path: root/tools/cpu/generic/ChangeLog (unfollow)
2013-03-08RTEMS: Delete ChangeLog files.Gedare Bloom1-78/+0
This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain.
2011-05-17 * tools/build/.cvsignore, tools/build/ChangeLog,Joel Sherrill1-24/+5
tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c, tools/build/cklength.c, tools/build/config.h.in, tools/build/configure.ac, tools/build/cvsignore-add.sh, tools/build/doxy-filter, tools/build/eolstrip.c, tools/build/install-if-change.in, tools/build/multigen, tools/build/packhex.c, tools/build/rtems-bin2c.c, tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac, tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog, tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac, tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore, tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am, tools/cpu/nios2/README, tools/cpu/nios2/bridges.c, tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c, tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac, tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h, tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h, tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h, tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c, tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c, tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf, tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING, tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO, tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h, tools/cpu/sh/shgen.c: New files.
2011-02-022011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius1-0/+4
2007-01-262007-01-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius1-0/+4
* Makefile.am: Use MKDIR_P instead of mkdir_p.
2006-12-022006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius1-0/+4
2006-10-172006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius1-0/+4
2004-09-242004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-0/+4
2003-12-122003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-0/+4
* Makefile.am: Reworked.
2003-12-102003-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-0/+4
* Makefile.am: Cosmetics.
2003-08-182003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-0/+4
2003-08-18Fix broken ChangeLog entries.Ralf Corsepius1-1/+1
2003-08-162003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-0/+4
2003-08-112003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-0/+4
2003-03-11Merger from rtems-4-6-branch.Ralf Corsepius1-0/+4
2003-02-112003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-0/+4
2002-10-212002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-0/+6
* .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
2002-04-032002-04-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
* configure.ac: Remove AC_EXEEXT (obsolete).
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+7
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS.
2001-10-112001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+6
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate.
2000-11-092000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
2000-11-022000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
2000-10-272000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+7
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization.
2000-08-10Adding ChangeLogs.Joel Sherrill1-0/+3
