* | 2007-09-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-09-04 | 2 | -1/+8 |
| | | | | | | * Makefile.am: Add bin2c so we can have a more reliable way to convert binary files to objects. If they are in C, we can use the correct CPU CFLAGS and they will link easier. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2006-07-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-07-13 | 3 | -0/+29 |
| | | | | | * doxy-filter: New. * Makefile.am: Add doxy-filter. | ||||
* | Remove. | Ralf Corsepius | 2006-07-11 | 1 | -275/+0 |
* | 2006-07-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-07-11 | 3 | -7/+10 |
| | | | | | | * ampolish3.in: Remove. * Makefile.am: Remove ampolish3. * configure.ac: Remove ampolish3, perl. | ||||
* | 2006-10-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-14 | 2 | -2/+7 |
| | | | | | * ampolish3.in: Check Makefile.am for SUBDIRS. Add all-am: for PREINSTALL_FILES. | ||||
* | 2006-10-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 2 | -10/+24 |
| | | | | | | * ampolish3.in: Add all: for PREINSTALL_FILES. Add all-local for TMPINSTALL_FILES. Misc bug fixes. | ||||
* | 2006-10-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 2 | -3/+26 |
| | | | | | * ampolish3.in: Check if Makefile.am already contains CLEANFILES or DISTCLEANFILES. | ||||
* | 2006-10-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 2 | -100/+110 |
| | | | | * ampolish3.im: Update. | ||||
* | 2005-10-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-25 | 2 | -2/+6 |
| | | | | * ampolish3.in: Sync with private bleeding-edge . | ||||
* | 2005-10-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-24 | 2 | -2/+6 |
| | | | | * ampolish3.in: Use @PERL@, partial update from local sources. | ||||
* | Fix typo | Ralf Corsepius | 2005-10-24 | 1 | -1/+1 |
* | 2005-10-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-24 | 3 | -4/+12 |
| | | | | | | * configure.ac: Add ampolish3. * Makefile.am: Add ampolish3. * ampolish3.in: New. | ||||
* | New. | Ralf Corsepius | 2005-10-24 | 1 | -0/+243 |
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-20 | 3 | -8/+8 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 |
* | 2004-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-20 | 2 | -0/+6 |
| | | | | | * Makefile.am: Add EXTRA_DIST = search-id.sh multigen cvsignore-add.sh. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+6 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 2 | -1/+5 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 2 | -2/+15 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 2 | -1/+5 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 2 | -3/+9 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-10-02 Chris Johns <cjohns@cybertec.com.au> | Joel Sherrill | 2002-10-04 | 3 | -1/+31 |
| | | | | | * cvsignore-add.sh: Script to append a specific file to all .cvsignore files if the files exists is a specific directory. | ||||
* | 2002-05-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-05-01 | 7 | -103/+6 |
| | | | | | * lock-directory.in, unlock-directory.in: Removed. * Makefile.am, README, .cvsignore: Updated to reflect above. | ||||
* | 2002-04-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-04-03 | 2 | -1/+4 |
| | | | | * configure.ac: Remove AC_EXEEXT (obsolete). | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 3 | -3/+9 |
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-12 | 1 | -0/+30 |
| | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. | ||||
* | 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-12 | 1 | -29/+0 |
| | | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-11 | 2 | -0/+7 |
* | 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-01-24 | 2 | -7/+4 |
| | | | | * config.h.in: Automatically generated. Remove from CVS. | ||||
* | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-09 | 2 | -1/+5 |
| | | | | * Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. | ||||
* | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-02 | 2 | -1/+5 |
| | | | | * Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. | ||||
* | 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-10-31 | 2 | -1/+5 |
| | | | | * Makefile.am: Switch to GNU-canonicalized autoconf macros. | ||||
* | 2000-08-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-12 | 2 | -1/+5 |
| | | | | * multigen: Fix BARE_CPU_CFLAGS. | ||||
* | 2000-09-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-06 | 2 | -2/+8 |
| | | | | * multigen: Fix usage. | ||||
* | Adding ChangeLogs. | Joel Sherrill | 2000-08-10 | 1 | -0/+3 |
* | Patch rtems-rc-20000705-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-07-06 | 1 | -1/+1 |
| | | | | that adds multigen to the list of noinst_SCRIPTS. | ||||
* | Patch rtems-rc-20000615-2-cvs.diff from Ralf Corsepius | Joel Sherrill | 2000-06-15 | 1 | -0/+6 |
| | | | | <corsepiu@faw.uni-ulm.de> to update multigen. | ||||
* | New file from Ralf. | Joel Sherrill | 2000-06-14 | 1 | -0/+165 |
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -8/+5 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+19 |
| | | | | adds .cvsignore. | ||||
* | Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-02-08 | 1 | -0/+1 |
| | | | | | | | | | | | | | | | | | that contains: * Removes remaining (now illegal) references to $(SRC) from a couple of Makefile.ams * Removes duplicate AC_CONFIG_SUBDIRS macro from c/configure.in * Moves ENABLE_LIBCDIR into RTEMS_PROG_C[C|XX]_FOR_TARGET (hides LIBCDIR from most configure scripts, i.e. LIBCDIR becomes less visible) * Adds RTEMS_PROG_C[C|XX]_FOR_TARGET and RTEMS_CANONICALIZE_TOOLS to libbsp/*/configure.ins (A minor bug in previous implementations, which only has an impact when switching to GNU/Cygnus canonicalization) * Cleans up several bogus comments. * Removes MKLIB * Switches the version number to 4.5.0 (for testing version number handling) | ||||
* | Ralf Corsepius <corsepiu@faw.uni-ulm.de> caught some files in CVS | Joel Sherrill | 2000-01-31 | 1 | -1/+0 |
| | | | | that should not have been. | ||||
* | Removed aclocal.m4 generated from aclocal macros | Joel Sherrill | 1999-10-06 | 1 | -214/+0 |
* | Removed configure generated from configure.in | Joel Sherrill | 1999-10-06 | 1 | -1663/+0 |
