the build-tools layout to simplify it.
This script reorganizes and simpilfies the build-tools subdirectories.
It moves all source-files and scripts to c/build-tools/. This will
enable use to use this directory directly to refer to the build-tools
instead of copying them around in a "preinstall" step in future.
However, RTEMS's autoconf Makefile.ins and *.cfg files are not yet
prepared to apply this approach and therefore require additional work.
description follows:
Description:
config.h.ins)
acpolish
configure scripts
Remarks:
[$(prefix)].
issues.
egcs/contrib/egcs_update).
ATTENTION:
* "make RTEMS_BSP=<bsp> dist"
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
BSDINSTALL=@INSTALL@
in autoconf.
fixed.
sources files.
TARGET_VARIANTS
NOTE:
FINALLY:
to each Makefile.in.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
be resolved.
