* ampolish3.in: Check Makefile.am for SUBDIRS.
Add all-am: for PREINSTALL_FILES.
* ampolish3.in: Add all: for PREINSTALL_FILES.
Add all-local for TMPINSTALL_FILES.
Misc bug fixes.
* ampolish3.in: Check if Makefile.am already contains CLEANFILES or
DISTCLEANFILES.
* ampolish3.im: Update.
* ampolish3.in: Sync with private bleeding-edge .
* ampolish3.in: Use @PERL@, partial update from local sources.
* configure.ac: Add ampolish3.
* Makefile.am: Add ampolish3.
* ampolish3.in: New.
* Makefile.am: Add EXTRA_DIST = search-id.sh multigen
cvsignore-add.sh.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* cvsignore-add.sh: Script to append a specific file to all
.cvsignore files if the files exists is a specific directory.
* lock-directory.in, unlock-directory.in: Removed.
* Makefile.am, README, .cvsignore: Updated to reflect above.
* configure.ac: Remove AC_EXEEXT (obsolete).
* configure.in: Remove.
* config.h.in: Automatically generated. Remove from CVS.
* Makefile.am: Switch to GNU-canonicalized autoconf macros.
* multigen: Fix BARE_CPU_CFLAGS.
* multigen: Fix usage.
that adds multigen to the list of noinst_SCRIPTS.
<corsepiu@faw.uni-ulm.de> to update multigen.
that contains:
* Removes MKLIB
handling)
that should not have been.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
