path: root/tools (unfollow)
2015-09-03tools/cpu/nios2/ptf.c: Fix leak of memory pointed to by new_prefixMartin Galvan1-10/+14
Updates #2405.
2015-09-03tools/cpu/nios2/memory.c: Fix uninitialized use of variable memoryMartin Galvan1-3/+2
Updates #2405.
2015-03-24tools/cpu/nios2/ptf.c: Add include of <ctype.h>Joel Sherrill1-0/+1
2015-03-24tools/build/binpatch.c: Include <unistd.h> for getopt()Joel Sherrill1-0/+1
2015-03-22tools/build/rtems-test-check: Support multiple include filesJoel Sherrill1-1/+1
2015-03-09tools/cpu/sh/sci.c: Add include of bsp.h to generated fileJoel Sherrill1-0/+1
2015-02-23rtems-bin2c: Fix Windows buildSebastian Huber1-1/+1
Update #2238.
2015-02-23Use counted strnlen in bin2c. Closes #2238.Gedare Bloom1-1/+1
2015-01-23tools: Fix fprintf() statementSebastian Huber1-1/+1
Close #2240.
2015-01-13tools/cpu/nios2/ptf.c: Add include to fix warningsJoel Sherrill1-0/+1
2014-12-05Update bug report URLSebastian Huber5-5/+5
2014-12-02tools: Provide strnlen() if missingSebastian Huber4-3/+50
2014-11-27rtems-bin2c.c: Fix free() of altered pointerJoel Sherrill1-4/+5
2014-11-26tools/build/*.c: Clean up issues reported by CodeSonarJosh Oguin5-306/+309
This code is built without warnings and ignored by Coverity Scan. CodeSonar found a wide range of issues including buffer overruns, buffer underruns, questionable type conversions, leaks, etc. This set of patches addresses all reported issues.
2014-09-05tools: Remove invalid cpp characters from the header guards.Chris Johns1-8/+21
The waf converter in examples-v2 uses an absolute path and this creates defines with invalid characters.
2014-05-28rtems-test-check: Ignore tests which require real ISR based clock tickChris Johns1-3/+27
BSPs for simulators which do not include a clock tick interrupt source are incapable of running some tests successfully. This is a common characteristic of some BSPs and a fixed set of tests. There is no point in duplicating this list of tests in those BSPs test configuration. Read testsuites/testdata/require-tick-isr.tcfg for details.
2014-05-05testsuite: Add a per BSP test check for tests not to build.Chris Johns1-0/+52
Provide a file per BSP to list tests that do not build for a BSP. This change removes the BSP_SMALL_MEMORY hack from the code. That hack was a mistake. Provide configuration files for each BSP with tests that cannot build.
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns16-17/+17
2013-08-26Initialize the string before replacing charactersCynthia Rempel1-1/+1
2013-03-08RTEMS: Delete ChangeLog files.Gedare Bloom5-534/+0
This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain.
2012-07-19Require automake-1.12.2.Ralf Corsépius5-5/+5
2012-07-19Require autoconf-2.69.Ralf Corsépius5-5/+5
2012-05-11Remove CVS Id Strings (manual edits after script)Joel Sherrill6-25/+2
These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns.
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill34-88/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2012-05-07Revert: Remove CVS IdsJoel Sherrill10-0/+32
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details.
2012-05-04Remove CVS-Ids.Ralf Corsépius2-6/+0
2012-05-04Remove CVS-Ids.Ralf Corsépius2-8/+0
2012-02-01Remove all .cvsignore files.Joel Sherrill5-75/+0
2011-06-082011-06-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-0/+13
* config.h.in: Regenerated.
2011-05-17 * tools/build/.cvsignore, tools/build/ChangeLog,Joel Sherrill57-0/+7632
tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c, tools/build/cklength.c, tools/build/config.h.in, tools/build/configure.ac, tools/build/cvsignore-add.sh, tools/build/doxy-filter, tools/build/eolstrip.c, tools/build/install-if-change.in, tools/build/multigen, tools/build/packhex.c, tools/build/rtems-bin2c.c, tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac, tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog, tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac, tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore, tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am, tools/cpu/nios2/README, tools/cpu/nios2/bridges.c, tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c, tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac, tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h, tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h, tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h, tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c, tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c, tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf, tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING, tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO, tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h, tools/cpu/sh/shgen.c: New files.
2011-05-172011-05-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill122-13807/+0
* tools/build/.cvsignore, tools/build/ChangeLog, tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c, tools/build/cklength.c, tools/build/configure.ac, tools/build/cvsignore-add.sh, tools/build/doxy-filter, tools/build/eolstrip.c, tools/build/install-if-change.in, tools/build/multigen, tools/build/packhex.c, tools/build/rtems-bin2c.c, tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac, tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog, tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac, tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore, tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am, tools/cpu/nios2/README, tools/cpu/nios2/bridges.c, tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c, tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac, tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h, tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h, tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h, tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c, tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c, tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf, tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING, tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO, tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h, tools/cpu/sh/shgen.c, tools/schedsim/.cvsignore, tools/schedsim/ChangeLog, tools/schedsim/Makefile.am, tools/schedsim/README, tools/schedsim/configure.ac, tools/schedsim/rtems/.cvsignore, tools/schedsim/rtems/ChangeLog, tools/schedsim/rtems/Makefile.am, tools/schedsim/rtems/interr.c, tools/schedsim/rtems/rtems_init.c, tools/schedsim/rtems/rtems_sched.h, tools/schedsim/rtems/wkspace.c, tools/schedsim/rtems/sched_cpu/cpu.c, tools/schedsim/rtems/sched_cpu/cpu_asm.c, tools/schedsim/rtems/sched_cpu/rtems/asm.h, tools/schedsim/rtems/sched_cpu/rtems/stringto.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpu.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpu_asm.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpuopts.h, tools/schedsim/rtems/sched_cpu/rtems/score/no_cpu.h, tools/schedsim/rtems/sched_cpu/rtems/score/types.h, tools/schedsim/shell/.cvsignore, tools/schedsim/shell/ChangeLog, tools/schedsim/shell/Makefile.am, tools/schedsim/shell/schedsim_priority/.cvsignore, tools/schedsim/shell/schedsim_priority/Makefile.am, tools/schedsim/shell/schedsim_priority/config.c, tools/schedsim/shell/schedsim_priority/printheir_executing.c, tools/schedsim/shell/schedsim_priority/schedsim.cc, tools/schedsim/shell/schedsim_priority/wrap_thread_dispatch.c, tools/schedsim/shell/scripts/script01, tools/schedsim/shell/scripts/script02, tools/schedsim/shell/scripts/script03, tools/schedsim/shell/scripts/script04, tools/schedsim/shell/scripts/script05, tools/schedsim/shell/scripts/script06, tools/schedsim/shell/shared/.cvsignore, tools/schedsim/shell/shared/Makefile.am, tools/schedsim/shell/shared/commands.c, tools/schedsim/shell/shared/getopt.c, tools/schedsim/shell/shared/lookup_semaphore.c, tools/schedsim/shell/shared/lookup_task.c, tools/schedsim/shell/shared/main_clocktick.c, tools/schedsim/shell/shared/main_echo.c, tools/schedsim/shell/shared/main_executing.c, tools/schedsim/shell/shared/main_heir.c, tools/schedsim/shell/shared/main_help.c, tools/schedsim/shell/shared/main_rtemsinit.c, tools/schedsim/shell/shared/main_semcreate.c, tools/schedsim/shell/shared/main_semdelete.c, tools/schedsim/shell/shared/main_semflush.c, tools/schedsim/shell/shared/main_semobtain.c, tools/schedsim/shell/shared/main_semrelease.c, tools/schedsim/shell/shared/main_taskcreate.c, tools/schedsim/shell/shared/main_taskdelete.c, tools/schedsim/shell/shared/main_taskmode.c, tools/schedsim/shell/shared/main_taskpriority.c, tools/schedsim/shell/shared/main_taskresume.c, tools/schedsim/shell/shared/main_tasksuspend.c, tools/schedsim/shell/shared/main_taskwakeafter.c, tools/schedsim/shell/shared/schedsim_shell.h, tools/schedsim/shell/shared/shell_cmdset.c, tools/schedsim/shell/shared/shell_makeargs.c, tools/schedsim/shell/shared/include/shell.h, tools/schedsim/shell/shared/include/newlib/_ansi.h, tools/schedsim/shell/shared/include/newlib/getopt.h: Removed. * configure.ac: RTEMS Scheduler Simulator is now in its own CVS module named rtems-schedsim.
2011-05-132011-05-13 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius3-5/+12
* rtems/interr.c: Minimize diffs to cpukit/score/src/interr.c. * rtems/sched_cpu/rtems/score/cpu.h: Incorporate parts of former posix BSP.
2011-04-212011-04-21 Jennifer Averett <Jennifer.Averett@OARcorp.comJennifer Averett1-1/+1
PR 1777/cpukit * tools/schedsim/rtems/rtems_init.c: Consolidated access to _Thread_Dispatch_disable_level.
2011-04-112011-04-11 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-0/+5
* Makefile.am: Add schedulersimple.h
2011-04-072011-04-07 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-0/+104
* README: New file.
2011-04-072011-04-07 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill15-2/+50
* shared/main_clocktick.c, shared/main_semcreate.c, shared/main_semdelete.c, shared/main_semflush.c, shared/main_semobtain.c, shared/main_semrelease.c, shared/main_taskcreate.c, shared/main_taskdelete.c, shared/main_taskmode.c, shared/main_taskpriority.c, shared/main_taskresume.c, shared/main_tasksuspend.c, shared/main_taskwakeafter.c, shared/schedsim_shell.h: Compiles now and do not core dump when RTEMS is not initialized.
2011-04-072011-04-07 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill3-8/+24
* Makefile.am, wkspace.c: Compiles now and do not core dump when RTEMS is not initialized.
2011-02-282011-02-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-2/+6
* sched_cpu/rtems/score/cpuopts.h: Bump to 4.10.99.0
2011-02-022011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius12-11/+35
2011-01-292011-01-28 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-5/+14
* configure.ac: Remove RTEMS_PATH_KSH (Unused). Require autoconf >= 2.68, automake >= 1.11.1. Add AC_PROG_CC_C99 to enforce c99 hoping this will suffice to make this stuff compilable with older GCCs (works on some hosts).
2010-12-172010-12-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill4-0/+66
Jennifer Averett <jennifer.averett@oarcorp.com> Add RTEMS Scheduler Simulator. This is the top level of the tree. * .cvsignore, ChangeLog, Makefile.am, configure.ac: New files.
2010-12-172010-12-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-0/+6
* .cvsignore: New file.
2010-12-172010-12-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill15-0/+2708
Jennifer Averett <jennifer.averett@oarcorp.com> Add RTEMS Scheduler Simulator. This is the RTEMS "port" to and adapter code to run on GNU/Linux with a fake context switch. * ChangeLog, Makefile.am, interr.c, rtems_init.c, rtems_sched.h, wkspace.c, sched_cpu/cpu.c, sched_cpu/cpu_asm.c, sched_cpu/rtems/asm.h, sched_cpu/rtems/stringto.h, sched_cpu/rtems/score/cpu.h, sched_cpu/rtems/score/cpu_asm.h, sched_cpu/rtems/score/cpuopts.h, sched_cpu/rtems/score/no_cpu.h, sched_cpu/rtems/score/types.h: New files.
2010-12-172010-12-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill45-0/+3253
Jennifer Averett <jennifer.averett@oarcorp.com> Add RTEMS Scheduler Simulator. This is the shell scripting portion. * .cvsignore, ChangeLog, Makefile.am, schedsim_priority/.cvsignore, schedsim_priority/Makefile.am, schedsim_priority/config.c, schedsim_priority/printheir_executing.c, schedsim_priority/schedsim.cc, schedsim_priority/wrap_thread_dispatch.c, scripts/script01, scripts/script02, scripts/script03, scripts/script04, scripts/script05, scripts/script06, shared/.cvsignore, shared/Makefile.am, shared/commands.c, shared/getopt.c, shared/lookup_semaphore.c, shared/lookup_task.c, shared/main_clocktick.c, shared/main_echo.c, shared/main_executing.c, shared/main_heir.c, shared/main_help.c, shared/main_rtemsinit.c, shared/main_semcreate.c, shared/main_semdelete.c, shared/main_semflush.c, shared/main_semobtain.c, shared/main_semrelease.c, shared/main_taskcreate.c, shared/main_taskdelete.c, shared/main_taskmode.c, shared/main_taskpriority.c, shared/main_taskresume.c, shared/main_tasksuspend.c, shared/main_taskwakeafter.c, shared/schedsim_shell.h, shared/shell_cmdset.c, shared/shell_makeargs.c, shared/include/shell.h, shared/include/newlib/_ansi.h, shared/include/newlib/getopt.h: New files.
2010-07-302010-07-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-2/+11
* rtems-bin2c.c: Fix memory leak in '.c' suffix strip. Also strip '.h' suffix.
2010-07-302010-07-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-1/+5
* rtems-bin2c.c: Make -v (verbose) working.
2010-07-302010-07-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius3-13/+15
* configure.ac: Check for libgen.h, basename. * rtems-bin2c.c: Use basename(3) instead of strrchr cascade. Introduce ifbasename. Use ifbasename in generated files.
