* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* cvsignore-add.sh: Script to append a specific file to all
.cvsignore files if the files exists is a specific directory.
* lock-directory.in, unlock-directory.in: Removed.
* Makefile.am, README, .cvsignore: Updated to reflect above.
* configure.ac: Remove AC_EXEEXT (obsolete).
* configure.in: Remove.
* config.h.in: Automatically generated. Remove from CVS.
* Makefile.am: Switch to GNU-canonicalized autoconf macros.
* multigen: Fix BARE_CPU_CFLAGS.
* multigen: Fix usage.
that adds multigen to the list of noinst_SCRIPTS.
<corsepiu@faw.uni-ulm.de> to update multigen.
that contains:
* Removes MKLIB
handling)
that should not have been.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
This patch addresses a few configuration issues and removes some
duplicate configuration files.
Background:
* some files used in AC_INIT were not unique enough and can lead to
problems if a user plays with configure scripts.
* the Makefile templates are independent of the target/cpu and bsp, so
the bsp dependent versions (c/src/make/Templates) are removed.
patch -p1 < rtems-rc-19990820-3.diff
rm -f c/src/make/Templates
ATTENTION: This patch removes several files and one directory :)
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
<corsepiu@faw.uni-ulm.de>.
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
This patch fixes a nasty problem with build-tools/Makefile.am:
When using install-sh instead of /usr/bin/install, only the first file
gets installed during the preinstall stage.
the build-tools layout to simplify it.
This script reorganizes and simpilfies the build-tools subdirectories.
It moves all source-files and scripts to c/build-tools/. This will
enable use to use this directory directly to refer to the build-tools
instead of copying them around in a "preinstall" step in future.
However, RTEMS's autoconf Makefile.ins and *.cfg files are not yet
prepared to apply this approach and therefore require additional work.
preparations for automake.
* aclocal/rtems-top.m4:
description follows:
Description:
config.h.ins)
acpolish
configure scripts
Remarks:
[$(prefix)].
issues.
egcs/contrib/egcs_update).
ATTENTION:
* "make RTEMS_BSP=<bsp> dist"
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
scripts (make/rtems.cfg)
Testing:
