scripts (make/rtems.cfg)
Testing:
BSDINSTALL=@INSTALL@
in autoconf.
fixed.
sources files.
TARGET_VARIANTS
NOTE:
FINALLY:
to each Makefile.in.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
be resolved.
