* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | 2010-07-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-07-30 | 2 | -2/+11 |
| | | | | | * rtems-bin2c.c: Fix memory leak in '.c' suffix strip. Also strip '.h' suffix. | ||||
* | 2010-07-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-07-30 | 2 | -1/+5 |
| | | | | * rtems-bin2c.c: Make -v (verbose) working. | ||||
* | 2010-07-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-07-30 | 3 | -13/+15 |
| | | | | | | * configure.ac: Check for libgen.h, basename. * rtems-bin2c.c: Use basename(3) instead of strrchr cascade. Introduce ifbasename. Use ifbasename in generated files. | ||||
* | 2010-07-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-07-29 | 2 | -7/+34 |
| | | | | * rtems-bin2c.c: Add -C and -H options. | ||||
* | 2010-03-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-03-12 | 2 | -1/+7 |
| | | | | | | * eolstrip.c: Readdress use of ctype methods per recommendation from D.J. Delorie on the newlib mailing list. We should pass an unsigned char into these methods. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-12-10 | 1 | -2/+2 |
* | 2007-09-18 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-09-18 | 2 | -2/+6 |
| | | | | * Makefile.am: Rename bin2c to rtems-bin2c. | ||||
* | 2007-09-10 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-09-10 | 2 | -3/+9 |
| | | | | * bin2c.c: Updated license after author changed it. | ||||
* | 2007-09-07 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-09-07 | 2 | -4/+12 |
| | | | | * bin2c.c: Update comments. | ||||
* | 2007-09-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-09-04 | 2 | -81/+241 |
| | | | | | | * bin2c.c: Significant improvements -- add multiple options, generate both C and H files, do not always generate static. fix indentation, add comments. | ||||
* | 2007-09-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-09-04 | 2 | -0/+113 |
| | | | | | * bin2c.c: New file. http://www.wxwidgets.org/wiki/index.php/Embedding_PNG_Images-Bin2c_In_C | ||||
* | 2007-09-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-09-04 | 2 | -1/+8 |
| | | | | | | * Makefile.am: Add bin2c so we can have a more reliable way to convert binary files to objects. If they are in C, we can use the correct CPU CFLAGS and they will link easier. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2006-07-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-07-13 | 3 | -0/+29 |
| | | | | | * doxy-filter: New. * Makefile.am: Add doxy-filter. | ||||
* | Remove. | Ralf Corsepius | 2006-07-11 | 1 | -275/+0 |
* | 2006-07-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-07-11 | 3 | -7/+10 |
| | | | | | | * ampolish3.in: Remove. * Makefile.am: Remove ampolish3. * configure.ac: Remove ampolish3, perl. | ||||
* | 2006-10-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-14 | 2 | -2/+7 |
| | | | | | * ampolish3.in: Check Makefile.am for SUBDIRS. Add all-am: for PREINSTALL_FILES. | ||||
* | 2006-10-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 2 | -10/+24 |
| | | | | | | * ampolish3.in: Add all: for PREINSTALL_FILES. Add all-local for TMPINSTALL_FILES. Misc bug fixes. | ||||
* | 2006-10-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 2 | -3/+26 |
| | | | | | * ampolish3.in: Check if Makefile.am already contains CLEANFILES or DISTCLEANFILES. | ||||
* | 2006-10-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 2 | -100/+110 |
| | | | | * ampolish3.im: Update. | ||||
* | 2005-10-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-25 | 2 | -2/+6 |
| | | | | * ampolish3.in: Sync with private bleeding-edge . | ||||
* | 2005-10-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-24 | 2 | -2/+6 |
| | | | | * ampolish3.in: Use @PERL@, partial update from local sources. | ||||
* | Fix typo | Ralf Corsepius | 2005-10-24 | 1 | -1/+1 |
* | 2005-10-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-24 | 3 | -4/+12 |
| | | | | | | * configure.ac: Add ampolish3. * Makefile.am: Add ampolish3. * ampolish3.in: New. | ||||
* | New. | Ralf Corsepius | 2005-10-24 | 1 | -0/+243 |
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-20 | 3 | -8/+8 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 |
* | 2004-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-20 | 2 | -0/+6 |
| | | | | | * Makefile.am: Add EXTRA_DIST = search-id.sh multigen cvsignore-add.sh. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+6 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 2 | -1/+5 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 2 | -2/+15 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 2 | -1/+5 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 2 | -3/+9 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-10-02 Chris Johns <cjohns@cybertec.com.au> | Joel Sherrill | 2002-10-04 | 3 | -1/+31 |
| | | | | | * cvsignore-add.sh: Script to append a specific file to all .cvsignore files if the files exists is a specific directory. | ||||
* | 2002-05-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-05-01 | 7 | -103/+6 |
| | | | | | * lock-directory.in, unlock-directory.in: Removed. * Makefile.am, README, .cvsignore: Updated to reflect above. | ||||
* | 2002-04-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-04-03 | 2 | -1/+4 |
| | | | | * configure.ac: Remove AC_EXEEXT (obsolete). | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 3 | -3/+9 |
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-12 | 1 | -0/+30 |
| | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. | ||||
* | 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-12 | 1 | -29/+0 |
| | | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-11 | 2 | -0/+7 |
* | 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-01-24 | 2 | -7/+4 |
| | | | | * config.h.in: Automatically generated. Remove from CVS. | ||||
* | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-09 | 2 | -1/+5 |
| | | | | * Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. | ||||
* | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-02 | 2 | -1/+5 |
| | | | | * Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. | ||||
* | 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-10-31 | 2 | -1/+5 |
| | | | | * Makefile.am: Switch to GNU-canonicalized autoconf macros. |
