path: root/tools/cpu/nios2/README (unfollow)
2018-06-14tools: Remove nios2genSebastian Huber1-146/+0
All tools should be removed from the RTEMS source repository at some point in time. Tools with a BSD-style license will be moved to the RTEMS tools repository. Unfortunately, the this tool is RTEMS GPL licensed. If users of this tool still exist, they can reimplement the functionality using a BSD-style license and add it to the RTEMS tools. Close #3444.
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-2/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2011-05-17 * tools/build/.cvsignore, tools/build/ChangeLog,Joel Sherrill1-0/+148
tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c, tools/build/cklength.c, tools/build/config.h.in, tools/build/configure.ac, tools/build/cvsignore-add.sh, tools/build/doxy-filter, tools/build/eolstrip.c, tools/build/install-if-change.in, tools/build/multigen, tools/build/packhex.c, tools/build/rtems-bin2c.c, tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac, tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog, tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac, tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore, tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am, tools/cpu/nios2/README, tools/cpu/nios2/bridges.c, tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c, tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac, tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h, tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h, tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h, tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c, tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c, tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf, tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING, tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO, tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h, tools/cpu/sh/shgen.c: New files.
2011-05-172011-05-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-148/+0
* tools/build/.cvsignore, tools/build/ChangeLog, tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c, tools/build/cklength.c, tools/build/configure.ac, tools/build/cvsignore-add.sh, tools/build/doxy-filter, tools/build/eolstrip.c, tools/build/install-if-change.in, tools/build/multigen, tools/build/packhex.c, tools/build/rtems-bin2c.c, tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac, tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog, tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac, tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore, tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am, tools/cpu/nios2/README, tools/cpu/nios2/bridges.c, tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c, tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac, tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h, tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h, tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h, tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c, tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c, tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf, tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING, tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO, tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h, tools/cpu/sh/shgen.c, tools/schedsim/.cvsignore, tools/schedsim/ChangeLog, tools/schedsim/Makefile.am, tools/schedsim/README, tools/schedsim/configure.ac, tools/schedsim/rtems/.cvsignore, tools/schedsim/rtems/ChangeLog, tools/schedsim/rtems/Makefile.am, tools/schedsim/rtems/interr.c, tools/schedsim/rtems/rtems_init.c, tools/schedsim/rtems/rtems_sched.h, tools/schedsim/rtems/wkspace.c, tools/schedsim/rtems/sched_cpu/cpu.c, tools/schedsim/rtems/sched_cpu/cpu_asm.c, tools/schedsim/rtems/sched_cpu/rtems/asm.h, tools/schedsim/rtems/sched_cpu/rtems/stringto.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpu.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpu_asm.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpuopts.h, tools/schedsim/rtems/sched_cpu/rtems/score/no_cpu.h, tools/schedsim/rtems/sched_cpu/rtems/score/types.h, tools/schedsim/shell/.cvsignore, tools/schedsim/shell/ChangeLog, tools/schedsim/shell/Makefile.am, tools/schedsim/shell/schedsim_priority/.cvsignore, tools/schedsim/shell/schedsim_priority/Makefile.am, tools/schedsim/shell/schedsim_priority/config.c, tools/schedsim/shell/schedsim_priority/printheir_executing.c, tools/schedsim/shell/schedsim_priority/schedsim.cc, tools/schedsim/shell/schedsim_priority/wrap_thread_dispatch.c, tools/schedsim/shell/scripts/script01, tools/schedsim/shell/scripts/script02, tools/schedsim/shell/scripts/script03, tools/schedsim/shell/scripts/script04, tools/schedsim/shell/scripts/script05, tools/schedsim/shell/scripts/script06, tools/schedsim/shell/shared/.cvsignore, tools/schedsim/shell/shared/Makefile.am, tools/schedsim/shell/shared/commands.c, tools/schedsim/shell/shared/getopt.c, tools/schedsim/shell/shared/lookup_semaphore.c, tools/schedsim/shell/shared/lookup_task.c, tools/schedsim/shell/shared/main_clocktick.c, tools/schedsim/shell/shared/main_echo.c, tools/schedsim/shell/shared/main_executing.c, tools/schedsim/shell/shared/main_heir.c, tools/schedsim/shell/shared/main_help.c, tools/schedsim/shell/shared/main_rtemsinit.c, tools/schedsim/shell/shared/main_semcreate.c, tools/schedsim/shell/shared/main_semdelete.c, tools/schedsim/shell/shared/main_semflush.c, tools/schedsim/shell/shared/main_semobtain.c, tools/schedsim/shell/shared/main_semrelease.c, tools/schedsim/shell/shared/main_taskcreate.c, tools/schedsim/shell/shared/main_taskdelete.c, tools/schedsim/shell/shared/main_taskmode.c, tools/schedsim/shell/shared/main_taskpriority.c, tools/schedsim/shell/shared/main_taskresume.c, tools/schedsim/shell/shared/main_tasksuspend.c, tools/schedsim/shell/shared/main_taskwakeafter.c, tools/schedsim/shell/shared/schedsim_shell.h, tools/schedsim/shell/shared/shell_cmdset.c, tools/schedsim/shell/shared/shell_makeargs.c, tools/schedsim/shell/shared/include/shell.h, tools/schedsim/shell/shared/include/newlib/_ansi.h, tools/schedsim/shell/shared/include/newlib/getopt.h: Removed. * configure.ac: RTEMS Scheduler Simulator is now in its own CVS module named rtems-schedsim.
2006-08-152006-08-15 Kolja Waschk <kawk@telos.de>Joel Sherrill1-4/+133
* linkcmds.c, linkcmds.h, memory.c, memory.h, sample.ptf: New files. * bridges.c: corrected detection of bridged connections * clocks.c: removed a printf * linkcmds.[ch] new files, added output of linker script * Makefile.am: added new files * memory.[ch]: new files, detection of memory in SOPC configuration * nios2gen.c: updated command line parsing and output control * output.[ch]: improved output of BSP header file * ptf.[ch]: added ptf_dump_ptf_item and small fixes * sample.ptf: new file, sample configuration for nios2gen * README: updated
2006-08-092006-08-09 Kolja Waschk <waschk@telos.de>Joel Sherrill1-0/+19
* configure.ac: New port to Altera NIOS II. * nios2/.cvsignore, nios2/Makefile.am, nios2/README, nios2/bridges.c, nios2/bridges.h, nios2/clocks.c, nios2/clocks.h, nios2/configure.ac, nios2/devices.c, nios2/devices.h, nios2/nios2gen.c, nios2/output.c, nios2/output.h, nios2/ptf.c, nios2/ptf.h: New files.
