path: root/tools/cpu (follow)
* Fix indentation.Ralf Corsepius2007-01-271-7/+7
* 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-12-028-4/+20
| | | | * configure.ac: New BUG-REPORT address.
* 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-178-8/+24
| | | | * configure.ac: Require autoconf-2.60. Require automake-1.10.
* 2006-08-15 Kolja Waschk <kawk@telos.de>Joel Sherrill2006-08-1515-115/+1283
| | | | | | | | | | | | | | * linkcmds.c, linkcmds.h, memory.c, memory.h, sample.ptf: New files. * bridges.c: corrected detection of bridged connections * clocks.c: removed a printf * linkcmds.[ch] new files, added output of linker script * Makefile.am: added new files * memory.[ch]: new files, detection of memory in SOPC configuration * nios2gen.c: updated command line parsing and output control * output.[ch]: improved output of BSP header file * ptf.[ch]: added ptf_dump_ptf_item and small fixes * sample.ptf: new file, sample configuration for nios2gen * README: updated
* 2006-08-10 Joel Sherrill <joel@oarcorp.com>Joel Sherrill2006-08-102-3/+37
| | | | | | | | * nios2gen.c: Added some very basic support for --help and --version options along with output that is roughly in GNU format. This is required by help2man. help2man expects this all to be written to stdout instead of stderr so this was changed as well. * ChangeLog: New file.
* 2006-08-09 Kolja Waschk <waschk@telos.de>Joel Sherrill2006-08-0917-0/+1837
| | | | | | | | * configure.ac: New port to Altera NIOS II. * nios2/.cvsignore, nios2/Makefile.am, nios2/README, nios2/bridges.c, nios2/bridges.h, nios2/clocks.c, nios2/clocks.h, nios2/configure.ac, nios2/devices.c, nios2/devices.h, nios2/nios2gen.c, nios2/output.c, nios2/output.h, nios2/ptf.c, nios2/ptf.h: New files.
* 2006-01-31 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-01-312-1/+6
| | | | * shgen.c: include <stdlib.h>.
* Fix typo in previous change.Ralf Corsepius2004-09-243-3/+3
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-246-3/+15
| | | | * configure.ac: Require automake > 1.9.
* 2004-09-24 Ralf Corsepius <ralf_corsepiu@rtems.org>Ralf Corsepius2004-09-242-1/+7
| | | | * configure.ac: Remove RTEMS_CPU_SUBDIRS.
* Remove stray white spaces.Ralf Corsepius2004-04-202-27/+27
* 2004-02-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-042-1/+5
| | | | * Makefile.am: DIST_SUBDIRS = @subdirs@.
* 2004-01-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-062-1/+5
| | | | * Makefile.am: Let shgen.1 depend on shgen$(EXEEXT).
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-126-6/+18
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-0/+5
| | | | * Makefile.am: Cosmetics.
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-262-1/+5
| | | | * Makefile.am: Obsoleting HP PA-RISC port.
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-266-463/+5
| | | | | * hppa1.1/.cvsignore, hppa1.1/ChangeLog, hppa1.1/Makefile.am, hppa1.1/configure.ac, hppa1.1/genoffsets.c: Removed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-042-2/+6
| | | | * genoffsets.c: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-042-1/+5
| | | | * size_rtems.in: URL for license changed.
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-118-4/+20
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-118-4/+16
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-118-4/+20
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-218-12/+36
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2002-06-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-06-272-0/+6
| | | | * Makefile.am: genoffsets must be built before the executive.
* 2002-04-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-034-2/+8
| | | | * configure.ac: Remove AC_EXEEXT (obsolete).
* 2001-04-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-032-0/+348
| | | | * sh/COPYING: Readded. Deleting this violated GPL on shgen.
* 2001-04-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-022-19/+4
| | | | * sh/COPYING: Deleted.
* 2001-04-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-022-1/+6
| | | | | * sh/Makefile.am: Use "./shgen" not "shgen" so current directory does not have to be in the PATH.
* 2001-04-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-022-1/+5
| | | | * Makefile.am: Remove unix from DIST_SUBDIRS.
* 2001-03-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-296-192/+6
| | | | | | * Per PR150, unix directory and contents removed. * unix/, unix/ChangeLog, unix/Makefile.am, unix/configure.ac, unix/gensize.c: Deleted.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2815-15/+45
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-125-0/+123
| | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-125-109/+0
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1110-0/+35
* 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-112-3/+6
| | | | * configure.in: AC_PREREQ(2.52), apply RTEMS_CPU_SUBDIRS.
* 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-152-2/+6
| | | | * shgen.c: Set default Phi to 20MHz (BUG-FIX).
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-0910-5/+25
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-0210-5/+25
* 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-3110-5/+25
| | | | * Makefile.am: Switch to GNU-canonicalized autoconf macros.
* Adding ChangeLogs.Joel Sherrill2000-08-105-0/+15
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-129-44/+87
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-135-0/+66
| | | | adds .cvsignore.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-085-4/+9
* Updated copyright notice.Joel Sherrill1999-11-173-8/+5
* Patch rtems-rc-19991105-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill1999-11-173-7/+25
| | | | | | | His comments follow: This is a minor enhancement to shgen, which should not have any side-effects.
* Removed aclocal.m4 generated from aclocal macrosJoel Sherrill1999-10-065-1360/+0
* Removed configure generated from configure.inJoel Sherrill1999-10-065-7616/+0
* Regenerated.Joel Sherrill1999-10-0510-429/+449
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-045-16/+16
