path: root/tools/build/packhex.c (follow)
* Added proper reference now that Embedded Systems Programming's WWW siteJoel Sherrill1998-05-181-1/+7
| | | | is available and has the code available.
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-231-1/+1
* Added autoconf support for strerror/sys_errlist per Ralf Corsepius'Joel Sherrill1998-01-211-0/+17
| | | | | direction. This fixes a problem reported by Steve Evans of Radstone since he is using glibc2.
* Corrected prototypes for main per Ralf Corsepius' report of warningsJoel Sherrill1998-01-211-1/+4
| | | | generated when egcs is used with "-Wall -pedantic".
* Initial revisionJoel Sherrill1995-05-111-0/+513
