* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* cvsignore-add.sh: Script to append a specific file to all
.cvsignore files if the files exists is a specific directory.
* Makefile.am: genoffsets must be built before the executive.
* tools/Makefile.am: Build the cpu dependent tools as well.
* lock-directory.in, unlock-directory.in: Removed.
* Makefile.am, README, .cvsignore: Updated to reflect above.
* configure.ac: Remove AC_EXEEXT (obsolete).
* sh/COPYING: Readded. Deleting this violated GPL on shgen.
* sh/COPYING: Deleted.
* sh/Makefile.am: Use "./shgen" not "shgen" so current directory
does not have to be in the PATH.
* Makefile.am: Remove unix from DIST_SUBDIRS.
* Per PR150, unix directory and contents removed.
* unix/, unix/ChangeLog, unix/Makefile.am, unix/configure.ac,
unix/gensize.c: Deleted.
* tools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
* configure.in: AC_PREREQ(2.52), apply RTEMS_CPU_SUBDIRS.
* configure.in: Reworked for Canadian Cross support.
* config.guess, config.sub: Update from subversions.gnu.org.
* README.cdn-X: New file.
* tools/Makefile.am: Remove build, tools from SUBDIRS.
* config.h.in: Automatically generated. Remove from CVS.
* shgen.c: Set default Phi to 20MHz (BUG-FIX).
* ampolish: Generate ACLOCAL_AMFLAGS = -I .../aclocal.
* Makefile.am: Switch to GNU-canonicalized autoconf macros.
* multigen: Fix BARE_CPU_CFLAGS.
* multigen: Fix usage.
* ampolish: Add rules to add compile.am
that is a cosmetic patch to ampolish.
that adds multigen to the list of noinst_SCRIPTS.
CVS:
CVS: Committing in .
CVS:
CVS: Modified Files:
<corsepiu@faw.uni-ulm.de> to update multigen.
that contains:
* Removes MKLIB
handling)
that should not have been.
which is described below:
break something.
SUBDIRS in a Makefile.am)
* An update to gensh2.cfg.
cd <srcdir>
in the previous commits.
His comments follow:
This is a minor enhancement to shgen, which should not have any
side-effects.
for RTEMS.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
