* | rtems-test-check: Ignore tests which require real ISR based clock tick | Chris Johns | 2014-05-28 | 1 | -3/+27 |
| | | | | | | | | | BSPs for simulators which do not include a clock tick interrupt source are incapable of running some tests successfully. This is a common characteristic of some BSPs and a fixed set of tests. There is no point in duplicating this list of tests in those BSPs test configuration. Read testsuites/testdata/require-tick-isr.tcfg for details. | ||||
* | testsuite: Add a per BSP test check for tests not to build. | Chris Johns | 2014-05-05 | 1 | -0/+52 |
Provide a file per BSP to list tests that do not build for a BSP. This change removes the BSP_SMALL_MEMORY hack from the code. That hack was a mistake. Provide configuration files for each BSP with tests that cannot build. |
