This script is horribly out of date. A new version could be placed in
RTEMS tools if necessary.
Close #3451.
All tools should be removed from the RTEMS source repository at some
point in time. Tools with a BSD-style license will be moved to the
RTEMS tools repository. Unfortunately, the this tool is RTEMS GPL
licensed.
If users of this tool still exist, they can reimplement the
functionality using a BSD-style license and add it to the RTEMS tools.
Close #3444.
point in time. Tools with a BSD-style license will be moved to the RTEMS
tools repository. Unfortunately, the shgen tool is GPL licensed.
Remove all uses of this tool from the code base. Replace generated files
with stub functions. If users of this BSP still exist, they can
reimplement the functionality using a BSD-style license.
Close #3443.
upgrade to that version.
Close #3387.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
for details.
tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c,
tools/build/cklength.c, tools/build/config.h.in,
tools/build/configure.ac, tools/build/cvsignore-add.sh,
tools/build/doxy-filter, tools/build/eolstrip.c,
tools/build/install-if-change.in, tools/build/multigen,
tools/build/packhex.c, tools/build/rtems-bin2c.c,
tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore,
tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac,
tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog,
tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac,
tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore,
tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am,
tools/cpu/nios2/README, tools/cpu/nios2/bridges.c,
tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c,
tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac,
tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h,
tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h,
tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h,
tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c,
tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c,
tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf,
tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING,
tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO,
tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h,
tools/cpu/sh/shgen.c: New files.
* * configure.ac: Remove RTEMS_CPU_SUBDIRS.
* configure.ac: Add 2nd arg to RTEMS_TOP.
* configure.ac: Rework. Make package a host compiled package.
* Makefile.am: Ditto.
* configure.ac: Reflect having moved to testsuites/.
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* configure.ac: Apply RTEMS_CPU_SUBDIRS for potential CPU-subdirs.
* configure.in: Remove.
