path: root/tools/build (unfollow)
2012-05-07Revert: Remove CVS IdsJoel Sherrill2-0/+8
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details.
2012-05-04Remove CVS-Ids.Ralf Corsépius2-8/+0
2012-02-01Remove all .cvsignore files.Joel Sherrill1-18/+0
2011-06-082011-06-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-0/+13
* config.h.in: Regenerated.
2011-05-17 * tools/build/.cvsignore, tools/build/ChangeLog,Joel Sherrill17-0/+3212
tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c, tools/build/cklength.c, tools/build/config.h.in, tools/build/configure.ac, tools/build/cvsignore-add.sh, tools/build/doxy-filter, tools/build/eolstrip.c, tools/build/install-if-change.in, tools/build/multigen, tools/build/packhex.c, tools/build/rtems-bin2c.c, tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac, tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog, tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac, tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore, tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am, tools/cpu/nios2/README, tools/cpu/nios2/bridges.c, tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c, tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac, tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h, tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h, tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h, tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c, tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c, tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf, tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING, tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO, tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h, tools/cpu/sh/shgen.c: New files.
2011-05-172011-05-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill16-3157/+0
* tools/build/.cvsignore, tools/build/ChangeLog, tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c, tools/build/cklength.c, tools/build/configure.ac, tools/build/cvsignore-add.sh, tools/build/doxy-filter, tools/build/eolstrip.c, tools/build/install-if-change.in, tools/build/multigen, tools/build/packhex.c, tools/build/rtems-bin2c.c, tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac, tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog, tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac, tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore, tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am, tools/cpu/nios2/README, tools/cpu/nios2/bridges.c, tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c, tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac, tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h, tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h, tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h, tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c, tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c, tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf, tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING, tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO, tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h, tools/cpu/sh/shgen.c, tools/schedsim/.cvsignore, tools/schedsim/ChangeLog, tools/schedsim/Makefile.am, tools/schedsim/README, tools/schedsim/configure.ac, tools/schedsim/rtems/.cvsignore, tools/schedsim/rtems/ChangeLog, tools/schedsim/rtems/Makefile.am, tools/schedsim/rtems/interr.c, tools/schedsim/rtems/rtems_init.c, tools/schedsim/rtems/rtems_sched.h, tools/schedsim/rtems/wkspace.c, tools/schedsim/rtems/sched_cpu/cpu.c, tools/schedsim/rtems/sched_cpu/cpu_asm.c, tools/schedsim/rtems/sched_cpu/rtems/asm.h, tools/schedsim/rtems/sched_cpu/rtems/stringto.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpu.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpu_asm.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpuopts.h, tools/schedsim/rtems/sched_cpu/rtems/score/no_cpu.h, tools/schedsim/rtems/sched_cpu/rtems/score/types.h, tools/schedsim/shell/.cvsignore, tools/schedsim/shell/ChangeLog, tools/schedsim/shell/Makefile.am, tools/schedsim/shell/schedsim_priority/.cvsignore, tools/schedsim/shell/schedsim_priority/Makefile.am, tools/schedsim/shell/schedsim_priority/config.c, tools/schedsim/shell/schedsim_priority/printheir_executing.c, tools/schedsim/shell/schedsim_priority/schedsim.cc, tools/schedsim/shell/schedsim_priority/wrap_thread_dispatch.c, tools/schedsim/shell/scripts/script01, tools/schedsim/shell/scripts/script02, tools/schedsim/shell/scripts/script03, tools/schedsim/shell/scripts/script04, tools/schedsim/shell/scripts/script05, tools/schedsim/shell/scripts/script06, tools/schedsim/shell/shared/.cvsignore, tools/schedsim/shell/shared/Makefile.am, tools/schedsim/shell/shared/commands.c, tools/schedsim/shell/shared/getopt.c, tools/schedsim/shell/shared/lookup_semaphore.c, tools/schedsim/shell/shared/lookup_task.c, tools/schedsim/shell/shared/main_clocktick.c, tools/schedsim/shell/shared/main_echo.c, tools/schedsim/shell/shared/main_executing.c, tools/schedsim/shell/shared/main_heir.c, tools/schedsim/shell/shared/main_help.c, tools/schedsim/shell/shared/main_rtemsinit.c, tools/schedsim/shell/shared/main_semcreate.c, tools/schedsim/shell/shared/main_semdelete.c, tools/schedsim/shell/shared/main_semflush.c, tools/schedsim/shell/shared/main_semobtain.c, tools/schedsim/shell/shared/main_semrelease.c, tools/schedsim/shell/shared/main_taskcreate.c, tools/schedsim/shell/shared/main_taskdelete.c, tools/schedsim/shell/shared/main_taskmode.c, tools/schedsim/shell/shared/main_taskpriority.c, tools/schedsim/shell/shared/main_taskresume.c, tools/schedsim/shell/shared/main_tasksuspend.c, tools/schedsim/shell/shared/main_taskwakeafter.c, tools/schedsim/shell/shared/schedsim_shell.h, tools/schedsim/shell/shared/shell_cmdset.c, tools/schedsim/shell/shared/shell_makeargs.c, tools/schedsim/shell/shared/include/shell.h, tools/schedsim/shell/shared/include/newlib/_ansi.h, tools/schedsim/shell/shared/include/newlib/getopt.h: Removed. * configure.ac: RTEMS Scheduler Simulator is now in its own CVS module named rtems-schedsim.
2011-02-022011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-2/+6
2010-07-302010-07-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-2/+11
* rtems-bin2c.c: Fix memory leak in '.c' suffix strip. Also strip '.h' suffix.
2010-07-302010-07-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-1/+5
* rtems-bin2c.c: Make -v (verbose) working.
2010-07-302010-07-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius3-13/+15
* configure.ac: Check for libgen.h, basename. * rtems-bin2c.c: Use basename(3) instead of strrchr cascade. Introduce ifbasename. Use ifbasename in generated files.
2010-07-292010-07-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-7/+34
* rtems-bin2c.c: Add -C and -H options.
2010-03-122010-03-12 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-1/+7
* eolstrip.c: Readdress use of ctype methods per recommendation from D.J. Delorie on the newlib mailing list. We should pass an unsigned char into these methods.
2009-12-10Whitespace removal.Ralf Corsepius1-2/+2
2007-09-182007-09-18 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2-2/+6
* Makefile.am: Rename bin2c to rtems-bin2c.
2007-09-102007-09-10 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2-3/+9
* bin2c.c: Updated license after author changed it.
2007-09-072007-09-07 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2-4/+12
* bin2c.c: Update comments.
2007-09-042007-09-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-81/+241
* bin2c.c: Significant improvements -- add multiple options, generate both C and H files, do not always generate static. fix indentation, add comments.
2007-09-042007-09-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-0/+113
* bin2c.c: New file. http://www.wxwidgets.org/wiki/index.php/Embedding_PNG_Images-Bin2c_In_C
2007-09-042007-09-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-1/+8
* Makefile.am: Add bin2c so we can have a more reliable way to convert binary files to objects. If they are in C, we can use the correct CPU CFLAGS and they will link easier.
2006-12-022006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-1/+5
2006-10-172006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-2/+6
2006-07-132006-07-13 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius3-0/+29
* doxy-filter: New. * Makefile.am: Add doxy-filter.
2006-07-11Remove.Ralf Corsepius1-275/+0
2006-07-112006-07-11 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius3-7/+10
* ampolish3.in: Remove. * Makefile.am: Remove ampolish3. * configure.ac: Remove ampolish3, perl.
2006-01-142006-10-14 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2-2/+7
* ampolish3.in: Check Makefile.am for SUBDIRS. Add all-am: for PREINSTALL_FILES.
2006-01-122006-10-12 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2-10/+24
* ampolish3.in: Add all: for PREINSTALL_FILES. Add all-local for TMPINSTALL_FILES. Misc bug fixes.
2006-01-122006-10-12 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2-3/+26
* ampolish3.in: Check if Makefile.am already contains CLEANFILES or DISTCLEANFILES.
2006-01-102006-10-10 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2-100/+110
* ampolish3.im: Update.
2005-10-252005-10-25 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2-2/+6
* ampolish3.in: Sync with private bleeding-edge .
2005-10-242005-10-24 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2-2/+6
* ampolish3.in: Use @PERL@, partial update from local sources.
2005-10-24Fix typoRalf Corsepius1-1/+1
2005-10-242005-10-24 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius3-4/+12
* configure.ac: Add ampolish3. * Makefile.am: Add ampolish3. * ampolish3.in: New.
2005-10-24New.Ralf Corsepius1-0/+243
2004-09-24Fix typo in previous change.Ralf Corsepius1-1/+1
2004-09-242004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2-1/+5
2004-04-20Remove stray white spaces.Ralf Corsepius3-8/+8
2004-04-15Remove stray white spaces.Ralf Corsepius1-1/+0
2004-02-202004-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-0/+6
* Makefile.am: Add EXTRA_DIST = search-id.sh multigen cvsignore-add.sh.
2003-12-122003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-2/+6
2003-08-112003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-1/+5
2003-03-11Merger from rtems-4-6-branch.Ralf Corsepius2-2/+15
2003-02-112003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-1/+5
2002-10-212002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-3/+9
* .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
2002-10-042002-10-02 Chris Johns <cjohns@cybertec.com.au>Joel Sherrill3-1/+31
* cvsignore-add.sh: Script to append a specific file to all .cvsignore files if the files exists is a specific directory.
2002-05-012002-05-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill7-103/+6
* lock-directory.in, unlock-directory.in: Removed. * Makefile.am, README, .cvsignore: Updated to reflect above.
2002-04-032002-04-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+4
* configure.ac: Remove AC_EXEEXT (obsolete).
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill3-3/+9
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS.
2001-10-122001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+30
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
