These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
for details.
tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c,
tools/build/cklength.c, tools/build/config.h.in,
tools/build/configure.ac, tools/build/cvsignore-add.sh,
tools/build/doxy-filter, tools/build/eolstrip.c,
tools/build/install-if-change.in, tools/build/multigen,
tools/build/packhex.c, tools/build/rtems-bin2c.c,
tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore,
tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac,
tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog,
tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac,
tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore,
tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am,
tools/cpu/nios2/README, tools/cpu/nios2/bridges.c,
tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c,
tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac,
tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h,
tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h,
tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h,
tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c,
tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c,
tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf,
tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING,
tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO,
tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h,
tools/cpu/sh/shgen.c: New files.
* tools/build/.cvsignore, tools/build/ChangeLog,
tools/build/cklength.c, tools/build/configure.ac,
tools/build/cvsignore-add.sh, tools/build/doxy-filter,
tools/build/eolstrip.c, tools/build/install-if-change.in,
tools/build/multigen, tools/build/packhex.c,
tools/build/rtems-bin2c.c, tools/build/search-id.sh,
tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog,
tools/cpu/sh/shgen.c, tools/schedsim/.cvsignore,
tools/schedsim/ChangeLog, tools/schedsim/Makefile.am,
tools/schedsim/README, tools/schedsim/configure.ac,
tools/schedsim/rtems/.cvsignore, tools/schedsim/rtems/ChangeLog,
tools/schedsim/rtems/Makefile.am, tools/schedsim/rtems/interr.c,
tools/schedsim/rtems/rtems_init.c,
tools/schedsim/rtems/rtems_sched.h, tools/schedsim/rtems/wkspace.c,
tools/schedsim/rtems/sched_cpu/cpu.c,
tools/schedsim/rtems/sched_cpu/cpu_asm.c,
tools/schedsim/rtems/sched_cpu/rtems/asm.h,
tools/schedsim/rtems/sched_cpu/rtems/stringto.h,
tools/schedsim/rtems/sched_cpu/rtems/score/cpu.h,
tools/schedsim/rtems/sched_cpu/rtems/score/cpu_asm.h,
tools/schedsim/rtems/sched_cpu/rtems/score/cpuopts.h,
tools/schedsim/rtems/sched_cpu/rtems/score/no_cpu.h,
tools/schedsim/rtems/sched_cpu/rtems/score/types.h,
tools/schedsim/shell/.cvsignore, tools/schedsim/shell/ChangeLog,
tools/schedsim/shell/Makefile.am,
tools/schedsim/shell/schedsim_priority/.cvsignore,
tools/schedsim/shell/schedsim_priority/Makefile.am,
tools/schedsim/shell/schedsim_priority/config.c,
tools/schedsim/shell/schedsim_priority/printheir_executing.c,
tools/schedsim/shell/schedsim_priority/schedsim.cc,
tools/schedsim/shell/schedsim_priority/wrap_thread_dispatch.c,
tools/schedsim/shell/scripts/script01,
tools/schedsim/shell/scripts/script02,
tools/schedsim/shell/scripts/script03,
tools/schedsim/shell/scripts/script04,
tools/schedsim/shell/scripts/script05,
tools/schedsim/shell/scripts/script06,
tools/schedsim/shell/shared/.cvsignore,
tools/schedsim/shell/shared/Makefile.am,
tools/schedsim/shell/shared/commands.c,
tools/schedsim/shell/shared/getopt.c,
tools/schedsim/shell/shared/lookup_semaphore.c,
tools/schedsim/shell/shared/lookup_task.c,
tools/schedsim/shell/shared/main_clocktick.c,
tools/schedsim/shell/shared/main_echo.c,
tools/schedsim/shell/shared/main_executing.c,
tools/schedsim/shell/shared/main_heir.c,
tools/schedsim/shell/shared/main_help.c,
tools/schedsim/shell/shared/main_rtemsinit.c,
tools/schedsim/shell/shared/main_semcreate.c,
tools/schedsim/shell/shared/main_semdelete.c,
tools/schedsim/shell/shared/main_semflush.c,
tools/schedsim/shell/shared/main_semobtain.c,
tools/schedsim/shell/shared/main_semrelease.c,
tools/schedsim/shell/shared/main_taskcreate.c,
tools/schedsim/shell/shared/main_taskdelete.c,
tools/schedsim/shell/shared/main_taskmode.c,
tools/schedsim/shell/shared/main_taskpriority.c,
tools/schedsim/shell/shared/main_taskresume.c,
tools/schedsim/shell/shared/main_tasksuspend.c,
tools/schedsim/shell/shared/main_taskwakeafter.c,
tools/schedsim/shell/shared/schedsim_shell.h,
tools/schedsim/shell/shared/shell_cmdset.c,
tools/schedsim/shell/shared/shell_makeargs.c,
tools/schedsim/shell/shared/include/shell.h,
tools/schedsim/shell/shared/include/newlib/_ansi.h,
tools/schedsim/shell/shared/include/newlib/getopt.h: Removed.
* configure.ac: RTEMS Scheduler Simulator is now in its own CVS module
named rtems-schedsim.
* shgen.c: include <stdlib.h>.
* Makefile.am: Let shgen.1 depend on shgen$(EXEEXT).
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* configure.ac: Remove AC_EXEEXT (obsolete).
* sh/COPYING: Readded. Deleting this violated GPL on shgen.
* sh/COPYING: Deleted.
* sh/Makefile.am: Use "./shgen" not "shgen" so current directory
does not have to be in the PATH.
* configure.in: Remove.
* shgen.c: Set default Phi to 20MHz (BUG-FIX).
* Makefile.am: Switch to GNU-canonicalized autoconf macros.
that contains:
* Removes MKLIB
handling)
His comments follow:
This is a minor enhancement to shgen, which should not have any
side-effects.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
