subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
direction. This fixes a problem reported by Steve Evans of Radstone
since he is using glibc2.
generated when egcs is used with "-Wall -pedantic".
enclose.
much target specific information in the script.
to lib/include.
be resolved.
Changed back to Newlib for Solaris UNIX simulator.
