path: root/tools/build/install-if-change.in (follow)
* * tools/build/.cvsignore, tools/build/ChangeLog,Joel Sherrill2011-05-171-0/+142
| | | | | | | | | | | | | | | | | | | | | | | | | | | | tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c, tools/build/cklength.c, tools/build/config.h.in, tools/build/configure.ac, tools/build/cvsignore-add.sh, tools/build/doxy-filter, tools/build/eolstrip.c, tools/build/install-if-change.in, tools/build/multigen, tools/build/packhex.c, tools/build/rtems-bin2c.c, tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac, tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog, tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac, tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore, tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am, tools/cpu/nios2/README, tools/cpu/nios2/bridges.c, tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c, tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac, tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h, tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h, tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h, tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c, tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c, tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf, tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING, tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO, tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h, tools/cpu/sh/shgen.c: New files.
* 2011-05-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-05-171-142/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tools/build/.cvsignore, tools/build/ChangeLog, tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c, tools/build/cklength.c, tools/build/configure.ac, tools/build/cvsignore-add.sh, tools/build/doxy-filter, tools/build/eolstrip.c, tools/build/install-if-change.in, tools/build/multigen, tools/build/packhex.c, tools/build/rtems-bin2c.c, tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac, tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog, tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac, tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore, tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am, tools/cpu/nios2/README, tools/cpu/nios2/bridges.c, tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c, tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac, tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h, tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h, tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h, tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c, tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c, tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf, tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING, tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO, tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h, tools/cpu/sh/shgen.c, tools/schedsim/.cvsignore, tools/schedsim/ChangeLog, tools/schedsim/Makefile.am, tools/schedsim/README, tools/schedsim/configure.ac, tools/schedsim/rtems/.cvsignore, tools/schedsim/rtems/ChangeLog, tools/schedsim/rtems/Makefile.am, tools/schedsim/rtems/interr.c, tools/schedsim/rtems/rtems_init.c, tools/schedsim/rtems/rtems_sched.h, tools/schedsim/rtems/wkspace.c, tools/schedsim/rtems/sched_cpu/cpu.c, tools/schedsim/rtems/sched_cpu/cpu_asm.c, tools/schedsim/rtems/sched_cpu/rtems/asm.h, tools/schedsim/rtems/sched_cpu/rtems/stringto.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpu.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpu_asm.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpuopts.h, tools/schedsim/rtems/sched_cpu/rtems/score/no_cpu.h, tools/schedsim/rtems/sched_cpu/rtems/score/types.h, tools/schedsim/shell/.cvsignore, tools/schedsim/shell/ChangeLog, tools/schedsim/shell/Makefile.am, tools/schedsim/shell/schedsim_priority/.cvsignore, tools/schedsim/shell/schedsim_priority/Makefile.am, tools/schedsim/shell/schedsim_priority/config.c, tools/schedsim/shell/schedsim_priority/printheir_executing.c, tools/schedsim/shell/schedsim_priority/schedsim.cc, tools/schedsim/shell/schedsim_priority/wrap_thread_dispatch.c, tools/schedsim/shell/scripts/script01, tools/schedsim/shell/scripts/script02, tools/schedsim/shell/scripts/script03, tools/schedsim/shell/scripts/script04, tools/schedsim/shell/scripts/script05, tools/schedsim/shell/scripts/script06, tools/schedsim/shell/shared/.cvsignore, tools/schedsim/shell/shared/Makefile.am, tools/schedsim/shell/shared/commands.c, tools/schedsim/shell/shared/getopt.c, tools/schedsim/shell/shared/lookup_semaphore.c, tools/schedsim/shell/shared/lookup_task.c, tools/schedsim/shell/shared/main_clocktick.c, tools/schedsim/shell/shared/main_echo.c, tools/schedsim/shell/shared/main_executing.c, tools/schedsim/shell/shared/main_heir.c, tools/schedsim/shell/shared/main_help.c, tools/schedsim/shell/shared/main_rtemsinit.c, tools/schedsim/shell/shared/main_semcreate.c, tools/schedsim/shell/shared/main_semdelete.c, tools/schedsim/shell/shared/main_semflush.c, tools/schedsim/shell/shared/main_semobtain.c, tools/schedsim/shell/shared/main_semrelease.c, tools/schedsim/shell/shared/main_taskcreate.c, tools/schedsim/shell/shared/main_taskdelete.c, tools/schedsim/shell/shared/main_taskmode.c, tools/schedsim/shell/shared/main_taskpriority.c, tools/schedsim/shell/shared/main_taskresume.c, tools/schedsim/shell/shared/main_tasksuspend.c, tools/schedsim/shell/shared/main_taskwakeafter.c, tools/schedsim/shell/shared/schedsim_shell.h, tools/schedsim/shell/shared/shell_cmdset.c, tools/schedsim/shell/shared/shell_makeargs.c, tools/schedsim/shell/shared/include/shell.h, tools/schedsim/shell/shared/include/newlib/_ansi.h, tools/schedsim/shell/shared/include/newlib/getopt.h: Removed. * configure.ac: RTEMS Scheduler Simulator is now in its own CVS module named rtems-schedsim.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1998-10-141-0/+142
1. Rtems contains some perl scripts that use hard-coded paths to /usr/bin/perl or /usr/local/bin/perl I have already fixed these problems by adding some checks to configure.in. While doing this, I also cleaned up some more autoconf related problems for generating shell scripts. This patch might seem a bit scary to you, but I am quite confident it won't break something (I've been testing it for almost a week now, however it might introduce typos for a limited number configurations I don't have access to - But it shouldn't be a problem for you to test them :-). I expect to get this finished tonight, hence you will very likely have the patch when you get up tomorrow. Changes: * Check for PERL and disable all PERL scripts if perl wasn't found. * Generate all KSHELL-scripts with autoconf instead of make-script * Automatic dependency handling for autoconf generated KSHELL or PERL scripts (make/rtems.cfg) Notes: * this patch contains new files and deletes some other files. * The patch is relative to rtems-4.0.0-beta4 with my previous rtems-rc-981014-1.diff patch applied. Testing: I tested it with sh-rtems and posix under linux. Now all targets which are touched by this patch and which are not used while building for sh-rtems and posix still need to be tested. AFAIS, only the sparc/erc32 BSP should be affected by this criterion. And if you like to, you should also consider testing it on a Cygwin32 and a Solaris host for one arbitrary BSP.
