* | Remove stray white spaces. | Ralf Corsepius | 2004-04-20 | 1 | -1/+1 |
* | Changed to avoid use of gets(). | Joel Sherrill | 1998-08-20 | 1 | -8/+34 |
* | Added proper reference now that Embedded Systems Programming's WWW site | Joel Sherrill | 1998-05-18 | 1 | -1/+7 |
| | | | | is available and has the code available. | ||||
* | Solaris port updates from Chris Johns | Joel Sherrill | 1998-01-23 | 1 | -1/+1 |
* | Added autoconf support for strerror/sys_errlist per Ralf Corsepius' | Joel Sherrill | 1998-01-21 | 1 | -0/+17 |
| | | | | | direction. This fixes a problem reported by Steve Evans of Radstone since he is using glibc2. | ||||
* | Corrected prototypes for main per Ralf Corsepius' report of warnings | Joel Sherrill | 1998-01-21 | 1 | -1/+4 |
| | | | | generated when egcs is used with "-Wall -pedantic". | ||||
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+513 |
