* | Regenerated. | Joel Sherrill | 1999-05-27 | 1 | -51/+113 |
* | Regenerated. | Joel Sherrill | 1999-05-18 | 1 | -113/+51 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-04-12 | 2 | -109/+213 |
| | | | | | | | | | | | | | | | | | | | | | | This patch addresses a few minor issues and contains a few (minor) preparations for automake. * configure.in: Fix for handing c/src/tests subdirectory handling (FIX) * aclocal/rtems-top.m4: + Add TARGET_SUBDIR and --with-target-subdir (preparation of future enhancements for cross-compiling) + Activate RTEMS_ROOT handling (automake preparation) * automake/*.am: replace comments "#" with "##" so that comments won't get included into Makefile.in's anymore * c/update-tools/* automake support (NEW) * ./autogen update/enhancement (cf. ./autogen for details) After applying this patch please run: ./autogen cvs add c/update-tools/configure.in cvs add c/update-tools/Makefile.am cvs add c/update-tools/aclocal.m4 | ||||
* | Regenerated. | Joel Sherrill | 1999-03-31 | 2 | -190/+106 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-03-29 | 1 | -0/+4 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Yet some more modifications, I would recommend to be considered before releasing a snapshot: 1. Cleanup to aclocal/ cvs rm -f aclocal/cygwin.m4 cvs rm -f aclocal/exeext.m4 They are neither used nor needed anymore, however they also don't disturb (we use autoconf-2.13's AC_EXEEXT instead, now) ---------- 2. rtems-rc-19990328-0.diff Some (minor) bug-fixes: * make/Templates/Makefile.inc.in: use the new installation directory ($(prefix)/ instead of $(prefix)/rtems/) * c/src/exec/score/tools/generic/Makefile.am: added line to include local.am * c/src/exec/score/tools/*/configure.in: added CVS Id header ---------- 3. rtems-rc-19990328-1.diff Enhancements and cleanups to autogen, rtems-polish.sh, configure.in etc. * autogen: Use the file "VERSION" to detect RTEMS toplevel directory, extended usage-message, use "find -print" * c/update-tools/cipolish: New script to beautify configure.in scripts * c/update-tools/rtems-polish.sh: Use the file "VERSION" to detect RTEMS toplevel directory, extended usage-message, added variable for perl scripts' subdirectory, use "find -print", cipolish support, new options -ac -am -ci. * aclocal/*.m4, configure.in: moved some AC_SUBST lines to aclocal/*.m4 (reduces size of configure.in scripts, eases splitting configure.in scripts). ---------- | ||||
* | These files were not added as part of a recent patch from | Joel Sherrill | 1999-03-24 | 4 | -0/+1680 |
| | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -2/+2 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -4/+4 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -9/+9 |
* | added ifdef around variables to eliminate warnings when cross | Joel Sherrill | 1997-04-07 | 1 | -0/+2 |
* | updates from Tony Bennett | Joel Sherrill | 1996-04-22 | 1 | -6/+35 |
* | minor changes so it would compile in a cross environment | Joel Sherrill | 1995-12-05 | 1 | -0/+2 |
* | all targets compile .. tony's patches in place | Joel Sherrill | 1995-09-29 | 1 | -2/+2 |
* | Initial attempt at building HP PA-RISC using Solaris hosted tools. | Joel Sherrill | 1995-09-12 | 1 | -5/+129 |
| | | | | Changed back to Newlib for Solaris UNIX simulator. | ||||
* | Fixed missing RCS Ids | Joel Sherrill | 1995-08-22 | 1 | -1/+1 |
* | Fully tested on all in-house targets | Joel Sherrill | 1995-05-24 | 1 | -4/+4 |
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+191 |
