path: root/tools (follow)
* tools/cpu/nios2/ptf.c: Fix leak of memory pointed to by new_prefixMartin Galvan2015-09-031-10/+14
| | | | Updates #2405.
* tools/cpu/nios2/memory.c: Fix uninitialized use of variable memoryMartin Galvan2015-09-031-3/+2
| | | | Updates #2405.
* tools/cpu/nios2/ptf.c: Add include of <ctype.h>Joel Sherrill2015-03-241-0/+1
* tools/build/binpatch.c: Include <unistd.h> for getopt()Joel Sherrill2015-03-241-0/+1
* tools/build/rtems-test-check: Support multiple include filesJoel Sherrill2015-03-221-1/+1
* tools/cpu/sh/sci.c: Add include of bsp.h to generated fileJoel Sherrill2015-03-091-0/+1
* rtems-bin2c: Fix Windows buildSebastian Huber2015-02-231-1/+1
| | | | Update #2238.
* Use counted strnlen in bin2c. Closes #2238.Gedare Bloom2015-02-231-1/+1
* tools: Fix fprintf() statementSebastian Huber2015-01-231-1/+1
| | | | Close #2240.
* tools/cpu/nios2/ptf.c: Add include to fix warningsJoel Sherrill2015-01-131-0/+1
* Update bug report URLSebastian Huber2014-12-055-5/+5
* tools: Provide strnlen() if missingSebastian Huber2014-12-024-3/+50
* rtems-bin2c.c: Fix free() of altered pointerJoel Sherrill2014-11-271-4/+5
* tools/build/*.c: Clean up issues reported by CodeSonarJosh Oguin2014-11-265-306/+309
| | | | | | | This code is built without warnings and ignored by Coverity Scan. CodeSonar found a wide range of issues including buffer overruns, buffer underruns, questionable type conversions, leaks, etc. This set of patches addresses all reported issues.
* tools: Remove invalid cpp characters from the header guards.Chris Johns2014-09-051-8/+21
| | | | | The waf converter in examples-v2 uses an absolute path and this creates defines with invalid characters.
* rtems-test-check: Ignore tests which require real ISR based clock tickChris Johns2014-05-281-3/+27
| | | | | | | | | BSPs for simulators which do not include a clock tick interrupt source are incapable of running some tests successfully. This is a common characteristic of some BSPs and a fixed set of tests. There is no point in duplicating this list of tests in those BSPs test configuration. Read testsuites/testdata/require-tick-isr.tcfg for details.
* testsuite: Add a per BSP test check for tests not to build.Chris Johns2014-05-051-0/+52
| | | | | | | | Provide a file per BSP to list tests that do not build for a BSP. This change removes the BSP_SMALL_MEMORY hack from the code. That hack was a mistake. Provide configuration files for each BSP with tests that cannot build.
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-2116-17/+17
* Initialize the string before replacing charactersCynthia Rempel2013-08-261-1/+1
* RTEMS: Delete ChangeLog files.Gedare Bloom2013-03-085-534/+0
| | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain.
* Require automake-1.12.2.Ralf Corsépius2012-07-195-5/+5
* Require autoconf-2.69.Ralf Corsépius2012-07-195-5/+5
* Remove CVS Id Strings (manual edits after script)Joel Sherrill2012-05-116-25/+2
| | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns.
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-1134-88/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-0710-0/+32
* Remove CVS-Ids.Ralf Corsépius2012-05-042-6/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-042-8/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-015-75/+0
* 2011-06-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-082-0/+13
| | | | * config.h.in: Regenerated.
* * tools/build/.cvsignore, tools/build/ChangeLog,Joel Sherrill2011-05-1757-0/+7632
| | | | | | | | | | | | | | | | | | | | | | | | | | | | tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c, tools/build/cklength.c, tools/build/config.h.in, tools/build/configure.ac, tools/build/cvsignore-add.sh, tools/build/doxy-filter, tools/build/eolstrip.c, tools/build/install-if-change.in, tools/build/multigen, tools/build/packhex.c, tools/build/rtems-bin2c.c, tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac, tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog, tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac, tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore, tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am, tools/cpu/nios2/README, tools/cpu/nios2/bridges.c, tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c, tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac, tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h, tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h, tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h, tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c, tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c, tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf, tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING, tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO, tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h, tools/cpu/sh/shgen.c: New files.
* 2011-05-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-05-17122-13807/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tools/build/.cvsignore, tools/build/ChangeLog, tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c, tools/build/cklength.c, tools/build/configure.ac, tools/build/cvsignore-add.sh, tools/build/doxy-filter, tools/build/eolstrip.c, tools/build/install-if-change.in, tools/build/multigen, tools/build/packhex.c, tools/build/rtems-bin2c.c, tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac, tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog, tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac, tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore, tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am, tools/cpu/nios2/README, tools/cpu/nios2/bridges.c, tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c, tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac, tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h, tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h, tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h, tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c, tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c, tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf, tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING, tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO, tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h, tools/cpu/sh/shgen.c, tools/schedsim/.cvsignore, tools/schedsim/ChangeLog, tools/schedsim/Makefile.am, tools/schedsim/README, tools/schedsim/configure.ac, tools/schedsim/rtems/.cvsignore, tools/schedsim/rtems/ChangeLog, tools/schedsim/rtems/Makefile.am, tools/schedsim/rtems/interr.c, tools/schedsim/rtems/rtems_init.c, tools/schedsim/rtems/rtems_sched.h, tools/schedsim/rtems/wkspace.c, tools/schedsim/rtems/sched_cpu/cpu.c, tools/schedsim/rtems/sched_cpu/cpu_asm.c, tools/schedsim/rtems/sched_cpu/rtems/asm.h, tools/schedsim/rtems/sched_cpu/rtems/stringto.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpu.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpu_asm.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpuopts.h, tools/schedsim/rtems/sched_cpu/rtems/score/no_cpu.h, tools/schedsim/rtems/sched_cpu/rtems/score/types.h, tools/schedsim/shell/.cvsignore, tools/schedsim/shell/ChangeLog, tools/schedsim/shell/Makefile.am, tools/schedsim/shell/schedsim_priority/.cvsignore, tools/schedsim/shell/schedsim_priority/Makefile.am, tools/schedsim/shell/schedsim_priority/config.c, tools/schedsim/shell/schedsim_priority/printheir_executing.c, tools/schedsim/shell/schedsim_priority/schedsim.cc, tools/schedsim/shell/schedsim_priority/wrap_thread_dispatch.c, tools/schedsim/shell/scripts/script01, tools/schedsim/shell/scripts/script02, tools/schedsim/shell/scripts/script03, tools/schedsim/shell/scripts/script04, tools/schedsim/shell/scripts/script05, tools/schedsim/shell/scripts/script06, tools/schedsim/shell/shared/.cvsignore, tools/schedsim/shell/shared/Makefile.am, tools/schedsim/shell/shared/commands.c, tools/schedsim/shell/shared/getopt.c, tools/schedsim/shell/shared/lookup_semaphore.c, tools/schedsim/shell/shared/lookup_task.c, tools/schedsim/shell/shared/main_clocktick.c, tools/schedsim/shell/shared/main_echo.c, tools/schedsim/shell/shared/main_executing.c, tools/schedsim/shell/shared/main_heir.c, tools/schedsim/shell/shared/main_help.c, tools/schedsim/shell/shared/main_rtemsinit.c, tools/schedsim/shell/shared/main_semcreate.c, tools/schedsim/shell/shared/main_semdelete.c, tools/schedsim/shell/shared/main_semflush.c, tools/schedsim/shell/shared/main_semobtain.c, tools/schedsim/shell/shared/main_semrelease.c, tools/schedsim/shell/shared/main_taskcreate.c, tools/schedsim/shell/shared/main_taskdelete.c, tools/schedsim/shell/shared/main_taskmode.c, tools/schedsim/shell/shared/main_taskpriority.c, tools/schedsim/shell/shared/main_taskresume.c, tools/schedsim/shell/shared/main_tasksuspend.c, tools/schedsim/shell/shared/main_taskwakeafter.c, tools/schedsim/shell/shared/schedsim_shell.h, tools/schedsim/shell/shared/shell_cmdset.c, tools/schedsim/shell/shared/shell_makeargs.c, tools/schedsim/shell/shared/include/shell.h, tools/schedsim/shell/shared/include/newlib/_ansi.h, tools/schedsim/shell/shared/include/newlib/getopt.h: Removed. * configure.ac: RTEMS Scheduler Simulator is now in its own CVS module named rtems-schedsim.
* 2011-05-13 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-05-133-5/+12
| | | | | | * rtems/interr.c: Minimize diffs to cpukit/score/src/interr.c. * rtems/sched_cpu/rtems/score/cpu.h: Incorporate parts of former posix BSP.
* 2011-04-21 Jennifer Averett <Jennifer.Averett@OARcorp.comJennifer Averett2011-04-211-1/+1
| | | | | | PR 1777/cpukit * tools/schedsim/rtems/rtems_init.c: Consolidated access to _Thread_Dispatch_disable_level.
* 2011-04-11 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-04-112-0/+5
| | | | * Makefile.am: Add schedulersimple.h
* 2011-04-07 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-04-072-0/+104
| | | | * README: New file.
* 2011-04-07 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-04-0715-2/+50
| | | | | | | | | | | * shared/main_clocktick.c, shared/main_semcreate.c, shared/main_semdelete.c, shared/main_semflush.c, shared/main_semobtain.c, shared/main_semrelease.c, shared/main_taskcreate.c, shared/main_taskdelete.c, shared/main_taskmode.c, shared/main_taskpriority.c, shared/main_taskresume.c, shared/main_tasksuspend.c, shared/main_taskwakeafter.c, shared/schedsim_shell.h: Compiles now and do not core dump when RTEMS is not initialized.
* 2011-04-07 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-04-073-8/+24
| | | | | * Makefile.am, wkspace.c: Compiles now and do not core dump when RTEMS is not initialized.
* 2011-02-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-02-282-2/+6
| | | | * sched_cpu/rtems/score/cpuopts.h: Bump to 4.10.99.0
* 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-0212-11/+35
| | | | * configure.ac: Require autoconf-2.68, automake-1.11.1.
* 2011-01-28 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-01-292-5/+14
| | | | | | | * configure.ac: Remove RTEMS_PATH_KSH (Unused). Require autoconf >= 2.68, automake >= 1.11.1. Add AC_PROG_CC_C99 to enforce c99 hoping this will suffice to make this stuff compilable with older GCCs (works on some hosts).
* 2010-12-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-12-174-0/+66
| | | | | | | Jennifer Averett <jennifer.averett@oarcorp.com> Add RTEMS Scheduler Simulator. This is the top level of the tree. * .cvsignore, ChangeLog, Makefile.am, configure.ac: New files.
* 2010-12-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-12-172-0/+6
| | | | * .cvsignore: New file.
* 2010-12-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-12-1715-0/+2708
| | | | | | | | | | | | | Jennifer Averett <jennifer.averett@oarcorp.com> Add RTEMS Scheduler Simulator. This is the RTEMS "port" to and adapter code to run on GNU/Linux with a fake context switch. * ChangeLog, Makefile.am, interr.c, rtems_init.c, rtems_sched.h, wkspace.c, sched_cpu/cpu.c, sched_cpu/cpu_asm.c, sched_cpu/rtems/asm.h, sched_cpu/rtems/stringto.h, sched_cpu/rtems/score/cpu.h, sched_cpu/rtems/score/cpu_asm.h, sched_cpu/rtems/score/cpuopts.h, sched_cpu/rtems/score/no_cpu.h, sched_cpu/rtems/score/types.h: New files.
* 2010-12-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-12-1745-0/+3253
| | | | | | | | | | | | | | | | | | | | | | | | | | | Jennifer Averett <jennifer.averett@oarcorp.com> Add RTEMS Scheduler Simulator. This is the shell scripting portion. * .cvsignore, ChangeLog, Makefile.am, schedsim_priority/.cvsignore, schedsim_priority/Makefile.am, schedsim_priority/config.c, schedsim_priority/printheir_executing.c, schedsim_priority/schedsim.cc, schedsim_priority/wrap_thread_dispatch.c, scripts/script01, scripts/script02, scripts/script03, scripts/script04, scripts/script05, scripts/script06, shared/.cvsignore, shared/Makefile.am, shared/commands.c, shared/getopt.c, shared/lookup_semaphore.c, shared/lookup_task.c, shared/main_clocktick.c, shared/main_echo.c, shared/main_executing.c, shared/main_heir.c, shared/main_help.c, shared/main_rtemsinit.c, shared/main_semcreate.c, shared/main_semdelete.c, shared/main_semflush.c, shared/main_semobtain.c, shared/main_semrelease.c, shared/main_taskcreate.c, shared/main_taskdelete.c, shared/main_taskmode.c, shared/main_taskpriority.c, shared/main_taskresume.c, shared/main_tasksuspend.c, shared/main_taskwakeafter.c, shared/schedsim_shell.h, shared/shell_cmdset.c, shared/shell_makeargs.c, shared/include/shell.h, shared/include/newlib/_ansi.h, shared/include/newlib/getopt.h: New files.
* 2010-07-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-07-302-2/+11
| | | | | * rtems-bin2c.c: Fix memory leak in '.c' suffix strip. Also strip '.h' suffix.
* 2010-07-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-07-302-1/+5
| | | | * rtems-bin2c.c: Make -v (verbose) working.
* 2010-07-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-07-303-13/+15
| | | | | | * configure.ac: Check for libgen.h, basename. * rtems-bin2c.c: Use basename(3) instead of strrchr cascade. Introduce ifbasename. Use ifbasename in generated files.
