1998-08-20 | Changed to avoid use of gets(). | Joel Sherrill | 1 | -8/+34 | |
1998-05-18 | Added proper reference now that Embedded Systems Programming's WWW site | Joel Sherrill | 1 | -1/+7 | |
is available and has the code available. | |||||
1998-01-23 | Solaris port updates from Chris Johns | Joel Sherrill | 1 | -1/+1 | |
1998-01-21 | Added autoconf support for strerror/sys_errlist per Ralf Corsepius' | Joel Sherrill | 1 | -0/+17 | |
direction. This fixes a problem reported by Steve Evans of Radstone since he is using glibc2. | |||||
1998-01-21 | Corrected prototypes for main per Ralf Corsepius' report of warnings | Joel Sherrill | 1 | -1/+4 | |
generated when egcs is used with "-Wall -pedantic". |
