path: root/tools/cpu/unix/Makefile.in (unfollow)
1997-10-08Removed include directory at "build" point and the link of this directoryJoel Sherrill1-1/+1
to lib/include. Went to using a PROJECT_INCLUDE variable.
1997-04-01This set of changes is the build of what was required to convert toJoel Sherrill1-0/+61
