* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* Makefile.am: genoffsets must be built before the executive.
* configure.ac: Remove AC_EXEEXT (obsolete).
* sh/COPYING: Readded. Deleting this violated GPL on shgen.
* sh/COPYING: Deleted.
* sh/Makefile.am: Use "./shgen" not "shgen" so current directory
does not have to be in the PATH.
* Makefile.am: Remove unix from DIST_SUBDIRS.
* Per PR150, unix directory and contents removed.
* unix/, unix/ChangeLog, unix/Makefile.am, unix/configure.ac,
unix/gensize.c: Deleted.
* configure.in: Remove.
* configure.in: AC_PREREQ(2.52), apply RTEMS_CPU_SUBDIRS.
* shgen.c: Set default Phi to 20MHz (BUG-FIX).
* Makefile.am: Switch to GNU-canonicalized autoconf macros.
that contains:
* Removes MKLIB
handling)
His comments follow:
This is a minor enhancement to shgen, which should not have any
side-effects.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
> When I run my script that just repeatedly builds different targets, some
> of them die with an error like this:
> Making all RTEMS_BSP=gen68360 in cpugmake[5]: Entering directory
> `/usr1/rtems/build/build-m68k-rtems/c/src/exec/score/cpu'
> Making all RTEMS_BSP=gen68360 in @RTEMS_CPU@
> /bin/sh: @RTEMS_CPU@: No such file or directory
> gmake[5]: *** [all] Error 1
> gmake[5]: Leaving directory
> It is not always the same variable substitution that fails. Sometimes it
> is @INSTALL@. But reliably, it is a variable substitution that is
> failing.
> Do you have any idea why this happens?
Yep, I think I know what's going on.
AC_SUBST(RTEMS_CPU) is missing in configure.ins, thus @RTEMS_CPU@ in
target.cfg.in doesn't get substituted correctly, causing the bug above. Due
to the redundancy of RTEMS_CPU, other most BSPs don't seem to be affected.
Other similar problems probably exist for the unix/posix bsp and the hppa.1
cpu, because their */tools/*Makefile.ams require RTEMS_CPU, too.
Fixes/Changes:
--target=no_cpu*rtems.
before adding :-)
toplevel/configure.in
files changed to RTEMS_CPU
future.
cd <rtems-source-tree>
preparations for automake.
* aclocal/rtems-top.m4:
releasing a snapshot:
1. Cleanup to aclocal/
cvs rm -f aclocal/cygwin.m4
cvs rm -f aclocal/exeext.m4
2. rtems-rc-19990328-0.diff
Some (minor) bug-fixes:
3. rtems-rc-19990328-1.diff
-ac -am -ci.
(reduces size of configure.in
problem.
