mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
This patch addresses a few configuration issues and removes some
duplicate configuration files.
Background:
* some files used in AC_INIT were not unique enough and can lead to
problems if a user plays with configure scripts.
* the Makefile templates are independent of the target/cpu and bsp, so
the bsp dependent versions (c/src/make/Templates) are removed.
patch -p1 < rtems-rc-19990820-3.diff
rm -f c/src/make/Templates
ATTENTION: This patch removes several files and one directory :)
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
<corsepiu@faw.uni-ulm.de>.
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
This patch fixes a nasty problem with build-tools/Makefile.am:
When using install-sh instead of /usr/bin/install, only the first file
gets installed during the preinstall stage.
the build-tools layout to simplify it.
This script reorganizes and simpilfies the build-tools subdirectories.
It moves all source-files and scripts to c/build-tools/. This will
enable use to use this directory directly to refer to the build-tools
instead of copying them around in a "preinstall" step in future.
However, RTEMS's autoconf Makefile.ins and *.cfg files are not yet
prepared to apply this approach and therefore require additional work.
preparations for automake.
* aclocal/rtems-top.m4:
description follows:
Description:
config.h.ins)
acpolish
configure scripts
Remarks:
[$(prefix)].
issues.
egcs/contrib/egcs_update).
ATTENTION:
* "make RTEMS_BSP=<bsp> dist"
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
scripts (make/rtems.cfg)
Testing:
BSDINSTALL=@INSTALL@
in autoconf.
fixed.
sources files.
TARGET_VARIANTS
NOTE:
FINALLY:
to each Makefile.in.
<qqi@world.std.com>). Unfortunately after merging these,
the pc386 will not boot using grub for for. It still does not
work using netboot for me. Here is his summary of changes:
rtems/c/src/lib/libbsp/i386/pc386/Makefile.in
Added support for new sub-directory
rtems/c/src/lib/libbsp/i386/pc386/bsp_specs
Made possible to build COFF image
rtems/c/src/lib/libbsp/i386/pc386/console/console.c
Added support for serial consoles, selectable by patching
binary image, added __assert(), use _IBMPC_inch_sleep()
instaed of _IMBPC_inch()
rtems/c/src/lib/libbsp/i386/pc386/console/inch.c
Added _IMBPC_inch_sleep()
rtems/c/src/lib/libbsp/i386/pc386/console/outch.c
Oops - just formatting
rtems/c/src/lib/libbsp/i386/pc386/include/Makefile.in
Added support for new files
rtems/c/src/lib/libbsp/i386/pc386/include/bsp.h
Added support for new features
rtems/c/src/lib/libbsp/i386/pc386/include/pc386uart.h
New file: definitions for serial ports
rtems/c/src/lib/libbsp/i386/pc386/include/pcibios.h
New file: definitions for PCI BIOS
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/Makefile.in
New file: makefile in new directory
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub-glue.c
New file: i386-stub interface
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub.c
New file: i386-stub itself
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pc386uart.c
New file: serial ports
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pcibios.c
New file: PCI BIOS support
rtems/c/src/lib/libbsp/i386/pc386/start/start.s
Commented out DEBUG_EARLY stuff, everything is working fine
rtems/c/src/lib/libbsp/i386/pc386/start/start16.s
Cleaned up
rtems/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
Added call to console_resereve_resources
rtems/c/src/lib/libbsp/i386/pc386/startup/exit.c
rtems/c/src/lib/libbsp/i386/pc386/startup/ldsegs.s
Fixed typo in comments
rtems/c/src/lib/libbsp/i386/pc386/tools/Makefile.in
Changed to reflect cnages in code
rtems/c/src/lib/libbsp/i386/pc386/tools/bin2boot.c
Trivialized, problem - I do not know how to make patch
remove obsolete files - there are a lot of them there
rtems/c/src/lib/libbsp/i386/pc386/tools/binpatch.c
New file: utility to do binary patches
rtems/c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in
Added support for new directory
rtems/make/custom/pc386.cfg
Add COFF image building
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
is available and has the code available.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
direction. This fixes a problem reported by Steve Evans of Radstone
since he is using glibc2.
generated when egcs is used with "-Wall -pedantic".
enclose.
be resolved.
