BSDINSTALL=@INSTALL@
in autoconf.
fixed.
sources files.
TARGET_VARIANTS
NOTE:
FINALLY:
to each Makefile.in.
* c/src/exec/score/tools/sh - NEW DIRECTORY - contains shgen
Most of it should be self-explanatory. I am a little bit concerned about
host-dependent features (getopt, floating point libraries). This
shouldn't disturb much now, as this tool should be compileable on all
gnu-based hosts and is only applicable for the sh. But in case somebody
complains, we may need to add autoconf checks or even restructurize
parts of rtems (IMO, rtems needs to be restructurized - remember the
"turning rtems upside down" issue).
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
GNU tool bc which is not always installed under Linux and seldom
present under non-UNIX environments like Win32.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
much target specific information in the script.
to lib/include.
be resolved.
Changed back to Newlib for Solaris UNIX simulator.
