* | Ralf Corsepius reported a number of missing CVS Id's: | Joel Sherrill | 1998-01-16 | 1 | -0/+2 | |
| | | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose. | |||||
* | Modified a lot of files to take a first cut at supporting building from | Joel Sherrill | 1997-12-10 | 1 | -1/+4 | |
| | | | | | any directory in the build tree. The only variable which must be set before the command "gmake" is invoked is RTEMS_BSP (e.g. RTEMS_BSP=erc32). | |||||
* | This set of changes is the build of what was required to convert to | Joel Sherrill | 1997-04-01 | 1 | -0/+37 | |
| | | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved. | |||||
* | Initial revision | Joel Sherrill | 1995-05-11 | 2 | -0/+550 | |
