefile.am: When using install-sh instead of /usr/bin/install, only the first file gets installed during the preinstall stage.
* Regenerated.Joel Sherrill1999-05-273-214/+405
* Initiated updating this to reflect split up.Joel Sherrill1999-05-261-2/+4
* Regenerated.Joel Sherrill1999-05-183-405/+214
* Regenerated.Joel Sherrill1999-04-191-0/+1
* New files.Joel Sherrill1999-04-192-0/+4
* Regenerated.Joel Sherrill1999-04-195-50/+60
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to reorganizeJoel Sherrill1999-04-1930-4448/+300
| | | | | | | | | | | the build-tools layout to simplify it. This script reorganizes and simpilfies the build-tools subdirectories. It moves all source-files and scripts to c/build-tools/. This will enable use to use this directory directly to refer to the build-tools instead of copying them around in a "preinstall" step in future. However, RTEMS's autoconf Makefile.ins and *.cfg files are not yet prepared to apply this approach and therefore require additional work.
* New file -- automatically generated.Joel Sherrill1999-04-191-0/+1233
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-04-192-1/+16
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-04-161-2/+6
| | | | | | | | | | | | | | | | FYI: I am not talking about using "make -C <dir>", which probably is much faster on M$ hosts than RTEMS's implementation, but about removing --enable-gmake-print support and to apply a variant of automake's subdirectory. Automake's subdirectory rule seems to be a little bit faster, but I wouldn't bet on this. Attached to this mail is my proposal. After applying the patch, please run cvs rm aclocal/enable-gmake-print.m4 ./autogen
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-04-1220-528/+1342
* Regenerated.Joel Sherrill1999-03-316-567/+364
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-03-298-5/+245
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Yet some more modifications, I would recommend to be considered before releasing a snapshot: 1. Cleanup to aclocal/ cvs rm -f aclocal/cygwin.m4 cvs rm -f aclocal/exeext.m4 They are neither used nor needed anymore, however they also don't disturb (we use autoconf-2.13's AC_EXEEXT instead, now) ---------- 2. rtems-rc-19990328-0.diff Some (minor) bug-fixes: * make/Templates/Makefile.inc.in: use the new installation directory ($(prefix)/ instead of $(prefix)/rtems/) * c/src/exec/score/tools/generic/Makefile.am: added line to include local.am * c/src/exec/score/tools/*/configure.in: added CVS Id header ---------- 3. rtems-rc-19990328-1.diff Enhancements and cleanups to autogen, rtems-polish.sh, configure.in etc. * autogen: Use the file "VERSION" to detect RTEMS toplevel directory, extended usage-message, use "find -print" * c/update-tools/cipolish: New script to beautify configure.in scripts * c/update-tools/rtems-polish.sh: Use the file "VERSION" to detect RTEMS toplevel directory, extended usage-message, added variable for perl scripts' subdirectory, use "find -print", cipolish support, new options -ac -am -ci. * aclocal/*.m4, configure.in: moved some AC_SUBST lines to aclocal/*.m4 (reduces size of configure.in scripts, eases splitting configure.in scripts). ----------
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to fix size_rtemsJoel Sherrill1999-03-292-51/+7
| | | | problem.
* Regenerated.Joel Sherrill1999-03-251-40/+11
* These files were not added as part of a recent patch fromJoel Sherrill1999-03-2417-0/+6596
* Automake II patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. EmailJoel Sherrill1999-03-2315-167/+1342
